Home » Eclipse Projects » Plugin Development Environment (PDE) » AssertionError: No editor descriptor for id org.eclipse.pde.ui.siteEditor
AssertionError: No editor descriptor for id org.eclipse.pde.ui.siteEditor [message #64981] Wed, 17 June 2009 05:52 Go to next message
I switched from Eclipse 3.4.0 to 3.4.2. When I tried to open my site.xml
for an old previously working plugin, I received an
assertionFailedException:
Any advice? Thanks.
Below I put more details:
Unable to create editor ID org.eclipse.pde.ui.siteEditor: No editor
org.eclipse.ui.PartInitException: No editor descriptor for id
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:598)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
org.eclipse.ui.internal.EditorManager.findEditor(EditorManag er.java:403)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2766)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:99)
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:99)
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:125)
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:329)
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:716)
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:443)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Re: AssertionError: No editor descriptor for id org.eclipse.pde.ui.siteEditor [message #478881 is a reply to message #64981] Fri, 07 August 2009 06:45 Go to previous message
The problem has gone when I switched Eclipse Classic SDK 3.5.0 instead of
IDE for Java developers.
Re: AssertionError: No editor descriptor for id org.eclipse.pde.ui.siteEditor [message #600401 is a reply to message #64981] Fri, 07 August 2009 06:45 Go to previous message
Previous Topic:plugin.xml substitution syntax
Next Topic:Support for other OSGi runtimes (Apache Felix, Knopflerfish, ...)
Current Time: Fri Nov 07 01:31:37 EST 2025
Powered by FUDForum. Page generated in 0.05238 seconds
