Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] EEnum attributes getting reset after a query
[Teneo] EEnum attributes getting reset after a query [message #64822] |
Tue, 19 December 2006 01:09  |
Originally posted by: Stephen.Egan.csiro.au
I'm experiencing very peculiar behaviour with EEnum attributes in my =
system. I've run some tests where I create an object that has an EEnum =
as =
an attribute. When I save the object, all is well, however when I run =
another test that retrieves that object, the attribute gets reset back t=
o =
it's default! This is particularly curious as I have run a query with o=
ne =
of the query parameters being the literal for the EEnum that gets =
changed! I've included a snippet below. Any ideas as to what might be =
going wrong?
//Stephen
public void testPersistence () {
UserAccount account =3D SupportFactory.eINSTANCE.createUserAccount();
account.setAccountStatus(AccountStatus.NORMAL_LITERAL);
account.setAdmin(false);
account.setLdapUid("test");
account.setLgonlineId(666l);
account.setRole("Tester");
account.setSpecialAuthority(false);
Session session =3D InitSessionFactory.getCurrentSession();
session.beginTransaction();
RoadAuthorityDao dao =3D new RoadAuthorityDao();
RoadAuthority ra =3D PartyRoleFactory.eINSTANCE.createRoadAuthority();=
ra.setName("Mundubbera");
List<RoadAuthority> l =3D dao.findByExample(ra);
if (l.size() =3D=3D1) {
ra =3D l.get(0);
} else {
System.out.println("No RA for Mundubbera");
System.exit(-1);
account.setRoadAuthority(ra);
session.save(account);
session.getTransaction().commit();
UserAccount ua2 =3D (new UserAccountDao()).findById(account.getId());
System.out.println(account.getAccountStatus().getName()); //Still =
System.out.println(ua2.getAccountStatus().getName()); //Now =
AccountStatus.AUTH_REQ (first literal in the enum)
Re: [Teneo] EEnum attributes getting reset after a query [message #64865 is a reply to message #64844] |
Tue, 19 December 2006 03:22   |
Hi Stephen,
Thanks for the extra info. This is a mismatch between Teneo and the way EMF handles enums (it
changed a while back).
Can you enter a bugzilla for this? There will be a solution in the next release.
gr. Martin
Stephen Egan wrote:
> Update: This only happens to EEnums that have different values for
> their "name" and "literal" values. At least I have a work around....
> On Tue, 19 Dec 2006 17:09:09 +1100, Stephen Egan
> <Stephen.Egan@csiro.au> wrote:
>> EEnum as an attribute. When I save the object, all is well, however
>> when I run another test that retrieves that object, the attribute gets
>> reset back to it's default! This is particularly curious as I have
>> run a query with one of the query parameters being the literal for the
>> EEnum that gets changed! I've included a snippet below. Any ideas as
>> to what might be going wrong?
>> //Stephen
>> Session session = InitSessionFactory.getCurrentSession();
>> RoadAuthorityDao dao = new RoadAuthorityDao();
>> RoadAuthority ra =
>> List<RoadAuthority> l = dao.findByExample(ra);
>> if (l.size() ==1) {
>> ra = l.get(0);
>> } else {
>> System.exit(-1);
>> UserAccount ua2 = (new
>> //Still AccountStatus.NORMAL_LITERAL
> --Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] EEnum attributes getting reset after a query [message #65079 is a reply to message #64865] |
Tue, 19 December 2006 21:10  |
Thanks very much Martin,
I've submitted bug number 168623
//Stephen
On Tue, 19 Dec 2006 19:22:20 +1100, Martin Taal <mtaal@elver.org> wrote:=
> Hi Stephen,
> Thanks for the extra info. This is a mismatch between Teneo and the wa=
y =
> EMF handles enums (it changed a while back).
> Can you enter a bugzilla for this? There will be a solution in the nex=
t =
> release.
> gr. Martin
> Stephen Egan wrote:
>> Update: This only happens to EEnums that have different values for =
>> their "name" and "literal" values. At least I have a work around....=
>> On Tue, 19 Dec 2006 17:09:09 +1100, Stephen Egan =
>>> Hi,
>>> I'm experiencing very peculiar behaviour with EEnum attributes in my=
>>> system. I've run some tests where I create an object that has an =
>>> EEnum as an attribute. When I save the object, all is well, however=
>>> when I run another test that retrieves that object, the attribute ge=
ts =
>>> reset back to it's default! This is particularly curious as I have =
>>> run a query with one of the query parameters being the literal for t=
he =
>>> EEnum that gets changed! I've included a snippet below. Any ideas =
as =
>>> //Stephen
>>> UserAccount account =3D =
>>> RoadAuthority ra =3D =
>>> ra =3D l.get(0);
>>> } else {
>>> System.exit(-1);
>>> UserAccount ua2 =3D (new =
>>> System.out.println(account.getAccountStatus().getName()); =
>>> System.out.println(ua2.getAccountStatus().getName()); //Now=
>> --Using Opera's revolutionary e-mail client: =
Re: [Teneo] EEnum attributes getting reset after a query [message #597077 is a reply to message #64822] |
Tue, 19 December 2006 01:32  |
Update: This only happens to EEnums that have different values for thei=
r =
On Tue, 19 Dec 2006 17:09:09 +1100, Stephen Egan <Stephen.Egan@csiro.au=
wrote:
> system. I've run some tests where I create an object that has an EEnu=
m =
> as an attribute. When I save the object, all is well, however when I =
> run another test that retrieves that object, the attribute gets reset =
> back to it's default! This is particularly curious as I have run a =
> query with one of the query parameters being the literal for the EEnum=
> that gets changed! I've included a snippet below. Any ideas as to wh=
at =
> //Stephen
> UserAccount account =3D SupportFactory.eINSTANCE.createUserAccount()=
> RoadAuthority ra =3D PartyRoleFactory.eINSTANCE.createRoadAuthority(=
> ra =3D l.get(0);
> } else {
> System.exit(-1);
> UserAccount ua2 =3D (new UserAccountDao()).findById(account.getId())=
Re: [Teneo] EEnum attributes getting reset after a query [message #597082 is a reply to message #64844] |
Hi Stephen,
gr. Martin
>> //Stephen
>> RoadAuthority ra =
>> if (l.size() ==1) {
>> ra = l.get(0);
>> } else {
>> System.exit(-1);
The Netherlands
Re: [Teneo] EEnum attributes getting reset after a query [message #597175 is a reply to message #64865] |
//Stephen
> Hi Stephen,
y =
t =
> release.
> gr. Martin
>>> Hi,
ts =
he =
as =
>>> //Stephen
>>> ra =3D l.get(0);
>>> } else {
>>> System.exit(-1);
Current Time: Mon Jul 21 20:54:23 EDT 2025
Powered by FUDForum. Page generated in 0.03779 seconds
