Home » Eclipse Projects » Plugin Development Environment (PDE) » JSSE provider in Eclipse (Expeditor) project
JSSE provider in Eclipse (Expeditor) project [message #65071] Thu, 18 June 2009 09:09 Go to next message
Originally posted by: jochs.critical-masses.com
I'm working on a project using Eclipse and Lotus Expeditor (an Eclipse
framework) that calls on Google Application APIs to authenticate to the
Google cloud. The problem seems to arise when the Google classes try to
authenticate and the platform's JCE provider doesn't have the expected
SSL algorithm. Does anyone know how to fix this?
--BEGIN SYSOUT---
Jun 18, 2009 9:03:57 AM
com.ibm.rcp.security.ssl.PlatformSSLProtocolSocketFactory
createPlatformSSLContext()
WARNING: CWPST502W: The algorithm for recovering the key from the
keystore cannot be found.
Throwable occurred: java.security.NoSuchAlgorithmException: K00b3
at javax.net.ssl.SSLContext.getInstance(SSLContext.java:57)
com.ibm.rcp.security.ssl.PlatformSSLProtocolSocketFactory.cr eatePlatformSSLContext(PlatformSSLProtocolSocketFactory.java :47)
com.ibm.rcp.security.ssl.PlatformSSLProtocolSocketFactory.ge tSSLContext(PlatformSSLProtocolSocketFactory.java:69)
com.ibm.rcp.security.ssl.PlatformSSLProtocolSocketFactory.cr eateSocket(PlatformSSLProtocolSocketFactory.java:96)
org.apache.commons.httpclient.protocol.ControllerThreadSocke tFactory$1.doit(ControllerThreadSocketFactory.java:90)
org.apache.commons.httpclient.protocol.ControllerThreadSocke tFactory$SocketTask.run(ControllerThreadSocketFactory.java:1 57)
at java.lang.Thread.run(Thread.java:816)
Exception in thread "Timeout guard" java.lang.NullPointerException
org.apache.commons.httpclient.HttpConnection.open(HttpConnec tion.java:720)
org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionM anager.java:1321)
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:387)
org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:401)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:323)
com.ibm.rcp.net.protocol.http.HttpURLConnection.execute(Http URLConnection.java:254)
com.ibm.rcp.net.protocol.http.HttpURLConnection.getResponseC ode(HttpURLConnection.java:702)
com.ibm.rcp.net.protocol.http.HttpsURLConnection.getResponse Code(HttpsURLConnection.java:134)
com.google.gdata.client.GoogleAuthTokenFactory.makePostReque st(GoogleAuthTokenFactory.java:550)
com.google.gdata.client.GoogleAuthTokenFactory.getAuthToken( GoogleAuthTokenFactory.java:477)
com.google.gdata.client.GoogleAuthTokenFactory.setUserCreden tials(GoogleAuthTokenFactory.java:336)
com.google.gdata.client.GoogleService.setUserCredentials(Goo gleService.java:362)
com.google.gdata.client.GoogleService.setUserCredentials(Goo gleService.java:317)
com.google.gdata.client.GoogleService.setUserCredentials(Goo gleService.java:301)
at com.cmti.gapps.GAppPref$1.widgetSelected(GAppPref.java:69)
--END SYSOUT---
Re: JSSE provider in Eclipse (Expeditor) project [message #65140 is a reply to message #65071] Sat, 20 June 2009 10:02 Go to previous message
If you're building on top of Lotus XPD, I would use IBM's support
channels for help. Especially when you see 'com.ibm.rcp*' in the
stacktraces...
If it's a general Eclipse problem, we'd love to help.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: JSSE provider in Eclipse (Expeditor) project [message #598422 is a reply to message #65071] Sat, 20 June 2009 10:02 Go to previous message
stacktraces...
Previous Topic:Filtering a fragment on criteria other than Eclipse-PlatformFilter settings
Next Topic:Filtering a fragment on criteria other than Eclipse-PlatformFilter settings
Current Time: Fri Nov 07 18:55:24 EST 2025
Powered by FUDForum. Page generated in 0.06732 seconds
