Home » Eclipse Projects » Nebula » [CDateTime] multiple selection / date range
[CDateTime] multiple selection / date range [message #64530] Tue, 16 June 2009 06:15 Go to next message
I'm using CDT.SIMPLE to have the calendar only. Is there any way to
mark/select/color multiple dates in the calendar ?
Are there any other SWT calendars, which can do that ?
Re: [CDateTime] multiple selection / date range [message #64622 is a reply to message #64530] Thu, 18 June 2009 21:47 Go to previous message
This is not currently implemented, though you could file a bug if you
want to get it going.
cheers
Stefan Pham wrote:
> Thanks
Re: [CDateTime] multiple selection / date range [message #595179 is a reply to message #64530] Thu, 18 June 2009 21:47 Go to previous message
cheers
Stefan Pham wrote:
> Thanks
Previous Topic:Freeze column in Grid
Next Topic:Freeze column in Grid
Current Time: Fri Nov 07 02:35:09 EST 2025
Powered by FUDForum. Page generated in 0.03516 seconds
