Home » Language IDEs » PHP Development Tools (PDT) » Editor breaks up every now and then
Editor breaks up every now and then [message #65023] Thu, 24 January 2008 03:43 Go to next message
It seems that since a few days one or two of the files i edit keeps
breaking up the editor. I don't know if there are any known bugs
regarding this, or some situations i should avoid, but it breaks down
the entire platform too. I can't find any log files showing the problems.
Maybe someone can help me figure this one out by telling how i can find
the files where some information may be logged.
Thanks.
drm / Gerard
Re: Editor breaks up every now and then [message #65131 is a reply to message #65023] Mon, 28 January 2008 08:03 Go to previous messageGo to next message
It seems this occurs when a relatively large file ( about >500 lines) is
being processed for syntax highlighting, and meanwhile i save the file.
Maybe it's a dead lock?
exquisitus wrote:
> Thanks.
> drm / Gerard
Re: Editor breaks up every now and then [message #65153 is a reply to message #65131] Mon, 28 January 2008 08:19 Go to previous messageGo to next message
Are you using PDT 1.0.2 ? If so I would raise a bugzilla for this on
https://bugs.eclipse.org/bugs
Dave Kelsey
> exquisitus wrote:
>> find the files where some information may be logged.
>> Thanks.
>> drm / Gerard
Re: Editor breaks up every now and then [message #65173 is a reply to message #65131] Mon, 28 January 2008 19:30 Go to previous messageGo to next message
exquisitus - i just registered for the eclipse newsgroups, and was
assigned your username. (i thought it was odd that i wasn't allowed my
own.)
if you have trouble logging in - and then you may not see this message -
you can contact me via gmail - my userid is xurizaemon there (and should
be here too!)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216841 reported
Re: Editor breaks up every now and then [message #65657 is a reply to message #65173] Wed, 06 February 2008 08:41 Go to previous messageGo to next message
> own.)
> be here too!)
[offtopic]
I didn't change my username ;) I did now. No troubles here.
Re: Editor breaks up every now and then [message #65679 is a reply to message #65153] Wed, 06 February 2008 08:50 Go to previous messageGo to next message
Hi Dave,
I am using PDT 1.0.2.v20080102. I would post a bug if i knew how to
reproduce it, but it seems to happen quite randomly, unfortunately.
I think it might have something to do with
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201868
The symptoms sometimes are the same, but in most cases it freezes up my
entire workspace in the end....
I'll try disabling code folding and report back here if i can safely say
anything about the influence of disabling folding on this issue.
drm / Gerard
> Dave Kelsey
>> is being processed for syntax highlighting, and meanwhile i save the
>> file. Maybe it's a dead lock?
>> exquisitus wrote:
>>> Hi,
>>> problems.
>>> Thanks.
>>> drm / Gerard
Re: Editor breaks up every now and then [message #65952 is a reply to message #65153] Wed, 13 February 2008 06:08 Go to previous message
Hi Dave,
I think i can safely say disabling code folding fixes the problem. What
do you recommend about posting the bug?
drm / Gerard
drm wrote:
> I'll try disabling code folding and report back here if i can safely say anything about the influence of disabling folding on this issue.
> drm / Gerard
Previous Topic:Eclipse PDT 1.0.2 is freezing randomly on big file
Next Topic:No PHP Compile Errors in eclipse PDT
Current Time: Tue Nov 04 19:08:51 EST 2025
Powered by FUDForum. Page generated in 0.04604 seconds
