Home » Eclipse Projects » Plugin Development Environment (PDE) » ClassNotFound using Lotus Expeditor w/Google Apps API
ClassNotFound using Lotus Expeditor w/Google Apps API [message #65002] Wed, 17 June 2009 15:30 Go to next message
Originally posted by: jochs.critical-masses.com
I have tested and run standard VM Google Apps code in Eclipse Ganymede.
When I try to insert the code into an event handler for a button on a
preference page in a plugin, though, I get a sever EventLoopException
telling me that the class was not found (Throwable occurred:
java.lang.NoClassDefFoundError:
com.google.gdata.client.docs.DocsService) I imagine this must be a build
path issue as I have the necessary jars in the project's Java Build Path
as external jar files. How do I correct or troubleshoot this issue?
Thanx in adv.
-Jake
[1]
http://code.google.com/apis/documents/docs/2.0/developers_gu ide_java.html
FIXED: Re: ClassNotFound using Lotus Expeditor w/Google Apps API [message #65094 is a reply to message #65002] Thu, 18 June 2009 09:11 Go to previous message
I put the dependecy jars in the project's /lib folder and named them on
the project's runtime classpath. I would have thought that having the
project dependency alone would have guaranteed the proper setup when
running... I wish I could find better documentation on this aspect of
Eclipse/PDE programming.
> Thanx in adv.
> -Jake
> [1]
FIXED: Re: ClassNotFound using Lotus Expeditor w/Google Apps API [message #598407 is a reply to message #65002] Thu, 18 June 2009 09:11 Go to previous message
> Thanx in adv.
> -Jake
> [1]
Previous Topic:JSSE provider in Eclipse (Expeditor) project
Next Topic:Filtering a fragment on criteria other than Eclipse-PlatformFilter settings
Current Time: Tue Nov 04 23:10:35 EST 2025
Powered by FUDForum. Page generated in 0.03668 seconds
