| memory indicator? [message #64893] |
Mon, 16 May 2005 14:39  |
Originally posted by: jeroen.lightyear.be
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Is there some kind of indicator in Eclipse which displays the amount of
RAM used by Eclipse?
I found two plugins that do this (by example Freemem,
http://junginger.biz/eclipse/), but today i read something about the
org.eclipse.core/perf/showHeapStatus option so i started wondering if
something like that was already included in Eclipse?
Thx!
Greetz,
Jeroen
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCiOj7H04wF4t7d0oRAqKsAJ9dB2/hJZXbcYRs/V8/6KqgbQdWtwCb BD4H
aez/mOObwGprpSb6vCOYcVA=
=1KKN
-----END PGP SIGNATURE-----
| Re: memory indicator? [message #66249 is a reply to message #66101] |
Wed, 18 May 2005 20:04  |
Hash: SHA1
John Arthorne wrote:
> Using Eclipse 3.1 M7, create a file called ".options" in the Eclipse
> install directory, containing the following line:
> org.eclipse.ui/perf/showHeapStatus=true
> Start Eclipse with the -debug command line argument, and you will now
> see heap usage in the status line, along with a button to force garbage
> collection. Clicking on the heap will "snapshot" the current heap
> usage, which is useful for finding leaks and observing memory growth for
> a given operation.
Ah that's indeed a cool memory indicator :) It seems to be allmost the
same as the one found at
http://dev.eclipse.org/viewcvs/index.cgi/platform-ui-home/de v.html?rev=1.38
(but with some more options for debugging)
thx!
Jeroen
<TeRanEX/>
--- e-mail: jeroen@lightyear.be - jid: teranex@jabber.org
--- blog: http://budts.be/weblog/ - cv: http://budts.be/jeroen/
--- projects: http://lightyear.be - pgp: 0x8B7B774A
_____________________________________
NO SoftwarePatents in Europe!
See an example: http://webshop.ffii.org/
iD8DBQFCi9f3H04wF4t7d0oRAg1EAJ9qibyeJjBrn/h3Bu8VB3Vvw+j43ACf XpHp
dnZ+X3rPKJy65cGGpv5uink=
=ebfq
FUDForum. Page generated in 0.09273 seconds
