Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Should we use Hibernate or JDO?
[Teneo] Should we use Hibernate or JDO? [message #64909] Tue, 19 December 2006 10:44 Go to next message
We've just started looking into persisting our EMF models to a database,
and we've decided to go with Teneo for this purpose. We've already got
Hibernate set up for a different (non-EMF related) part of our application,
so if Hibernate and JDO were equally well supported, we'd probably go with
Hibernate. However, some of the documents we've seen seem to imply that
Teneo has better support for JDO, in particular with respect to lazy loading
and multiple interface inheritance.
Since we haven't started writing any Teneo-related code yet, we were
wondering if someone who were starting from scratch should favour JDO over
Hibernate or not. Is there a webpage or some other document comparing the
pros and cons of each?
- Oliver
Re: [Teneo] Should we use Hibernate or JDO? [message #64928 is a reply to message #64909] Tue, 19 December 2006 14:22 Go to previous messageGo to next message
Hi Oliver,
There is no document comparing the pros or cons.
JPOX/jdo has better support for lazy loading for single associations (and fetch groups). Both jpox
and hibernate support lazy loading of lists. Also Hibernate Teneo has much better support for
different jpa annotations (and hibernate specific annotations). Dynamic emf works with hibernate but
not with jpox.
Overall I would advice anyone familiar with jdo to stay with jpox and familiar with hibernate to use
hibernate. I myself use hibernate because I find the compile time class enhancement (which is needed
for jpox) less practical, but this is my personal way of working.
So if you are already using hibernate then I would stick to that. If you find any issues with
hibernate or missing functionality then please report it and we will do our best to adapt Teneo.
gr. Martin
> - Oliver
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Should we use Hibernate or JDO? [message #65196 is a reply to message #64928] Wed, 20 December 2006 09:46 Go to previous message
"Martin Taal" <mtaal@elver.org> wrote in message
news:em9e5t$5r0$1@utils.eclipse.org...
> familiar with hibernate to use hibernate. I myself use hibernate because I
> find the compile time class enhancement (which is needed for jpox) less
> find any issues with hibernate or missing functionality then please report
Okay, thanks Martin. We'll probably stick with Hibernate then.
- Oliver
Re: [Teneo] Should we use Hibernate or JDO? [message #597108 is a reply to message #64909] Tue, 19 December 2006 14:22 Go to previous message
Hi Oliver,
not with jpox.
gr. Martin
> - Oliver
The Netherlands
Re: [Teneo] Should we use Hibernate or JDO? [message #597226 is a reply to message #64928] Wed, 20 December 2006 09:46 Go to previous message
- Oliver
Previous Topic:validation using the org.eclipse.emf.validation.constraintProviders extension point
Next Topic:[Teneo] Setting Id generator from ecore file
Current Time: Sun Aug 31 14:36:02 EDT 2025
Powered by FUDForum. Page generated in 0.03839 seconds
