Home » Language IDEs » Java Development Tools (JDT) » Stepping into JAVA API classes
Stepping into JAVA API classes [message #64838] Mon, 23 June 2003 00:46 Go to next message
Originally posted by: tony509.tampabay.rr.com
I have been using Visual Age for Java for some time and I am considering
making the switch to Eclipse. I played around with Eclipse briefly and
noticed that I cannot seem to step into Java API class code automatically
like I can in Visual Age. I get an error that the source is not found. I
sometime find it very enlightening to step thru Java API classes with Visual
Age. Is there an easy way to set this up with Eclipse? Thanks!
Tony
Re: Stepping into JAVA API classes [message #64861 is a reply to message #64838] Mon, 23 June 2003 01:12 Go to previous messageGo to next message
Visual
Hi Tony,
to find the Sources of a Java class you must install the SDK rather
then the JRE of Java. I am using Sun's SDKs here and the sources
are automatically added by eclipse. You can switch/install the
runtime/debug environment on -> workbench-> Preferrence.
Bye
Martin (Kersten)
PS: I've switched from VAJ 4.0 to 1.x of Eclipse. And I still love it;)
(Check out the additional views and rearrange it, its one of the coolest
things
I think;)
Re: Stepping into JAVA API classes [message #65273 is a reply to message #64861] Mon, 23 June 2003 13:21 Go to previous messageGo to next message
Originally posted by: Jed.Anderson.EN.aclickinthedark.com
One thing to note about this is that the rt.jar is compiled without line
number/local variable debug information (to save space), so you will not
be able to debug as well as you can in your own source (which usually is
compiled with the line number/local variable information).
jkca
> Visual
> Hi Tony,
> Bye
> Martin (Kersten)
> things
> I think;)
Re: Stepping into JAVA API classes [message #65571 is a reply to message #64861] Mon, 23 June 2003 16:11 Go to previous message
Bingo - thanks Martin. Eclipse was pointing to the JRE instead of the SDK.
I switched it and now I can walk thru JAVA API code.
Tony
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message
news:bd6250$j9r$1@rogue.oti.com...
automatically
I
> Visual
> Hi Tony,
> Bye
> Martin (Kersten)
> things
> I think;)
Previous Topic:Method line number
Next Topic:[ANN] CodePro Express End-of-Quarter Special
Current Time: Thu Jul 17 01:27:19 EDT 2025
Powered by FUDForum. Page generated in 0.05085 seconds
