Home » Language IDEs » C / C++ IDE (CDT) » Outline View
Outline View [message #65021] Mon, 24 March 2003 04:43 Go to next message
Originally posted by: cs.bcl.de
I have a large C File and the outline view does not display all keywords.
I see only the first part of the file. Is there a limitation and can I
change that ??
regards
Christoph
Re: Outline View [message #65245 is a reply to message #65021] Wed, 26 March 2003 09:56 Go to previous message
i have relocated the problem. It is the same as described from Mr. Fabio
Frumento on 24. January. I am using the keyword "huge" in a function
declaration. When the outline parser reads that, it stops.
The same effect appears, if i delcare my own keyword using "#define".
E.g.
#define CDECL __cdecl
void CDECL myfunc() { }
regards
Christoph
Beck IPC GmbH
Christoph wrote:
> Hello,
> change that ??
> regards
> Christoph
Previous Topic:File Template in Eclipse/CDT
Next Topic:Is there a public method to set the project build command?
Current Time: Sat Nov 08 23:20:44 EST 2025
Powered by FUDForum. Page generated in 0.03287 seconds
