| [ATL] RC2 installation [message #64897] |
Fri, 26 October 2007 10:46  |
I installed, using update site, the last release of ATL.
To use emf4atl plugin, I made some modification considering the thread
"[ATL] Launch programmatically" - 19/08/2007. So the problem of
extraction seems to be not resolved.
Now I need to use the plugin org.eclipse.atl.engine but I cannot access
to the content of this plugin. It appears in the plugin dependencies,
but I cannot reference the packages.
Does anybody know why ? or have the same problem ?
Guillaume
| Re: [ATL] RC2 installation [message #64952 is a reply to message #64919] |
Mon, 29 October 2007 06:21  |
Originally posted by: quentin.glineur.obeo.fr
--------------070603090309050208070200
The plugin you have installed contains a compiled and packaged version
of its files. Its content is in the archive (jar). To browse it you have
two solutions :
-add the jar in the eclipse class path (then it will be displayed as a
package but you will only be able to see compiled file)
-get the source code from the cvs to build the plugin by yourself
Quentin GLINEUR
Guillaume Gauffre a
FUDForum. Page generated in 0.04322 seconds
