| [Teneo] GMF -mindmap example problem [message #64704] |
Mon, 18 December 2006 11:05  |
I have tried to repeat a tutorial which is described at
http://www.elver.org/hibernate/gmftutorial/tutorial1.html . And have got
"java.lang.IllegalStateException: Cannot modify resource set without a write
transaction" from the action "Initialize mindmap_diagram diagram file"
Any ideas?
Kirill
Exception:
transaction
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:295)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:257)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessResourceNotification(TransactionChangeRecorder.java:22 7)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:193)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:230)
org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch (NotificationImpl.java:1029)
org.eclipse.emf.teneo.resource.StoreResource.addToContent(St oreResource.java:284)
org.eclipse.emf.teneo.resource.StoreResource.load(StoreResou rce.java:269)
org.eclipse.emf.teneo.resource.StoreResource.getContents(Sto reResource.java:398)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.s etTarget(TransactionChangeRecorder.java:128)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.didAdd(BasicNotifierImpl.java:71)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:620)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 00)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.add(BasicNotifierImpl.java:119)
org.eclipse.emf.ecore.change.util.ChangeRecorder.addAdapter( ChangeRecorder.java:697)
org.eclipse.emf.ecore.change.util.ChangeRecorder.notifyChang ed(ChangeRecorder.java:352)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:173)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.dispatc hNotification(NotifyingListImpl.java:260)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:292)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createRe source(ResourceSetImpl.java:411)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCr eateResource(ResourceSetImpl.java:233)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:384)
mindmap.diagram.part.MindmapInitDiagramFileAction.run(Mindma pInitDiagramFileAction.java:117)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
MindmapInitDiagramFileAction.java :
111 TransactionalEditingDomain editingDomain =
GMFEditingDomainFactory.INSTANCE
112 .createEditingDomain();
113 ResourceSet resourceSet = editingDomain.getResourceSet();
114
115 EObject diagramRoot = null;
116 try {
117 Resource resource = resourceSet.getResource(URI
118 .createPlatformResourceURI(mySelectedModelFile
119 .getFullPath().toString(), true), true);
120 diagramRoot = (EObject) resource.getContents().get(0);
Configuration:
emf-sdo-xsd-SDK-M200611161441.zip
emft-ocl-SDK-1.0.0.zip
emft-query-SDK-1.0.1.zip
emft-teneo-SDK-I200611290220.zip
emft-transaction-SDK-1.0.1.zip
emft-validation-SDK-1.0.1.zip
GEF-SDK-3.2.1.zip
GMF-sdk-experimental-N20061115.zip
GMF-sdk-N20061115.zip
hibernate-3.2.1.ga.zip
uml2-SDK-2.0.2.zip
| Re: [Teneo] GMF -mindmap example problem [message #64776 is a reply to message #64704] |
Mon, 18 December 2006 16:01  |
Yes this is an issue because the HibernateResource sends out notifications when loading content from
the database. This can be disabled by passing the DISABLE_NOTIFY option when loading a resource.
Which is not directly possible in the way the resource is used here (the load action is called
implicitly). I have entered a bugzilla for this and will look at this issue later.
As an intermediate workaround you can replace the part in the try catch (line 117 in
MindmapInitDiagramFileAction.java) with the following code:
Resource res = new HibernateResource(URI
.getFullPath().toString()));
HashMap options = new HashMap();
options.put(XMLResource.OPTION_DISABLE_NOTIFY, "true");
res.load(options);
resourceSet.getResources().add(res);
// Resource resource = resourceSet.getResource(URI
// .createPlatformResourceURI(mySelectedModelFile
// .getFullPath().toString()), true);
diagramRoot = (EObject) res.getContents().get(0);
Note that the old call to resourceSet.getResource is commented out.
gr. Martin
Kirill A. balod wrote:
> Hello,
> Any ideas?
> Thanks
> Kirill
> Exception:
> transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 114
> 116 try {
> Configuration:
> GEF-SDK-3.2.1.zip
> uml2-SDK-2.0.2.zip
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] GMF -mindmap example problem [message #597048 is a reply to message #64704] |
res.load(options);
gr. Martin
> Hello,
> Any ideas?
> Thanks
> Kirill
> Exception:
> transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 114
> 116 try {
> Configuration:
> GEF-SDK-3.2.1.zip
> uml2-SDK-2.0.2.zip
The Netherlands
FUDForum. Page generated in 0.03706 seconds
