| Dragging above or left from (0,0) moves figure. [message #64717] |
Thu, 13 February 2003 06:04  |
Originally posted by: g.wagenknecht.intershop.de
Hi!
How to avoid that? I know it was a problem a long time ago. My editor worked
already without that issue but now it is back again and I can't explain why.
MyEditor#configureGraphicalViewer()
super.configureGraphicalViewer();
ScrollingGraphicalViewer viewer = (ScrollingGraphicalViewer)
getGraphicalViewer();
viewer.setRootEditPart(new ScalableFreeformRootEditPart());
viewer.setEditPartFactory(PipelineEditorEditPartFactory.getE ditPartFactory()
MyEditor#initializeGraphicalViewer()
getGraphicalViewer().setContents(getMyRootModelObject());
MyRootModelObjectEditPart#createFigure()
LayeredPane pane = new FreeformLayeredPane();
VPMPreferences.getPreferenceStore().addPropertyChangeListene r(preferencesLis
tener);
GridFigure gridFigure = new GridFigure();
initializeGridFigure(gridFigure);
* GridFigure is a FreeformLayer with a GridLayout
* GridLayout is a subclass of AbstractLayout
* Could it be possible that the layout
* must be a subclass for "FreeformLayout"?
FreeformLayer textLayer = new FreeformLayer();
textLayer.setLayoutManager(new DelegatingLayout());
textLayer.setBorder(new MarginBorder(5));
textLayer.setOpaque(false);
pane.add(gridFigure, GRID_LAYER, 0);
pane.add(textLayer, TEXT_LAYER, 1);
return pane;
MyRootModelObjectEditPart#getContentPane()
return ((LayeredPane)getFigure().getLayer(GRID_LAYER);
MyRootModelObjectEditPart#registerVisuals()
//super.registerVisuals();
getViewer().getVisualPartMap().put(getContentPane(), this);
| Re: Dragging above or left from (0,0) moves figure. [message #64811 is a reply to message #64717] |
Thu, 13 February 2003 09:12  |
You will have to post your code for you contents editpart, root editpart,
and any figures used by them.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:b2fsjn$i9v$1@rogue.oti.com...
> Hi!
worked
why.
> tener);
> return pane;
FUDForum. Page generated in 0.39854 seconds
