Re: How to query only one bug from eclipse's bugzilla [message #64593 is a reply to message #64571] |
Wed, 21 January 2009 19:16  |
Hi Eric Rizzo napsal(a):
> While it's not a query, you can easily open a specific bug:
> In the Task Repositories, right-click on a repository and select Open
> Repository Task... Then you can enter the bug number and it will open in
> the Mylyn task editor.
> The default keyboard shortcut is Ctrl+Alt+Shift+F12
great, that was only one thing which i lacked, thank you very much
Re: How to query only one bug from eclipse's bugzilla [message #595898 is a reply to message #64547] |
Wed, 21 January 2009 19:04  |
On 1/21/2009 2:47 PM, sNop wrote:
> I want to ask you how can I create query only for one bug e.g.:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=161760
> Thank you for any advices and suggestions
The "experimental" Mylyn UI feature also provides quick access to this
in the "Task Trim" widget that it provides.
Hope this helps,
Eric
Re: How to query only one bug from eclipse's bugzilla [message #595904 is a reply to message #64571] |
FUDForum. Page generated in 0.03037 seconds
