| How does one create pre-defined fixed elements/figures? [message #65143] |
Wed, 18 October 2006 09:02   |
Eclipse User  |
For my application I would like to have the graphical editor come up
with two predefined containers (I fancy two large labeled rectangles)
inside which the user then starts creating sub-elements and connecting
them, etc.
This corresponds to two top-level elements that *always* have to be
present in the XML files that I am dealing with. I don't want to have to
create these outermost elements, they simply should be there right from
the begin (i.e. even if creating an new "empty" file or model).
Can one create such fixed and predefined figures? How?
Michael
| Re: How does one create pre-defined fixed elements/figures? [message #65251 is a reply to message #65230] |
Wed, 18 October 2006 09:59   |
Eclipse User  |
Wow - *that* was easy! And it worked on the first try... unbelievable!
Thanks!
Michael :-)
"Michael Golubev" <michael.golubev@borland.com> wrote in message
news:eh5arh$3l4$1@utils.eclipse.org...
> You may remove tool references for this "fixed" mappings in the Map
> model, effectively removing creation tools for them.
> Then write custom code that creates this 2 fixed elements in the
> generated <Model>DiagramEditorUtil#createInitialModel(), something
> like
> * Create a new instance of domain element associated with canvas.
> * @generated NOT
> private static org.eclipse.uml2.uml.Package createInitialModel() {
>  org.eclipse.uml2.uml.Package root =
> UMLFactory.eINSTANCE.createModel();
>  root.setName("Model");
>  createDefaultPrimitiveTypeImports(root);
>  return root;
> Michael
> "Michael Moser" <mmo@zurich.ibm.com> wrote in message
> news:eh58lc$760$1@utils.eclipse.org...
>> connecting them, etc.
>> to create these outermost elements, they simply should be there right
>> from the begin (i.e. even if creating an new "empty" file or model).
>> Michael
FUDForum. Page generated in 0.08018 seconds
