| Re: How to add combo box and textbox in a figure in GEF. [message #64788 is a reply to message #64742] |
Thu, 13 February 2003 09:12  |
The easy answer is not to. For example, in the PropertySheet, which uses a
Table control, you cannot place Combos and Textboxes in every cell. Instead,
you just display the current value (perhaps use Lable Figure), and then you
use a CellEditor only when the user is editing the value.
Besides, depending on the number of items in your diagram, you probably
don't want to overwhelm the user with so many combo boxes.
In the logic example, double click on a Label and see how it works.
"Dinesh Varadharajan" <dvaradharajan@selectica.com> wrote in message
news:b2fttm$jg2$1@rogue.oti.com...
> I need to add ComboBox and Textbox into a figure but those are swt
> components. How I can add these.
> Dinesh
FUDForum. Page generated in 0.03146 seconds
