Home » Eclipse Projects » Plugin Development Environment (PDE) » How to run simple unit tests?
How to run simple unit tests? [message #64918] Mon, 15 June 2009 19:37 Go to next message
What's the simplest way to have some pure (i.e no dependencies on Eclipse
anything) unit tests run as part of a PDE build?
I've read
http://www.eclipse.org/articles/article.php?file=Article-PDE JUnitAntAutomation/index.html
(and the referenced articles), and seriously hope there is a simpler (and
faster) approach...
Re: How to run simple unit tests? [message #64941 is a reply to message #64918] Mon, 15 June 2009 20:08 Go to previous messageGo to next message
You don't really need PDE build for this. Just write an Ant script that
uses the <junit> task. If you don't have a top-level script to drive
both then I guess you could drive it from the PDE scripts..
-Ben
> Eclipse anything) unit tests run as part of a PDE build?
> I've read
> (and faster) approach...
Re: How to run simple unit tests? [message #64955 is a reply to message #64941] Mon, 15 June 2009 21:19 Go to previous messageGo to next message
That's the question: How do I hook a junit ant task (per-bundle) into the
PDE build script? Ideally, I'd want to keep the unit tests in separate
bundles (or fragments), but that may complicate things further...
Re: How to run simple unit tests? [message #65057 is a reply to message #64955] Wed, 17 June 2009 20:52 Go to previous messageGo to next message
> the PDE build script? Ideally, I'd want to keep the unit tests in
> separate bundles (or fragments), but that may complicate things further...
I'm not terribly familir with PDE build itself but I can tell you about
our setup and maybe that will help. We're not using PDE build as our
master script, which sort of sounds like what you want to do?
We are using CruiseControl to drive the whole process. It does the
following:
1. Runs a product build via PDE build for the main product
2. Runs a feature build via PDE build for a feature that holds our test
fragments
3. Runs a follow-on Ant script to execute the tests in the fragments.
We are doing the same thing you suggested; one test fragment per plug-in.
The follow-on script simply copies the compiled plugins and test
fragments into a common location, puts them all in a classpath, then
runs JUnit, calling out a top-level test suite for each plug-in.
HTH
Ben
Re: How to run simple unit tests? [message #65184 is a reply to message #65057] Mon, 22 June 2009 14:02 Go to previous message
Thanks; guess we'll have to set up something similar. Not a big deal
(though I try to minimize the amount of infrastructure we need to set up
and maintain)...
Re: How to run simple unit tests? [message #598343 is a reply to message #64918] Mon, 15 June 2009 20:08 Go to previous message
-Ben
> I've read
Re: How to run simple unit tests? [message #598349 is a reply to message #64941] Mon, 15 June 2009 21:19 Go to previous message
Re: How to run simple unit tests? [message #598394 is a reply to message #64955] Wed, 17 June 2009 20:52 Go to previous message
following:
fragments
HTH
Ben
Re: How to run simple unit tests? [message #598439 is a reply to message #65057] Mon, 22 June 2009 14:02 Go to previous message
and maintain)...
Previous Topic:Filtering a fragment on criteria other than Eclipse-PlatformFilter settings
Next Topic:PDE Build errors on xerces jar
Current Time: Wed Oct 29 23:57:23 EDT 2025
Powered by FUDForum. Page generated in 0.05895 seconds
