Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported?
teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #64657] Sat, 16 December 2006 12:15 Go to next message
Hi Martin,
I just gave the combination of eclipse 3.3M4 with EMF2.3 a try and I like it -
particularly the generics based EList removes a lot of the downcasting pain. I
tried to compile everything with teneo from its CVS head but it failed -
fortunately not with many problems though.
Do you have already planned to support EMF2.3 somewhere in the near future?
Andre
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #64680 is a reply to message #64657] Mon, 18 December 2006 04:56 Go to previous messageGo to next message
Hi Andre,
I need to check the changes I need to do to build/test Teneo with 2.3. If the incompatabilities are
only in certain parts (for example featuremap support) then I will support 2.3 in the near future (I
hope to do a release next week).
If there are more differences which make Teneo not-compatible with 2.2 then I might wait a bit
longer (depends on the release schedule for 2.3).
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> like it - particularly the generics based EList removes a lot of the
> downcasting pain. I tried to compile everything with teneo from its CVS
> head but it failed - fortunately not with many problems though.
> Thanks
> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #64944 is a reply to message #64680] Tue, 19 December 2006 14:58 Go to previous messageGo to next message
That's fine, Martin. The benefit is not overly big
Andre
Martin Taal wrote:
> Hi Andre,
> If the incompatabilities are only in certain parts (for example
> featuremap support) then I will support 2.3 in the near future (I hope
> then I might wait a bit longer (depends on the release schedule for 2.3).
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> CVS head but it failed - fortunately not with many problems though.
>> future?
>> Thanks
>> Andre
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #69638 is a reply to message #64680] Tue, 30 January 2007 19:19 Go to previous messageGo to next message
Originally posted by: salvatore.it.ibm.com
Hi Martin, do you have any news on this subject?
I am trying to use the latest TENEO's build with EMF 2.3. I encountered a
problem when saving an EObject that contains an enumeration. Here follows
the stack trace:
java.lang.ClassCastException: com.ibm.casrome.hyper.odmdl.Type
org.eclipse.emf.teneo.hibernate.mapping.ENumUserType.equals( ENumUserType.java:98)
at org.hibernate.type.CustomType.isEqual(CustomType.java:86)
at org.hibernate.type.CustomType.isEqual(CustomType.java:91)
at org.hibernate.type.AbstractType.isSame(AbstractType.java:104 )
at org.hibernate.type.AbstractType.isDirty(AbstractType.java:70 )
at org.hibernate.type.CustomType.isDirty(CustomType.java:235)
at org.hibernate.type.TypeFactory.findDirty(TypeFactory.java:56 3)
org.hibernate.persister.entity.AbstractEntityPersister.findD irty(AbstractEntityPersister.java:3117)
org.hibernate.event.def.DefaultFlushEntityEventListener.dirt yCheck(DefaultFlushEntityEventListener.java:472)
org.hibernate.event.def.DefaultFlushEntityEventListener.isUp dateNecessary(DefaultFlushEntityEventListener.java:197)
org.hibernate.event.def.DefaultFlushEntityEventListener.onFl ushEntity(DefaultFlushEntityEventListener.java:120)
org.hibernate.event.def.AbstractFlushingEventListener.flushE ntities(AbstractFlushingEventListener.java:196)
org.hibernate.event.def.AbstractFlushingEventListener.flushE verythingToExecutions(AbstractFlushingEventListener.java:76)
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:26)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java :338)
org.hibernate.transaction.JDBCTransaction.commit(JDBCTransac tion.java:106)
com.ibm.casrome.hyper.odmdl.persistence.teneo.TeneoPersisten ceTest.testCreate2(TeneoPersistenceTest.java:77)
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Dino
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #69658 is a reply to message #69638] Wed, 31 January 2007 03:43 Go to previous messageGo to next message
Hi Dino,
I'll add support for emf 2.3 in the coming weeks. I have just added a bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=172278
You can add yourselve to the cc to be kept informed upfront. I'll also post here when it is released.
gr. Martin
> a problem when saving an EObject that contains an enumeration. Here
> follows the stack trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Dino
The Netherlands
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #69678 is a reply to message #69658] Wed, 31 January 2007 05:51 Go to previous message
Great! Thanks
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #596998 is a reply to message #64657] Mon, 18 December 2006 04:56 Go to previous message
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Thanks
> Andre
The Netherlands
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #597116 is a reply to message #64680] Tue, 19 December 2006 14:58 Go to previous message
Andre
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> future?
>> Thanks
>> Andre
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #601835 is a reply to message #64680] Tue, 30 January 2007 19:19 Go to previous message
the stack trace:
Dino
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #601844 is a reply to message #69638] Wed, 31 January 2007 03:43 Go to previous message
Hi Dino,
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Dino
The Netherlands
Re: teneo - when will EMF2.3 (i.e., the Java 5.0 features) be supported? [message #601858 is a reply to message #69658] Wed, 31 January 2007 05:51 Go to previous message
Great! Thanks
Previous Topic:Teneo: More than one class with same name
Next Topic:Generating EMF model with virtual attributes
Current Time: Sat Nov 22 23:32:02 EST 2025
Powered by FUDForum. Page generated in 0.05902 seconds
