| BIRT Report Object Model specs update [message #64950] | Thu, 04 August 2005 14:43  |  |
| Eclipse User  |  |  |  |  | Hi,
 The following BIRT Report Object Model specifications are updated on
 the  BIRT project website  http://eclipse.org/birt/ref.
 - ROM overview
 - ROM base elements
 - ROM design
 - ROM layout
 - ROM styles
 - ROM scripting
 The updates include some minor corrections based on community feedback.
 Inconsistencies between the specifications and the 1.0,1.0.1 feature
 descriptions have also been resolved.
 Thanks.
 --Rima Kanguri
| Re: BIRT Report Object Model specs update [message #65332 is a reply to message #65268] | Fri, 05 August 2005 17:56  |  |
| Eclipse User  |  |  |  |  | Scott,
 The chart is implemented as a Report Item extension, therefore it is not
 part of ROM specs.
 We have plans to put a document describing the chart feature on the birt
 website.
 About FreeForm, it is not supported in 1.0, I will make the corrections in
 the specs.
 --Thanks
 Rima Kanguri
 Scott Rosenbaum wrote:
 > Rima,
 > Could you please explain where the ROM Spec for charting is located.  I
 > am probably being dense, but I don't see it in the TOC or the specs.
 > Also, I see the FreeForm Element in there as since 1.0.  I thought the
 > FreeForm element was planned for 2.0?
 > Scott Rosenbaum
 > BIRT PMC
 > Rima Kanguri wrote:
 > >Hi,
 > >- ROM overview
 > >- ROM base elements
 > >- ROM design
 > >- ROM layout
 > >- ROM styles
 > >- ROM scripting
 > >Thanks.
 > >--Rima Kanguri
FUDForum. Page generated in 0.03843 seconds
