Mylyn Query Skips Tasks [message #64777] |
Tue, 03 February 2009 09:35  |
I'm having a problem with mylyn queries not finding tasks. I'm using Trac
0.11.2.1 with the xml-rpc plugin. When I create a ticket through the normal
web interface mylyn has no problems pulling the ticket in. But when I send
an email to trac, mylyn never sees the ticket. I have verified that the
ticket does go into Trac just fine, and have also verfied the output of the
xml-rpc function. Also, when I use the find function on the task list and
hit the "Search repository for key or summary" it does find the ticket and
opens it just fine.
Has anyone seen this before? This used to work just fine for me and I'm not
sure what has changed.
Thanks!
-jason
Re: Mylyn Query Skips Tasks [message #595995 is a reply to message #64777] |
Wed, 04 February 2009 11:42  |
I think I found a work around to this. Previously I had no other options in
the query selected other than just the owner field. I selected all options
in the status list and now the query works just fine.
Just thought I'd pass that along incase someone else ran into this.
-jason
Re: Mylyn Query Skips Tasks [message #596019 is a reply to message #64826] |
Wed, 04 February 2009 21:27  |
On a slightly different note, is there a maximum number of Tasks that you
can get from a query? My "get everything" query only sees the first 100
tasks, though other queries see tasks with bigger ticket numbers.
I'm using Mylyn 3.0.4 with Trac 0.11.1 and the XML-RPC plugin, if that
matters.
Re: Mylyn Query Skips Tasks [message #596025 is a reply to message #64890] |
Wed, 04 February 2009 21:33  |
> matters.
Please file a bug for that. The Trac connector may not set an explicit limit
when querying the repository which causes queries to be limited to 100
results by default:
http://trac-hacks.org/ticket/3509
Steffen
Re: Mylyn Query Skips Tasks [message #596031 is a reply to message #64911] |
Wed, 04 February 2009 22:57  |
Wow, that was fast!
But now that you've pointed out the problem, I think it can also be
considered a configuration issue.
There's a setting in the trac.ini configuration:
[query]
items_per_page = 100
Upping that number to 1000 takes care of the issue.
I can still open the bug if you'd like but the workaround is really simple.
Thanks again!
Re: Mylyn Query Skips Tasks [message #596081 is a reply to message #65009] |
Fri, 06 February 2009 08:48  |
Has anyone filed this bug? If not I will.
The tweak worked for me, but I have other users that use Trac through the
web so I can't have their query defaults set too high.
Thanks for the help!
FUDForum. Page generated in 0.05192 seconds
