Home » Eclipse Projects » Nebula » Questions on Nebula Grid
| Questions on Nebula Grid [message #64956] |
Mon, 22 June 2009 08:27  |
Originally posted by: m.kasid.gmail.com
I have some queries on Grid:
1. Is it possible to change the color of cells in Row headers? How ?
2. Is it possible to change the width of Row headers or make the row header
resizable?
Mustufa
| Re: Questions on Nebula Grid [message #64991 is a reply to message #64980] |
Fri, 26 June 2009 00:58   |
Thanks.
I think grid.getColumn(0).setHeaderRenderer(customHeaderRenderer); will be
useful for having custom column headers, I want to know how can i modify the
Row headers. Also, I just want to have a facility of changing the color of
Row headers, so can i extend some class for this and provide colors that i
need?
Mustufa
"Stanislav Vodetskyi" <blutkind99@gmail.com> wrote in message
news:3f17500f00271a8c32c3f270d53966a7$1@www.eclipse.org...
> Mustufa Kasidwala wrote:
>> header resizable?
> 1. It is possible to set your own custom header renderer and draw anything
> you need in the header cell:
> There may be a possibility to use a label provider for this, but I don't
> know for sure, if it exists.
> 2. Width of row headers is definitely adjustable, but I'm not sure of the
> API to do that, sorry.
> Stanislav
| Re: Questions on Nebula Grid [message #65000 is a reply to message #64991] |
Fri, 26 June 2009 03:35   |
The method to set the width of the row header is called
Grid#setItemHeaderWidth. We currently miss the implementation to the set
the background/foreground color for the row-header but this should be
easy to implement.
So if you need this feature please file a bug and if possible create a
patch I can integrate into the code base. This way the feature will be
available to whole Grid community.
Tom
Mustufa Kasidwala schrieb:
> Thanks.
> need?
> Mustufa
>>> Hi,
>>> header resizable?
>> Regards,
>> Stanislav
| Re: Questions on Nebula Grid [message #65040 is a reply to message #65000] |
Fri, 26 June 2009 06:31   |
Thanks Tom,
I downloaded the code from CVS and i can see the method 'setItemHeaderWidth'
added in Grid.java. It wasn't visible in the binary that i was using. I may
be using an old one.
For setting background/foreground colors in row headers, i tried it out and
was able to set it by making some changes in GridItem and
DefaultRowHeaderRenderer.
How to raise a bug for this? and how can i contribute? can I send/post the
code and you can update it?
Mustufa
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:h21tnl$2kq$1@build.eclipse.org...
> easy to implement.
> Tom
>> Thanks.
>> be
>> the
>> of
>> i
>> need?
>> Thanks,
>> Mustufa
>>>> Hi,
>>>> header resizable?
>>> Hi,
>>> anything
>>> the
>>> Regards,
>>> Stanislav
| Re: Questions on Nebula Grid [message #65050 is a reply to message #65040] |
Fri, 26 June 2009 06:35   |
Please file a bug against Nebula > Grid through
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Nebula and attach a
patch which you can create within eclipse.
Please cc me on the bug and post the bug id here.
Tom
> Thanks Tom,
> Mustufa
>> easy to implement.
>> Tom
>>> Thanks.
>>> be
>>> the
>>> of
>>> i
>>> need?
>>> Thanks,
>>> Mustufa
>>>>> Hi,
>>>>> header resizable?
>>>> Hi,
>>>> anything
>>>> the
>>>> Regards,
>>>> Stanislav
| Re: Questions on Nebula Grid [message #65066 is a reply to message #65050] |
Fri, 26 June 2009 06:46   |
"attach a patch which you can create within eclipse."
can you explain what steps i need to do for this? i made changes in two
files, should i attach these two files?
Sorry if this sounds like a stupid question...
Mustufa
news:h2288o$91a$1@build.eclipse.org...
> Tom
>> Thanks Tom,
>> may
>> and
>> the
>> Thanks,
>> Mustufa
>>> Hi,
>>> easy to implement.
>>> Tom
>>>> Thanks.
>>>> be
>>>> modify
>>>> the
>>>> of
>>>> that
>>>> i
>>>> need?
>>>> Thanks,
>>>> Mustufa
>>>>>> Hi,
>>>>>> header resizable?
>>>>> Hi,
>>>>> anything
>>>>> don't
>>>>> the
>>>>> Regards,
>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65091 is a reply to message #65066] |
Fri, 26 June 2009 06:58   |
1. Right Click on the project
2. Team > Create Patch
3. Save to file system
4. Attach to bug
> Mustufa
>> Tom
>>> Thanks Tom,
>>> may
>>> and
>>> the
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> easy to implement.
>>>> Tom
>>>>> Thanks.
>>>>> be
>>>>> modify
>>>>> the
>>>>> of
>>>>> that
>>>>> i
>>>>> need?
>>>>> Thanks,
>>>>> Mustufa
>>>>>>> Hi,
>>>>>>> header resizable?
>>>>>> Hi,
>>>>>> anything
>>>>>> don't
>>>>>> the
>>>>>> Regards,
>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65113 is a reply to message #65091] |
Fri, 26 June 2009 07:17   |
Bug 281644 submitted for this and a patch is attached.
Mustufa
news:h229l8$3np$1@build.eclipse.org...
> 4. Attach to bug
>> Thanks,
>> Mustufa
>>> Hi,
>>> Tom
>>>> Thanks Tom,
>>>> may
>>>> and
>>>> the
>>>> Thanks,
>>>> Mustufa
>>>>> Hi,
>>>>> set
>>>>> easy to implement.
>>>>> Tom
>>>>>> Thanks.
>>>>>> will
>>>>>> be
>>>>>> modify
>>>>>> the
>>>>>> color
>>>>>> of
>>>>>> that
>>>>>> i
>>>>>> need?
>>>>>> Thanks,
>>>>>> Mustufa
>>>>>>>> Hi,
>>>>>>>> row
>>>>>>>> header resizable?
>>>>>>> Hi,
>>>>>>> anything
>>>>>>> don't
>>>>>>> of
>>>>>>> the
>>>>>>> Regards,
>>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65260 is a reply to message #65113] |
Fri, 03 July 2009 06:01   |
Any idea when this will be fixed? Actually we are planning to use Nebula
Grid for our project and fixing this bug is important to us.
Mustufa
"Mustufa Kasidwala" <m.kasid@gmail.com> wrote in message
news:h22ank$i9q$1@build.eclipse.org...
> Mustufa
>> 4. Attach to bug
>>> Hi,
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> Tom
>>>>> Thanks Tom,
>>>>> I
>>>>> may
>>>>> out
>>>>> and
>>>>> the
>>>>> Thanks,
>>>>> Mustufa
>>>>>> Hi,
>>>>>> set
>>>>>> easy to implement.
>>>>>> a
>>>>>> be
>>>>>> Tom
>>>>>>> Thanks.
>>>>>>> will
>>>>>>> be
>>>>>>> modify
>>>>>>> the
>>>>>>> color
>>>>>>> of
>>>>>>> that
>>>>>>> i
>>>>>>> need?
>>>>>>> Thanks,
>>>>>>> Mustufa
>>>>>>>>> Hi,
>>>>>>>>> row
>>>>>>>>> header resizable?
>>>>>>>> Hi,
>>>>>>>> anything
>>>>>>>> don't
>>>>>>>> of
>>>>>>>> the
>>>>>>>> Regards,
>>>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65454 is a reply to message #65281] |
Fri, 10 July 2009 04:42  |
Thanks Tom,
I can see this is fixed now.
Mustufa
news:h2klf5$sci$1@build.eclipse.org...
> I'll try (but can't promise) to revist it on the weekend.
> Tom
| Re: Questions on Nebula Grid [message #595372 is a reply to message #64956] |
Wed, 24 June 2009 08:21  |
> resizable?
Stanislav
| Re: Questions on Nebula Grid [message #595381 is a reply to message #64980] |
Thanks.
need?
Mustufa
>> header resizable?
> Stanislav
| Re: Questions on Nebula Grid [message #595392 is a reply to message #64991] |
easy to implement.
Tom
> Thanks.
> need?
> Mustufa
>>> Hi,
>>> header resizable?
>> Regards,
>> Stanislav
| Re: Questions on Nebula Grid [message #595409 is a reply to message #65000] |
Thanks Tom,
Mustufa
> easy to implement.
> Tom
>> Thanks.
>> be
>> the
>> of
>> i
>> need?
>> Thanks,
>> Mustufa
>>>> Hi,
>>>> header resizable?
>>> Hi,
>>> anything
>>> the
>>> Regards,
>>> Stanislav
| Re: Questions on Nebula Grid [message #595416 is a reply to message #65040] |
Tom
> Thanks Tom,
> Mustufa
>> easy to implement.
>> Tom
>>> Thanks.
>>> be
>>> the
>>> of
>>> i
>>> need?
>>> Thanks,
>>> Mustufa
>>>>> Hi,
>>>>> header resizable?
>>>> Hi,
>>>> anything
>>>> the
>>>> Regards,
>>>> Stanislav
| Re: Questions on Nebula Grid [message #595430 is a reply to message #65050] |
Mustufa
> Tom
>> Thanks Tom,
>> may
>> and
>> the
>> Thanks,
>> Mustufa
>>> Hi,
>>> easy to implement.
>>> Tom
>>>> Thanks.
>>>> be
>>>> modify
>>>> the
>>>> of
>>>> that
>>>> i
>>>> need?
>>>> Thanks,
>>>> Mustufa
>>>>>> Hi,
>>>>>> header resizable?
>>>>> Hi,
>>>>> anything
>>>>> don't
>>>>> the
>>>>> Regards,
>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595441 is a reply to message #65066] |
4. Attach to bug
> Mustufa
>> Tom
>>> Thanks Tom,
>>> may
>>> and
>>> the
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> easy to implement.
>>>> Tom
>>>>> Thanks.
>>>>> be
>>>>> modify
>>>>> the
>>>>> of
>>>>> that
>>>>> i
>>>>> need?
>>>>> Thanks,
>>>>> Mustufa
>>>>>>> Hi,
>>>>>>> header resizable?
>>>>>> Hi,
>>>>>> anything
>>>>>> don't
>>>>>> the
>>>>>> Regards,
>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595445 is a reply to message #65091] |
Mustufa
> 4. Attach to bug
>> Thanks,
>> Mustufa
>>> Hi,
>>> Tom
>>>> Thanks Tom,
>>>> may
>>>> and
>>>> the
>>>> Thanks,
>>>> Mustufa
>>>>> Hi,
>>>>> set
>>>>> easy to implement.
>>>>> Tom
>>>>>> Thanks.
>>>>>> will
>>>>>> be
>>>>>> modify
>>>>>> the
>>>>>> color
>>>>>> of
>>>>>> that
>>>>>> i
>>>>>> need?
>>>>>> Thanks,
>>>>>> Mustufa
>>>>>>>> Hi,
>>>>>>>> row
>>>>>>>> header resizable?
>>>>>>> Hi,
>>>>>>> anything
>>>>>>> don't
>>>>>>> of
>>>>>>> the
>>>>>>> Regards,
>>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595508 is a reply to message #65113] |
Mustufa
> Mustufa
>> 4. Attach to bug
>>> Hi,
>>> Thanks,
>>> Mustufa
>>>> Hi,
>>>> Tom
>>>>> Thanks Tom,
>>>>> I
>>>>> may
>>>>> out
>>>>> and
>>>>> the
>>>>> Thanks,
>>>>> Mustufa
>>>>>> Hi,
>>>>>> set
>>>>>> easy to implement.
>>>>>> a
>>>>>> be
>>>>>> Tom
>>>>>>> Thanks.
>>>>>>> will
>>>>>>> be
>>>>>>> modify
>>>>>>> the
>>>>>>> color
>>>>>>> of
>>>>>>> that
>>>>>>> i
>>>>>>> need?
>>>>>>> Thanks,
>>>>>>> Mustufa
>>>>>>>>> Hi,
>>>>>>>>> row
>>>>>>>>> header resizable?
>>>>>>>> Hi,
>>>>>>>> anything
>>>>>>>> don't
>>>>>>>> of
>>>>>>>> the
>>>>>>>> Regards,
>>>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595512 is a reply to message #65260] |
Fri, 03 July 2009 06:10  |
Tom
| Re: Questions on Nebula Grid [message #595584 is a reply to message #65281] |
Thanks Tom,
Mustufa
> Tom
Current Time: Sat Nov 08 15:59:01 EST 2025
Powered by FUDForum. Page generated in 0.06823 seconds
