run osgi config error [message #65124] |
Tue, 18 April 2006 13:56  |
When I try running an eclipse osgi, I have an error in the run wizard
configuration:
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
the details follow:
______________________________
at java.util.TreeMap.compare(Unknown Source)
at java.util.TreeMap.getEntry(Unknown Source)
at java.util.TreeMap.containsKey(Unknown Source)
org.eclipse.pde.internal.ui.launcher.EquinoxPluginBlock.retr ieveWorkspaceMap(EquinoxPluginBlock.java:236)
org.eclipse.pde.internal.ui.launcher.EquinoxPluginBlock.init WorkspacePluginsState(EquinoxPluginBlock.java:290)
org.eclipse.pde.internal.ui.launcher.EquinoxPluginBlock.init ializeFrom(EquinoxPluginBlock.java:246)
org.eclipse.pde.ui.launcher.EquinoxPluginsTab.initializeFrom (EquinoxPluginsTab.java:134)
org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.ini tializeFrom(AbstractLaunchConfigurationTabGroup.java:86)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:655)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$6.run(LaunchConfigurationTabGroupVi ewer.java:548)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:565)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:529)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:922)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$4.selectionChanged(LaunchConfigurationsDia log.java:545)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:833)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:831)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1137)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1157)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:236)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:230)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 404)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3323)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2969)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1080)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:37 5)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:379)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:321)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3346)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
_________________________________________________
eclipse 3.2RC1
FUDForum. Page generated in 0.03288 seconds
