Home » Archived » M2M (model-to-model transformation) » [ATL] How to reference object of different metamodels
[ATL] How to reference object of different metamodels [message #64965] Mon, 29 October 2007 13:09 Go to next message
Originally posted by: eric.maes.thalesgroup.com
I'll try to be as clear as possible to explain my problem.
Please ask me for details if it is not enough.
I'd like to do a transformation from an input model Mi to 2 output models,
Mo1 and Mo2.
Mo1 and Mo2 have different metamodels MMo1 and MMo2.
In MMo1, an element ElementWithReference has a reference to an element
ElementToReference in MMo2.
With the following transformation, the reference is not filled!
create Mo1 : MMo1, Mo2 : MMo2 from Mi : MMi
rule MyRule {
from
element:MMi!Element
to
eWR:MMo1!ElementWithReference (
reference <- eTR
eTR:MMo2!ElementToReference
The two elements are correctly created in Mo1 and Mo2 but the Mo1
ElementWithReference reference field is empty.
In practice, when the two models are created, I can correct the
transformation by loading the resource Mo2 from Mo1 and then give the
correct value to the reference field.
Is there a way to do such things in an ATL transformation ?
Re: [ATL] How to reference object of different metamodels [message #65045 is a reply to message #64965] Mon, 29 October 2007 18:58 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Eric,
Did you check the option "Allow inter-model references" in the Advanced
tab of your launch configuration?
Freddy.
> models, Mo1 and Mo2.
> rule MyRule {
> from
> element:MMi!Element
> to
> reference <- eTR
Re: [ATL] How to reference object of different metamodels [message #65065 is a reply to message #65045] Tue, 30 October 2007 02:58 Go to previous messageGo to next message
I am launching the transformation programmatically.
The AtlLaucher launch method does not seem to offer the possibility to
specify the "Allow inter-model references" parameter.
Is there a way to specify it without using the launch configuration ?
Re: [ATL] How to reference object of different metamodels [message #65086 is a reply to message #65065] Tue, 30 October 2007 13:17 Go to previous messageGo to next message
--------------010309050807080908020500
First, I look at the adt plugin code and it seems that the "Allow
inter-model references" checkbox has no effect in the current CVS
version... but the default value is true, so normally you should'nt have
problems to make inter-model references.
If you look at the generated Mo1 file (in text format), is the reference
feature set ? Do you encounter an error when opening the file with the
ecore editor ?
William
Eric MAES a
Re: [ATL] How to reference object of different metamodels [message #65108 is a reply to message #65086] Wed, 31 October 2007 09:50 Go to previous messageGo to next message
> is the reference feature set ?
No, the reference feature is not set.
> Do you encounter an error when opening the file with the ecore editor ?
I have no problem opening Mo1 or Mo2 but in the generated files, there are
no inter-model reference (see previous answer).
Re: [ATL] How to reference object of different metamodels [message #65130 is a reply to message #65108] Wed, 31 October 2007 10:22 Go to previous messageGo to next message
--------------030503000003030405080307
I tried to make a transformation like yours and it works using the
normal launchConfiguration. The Mo1 to Mo2 is correctly set.
So perhaps the problem comes from the way you call the AtlLauncher.
Normally, the "allowInterModelReference" attribute is related to the
"checkSameModel" attribute of the ASMEMFModel class.
If you use the AtlLauncher class to launch transformation, I suppose
that you load models before : at this state you may use the
"setCheckSameModel" method to fix the attribute to "false". Look at the
class org.eclipse.m2m.atl.adt.launching.AtlRegularVM for an example.
William
Eric MAES a
Re: [ATL] How to reference object of different metamodels [message #65426 is a reply to message #65130] Fri, 02 November 2007 06:06 Go to previous message
Fixing the checkSameModel ASMEMFModel attribute to false makes the
transformation working.
Thanks for your help.
Best regards
Previous Topic:Re: [AM3] ATL transformation Ant Task
Next Topic:RCP feature/patch error installing ATL
Current Time: Sun Aug 31 09:54:04 EDT 2025
Powered by FUDForum. Page generated in 0.03612 seconds
