Home » Language IDEs » ServerTools (WTP) » Resource Links/Context Variables
Resource Links/Context Variables [message #64568] Tue, 11 January 2005 11:03 Go to next message
Originally posted by: james.kilbride.gd-ais.com
How do you get the context.xml file to be read by the Server created under
the web tools IDE(assuming Tomcat 5.5)? I've got some resource links I
want it to read in and it doesn't seem to be doing so.
Re: Resource Links/Context Variables [message #64638 is a reply to message #64568] Tue, 11 January 2005 12:44 Go to previous messageGo to next message
Originally posted by: jrduncans.stephenduncanjr.com
> under the web tools IDE(assuming Tomcat 5.5)? I've got some resource
> links I want it to read in and it doesn't seem to be doing so.
I was just about to ask the same thing, though for Tomcat 4.1...
Re: Resource Links/Context Variables [message #69249 is a reply to message #64638] Thu, 27 January 2005 13:09 Go to previous message
This has been addressed, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82812
For Tomcat 4.1.x and up, a META-INF/context.xml, will be incorporated in to
the server.xml when the server configuration is published to the Tomcat
server. Note that this means it won't be present in server.xml's found
under the "Servers" project. If you change a context.xml file, you will
need to trick the server into republishing the configuration if it thinks it
is synchronized. Removing and re-adding a project on the server will do the
trick.
Larry
"Stephen Duncan Jr" <jrduncans@stephenduncanjr.com> wrote in message
news:cs1382$ndb$1@www.eclipse.org...
Previous Topic:ClassSchedule Tutorial missing target in form
Next Topic:Compiler errors in projets just checked from WTP
Current Time: Sun Aug 31 17:14:13 EDT 2025
Powered by FUDForum. Page generated in 0.02900 seconds
