Home » Eclipse Projects » Nebula » Column Group and Header Control Conflict when Drawing
Column Group and Header Control Conflict when Drawing [message #64507] Mon, 15 June 2009 14:34 Go to next message
Originally posted by: dan.healy.eds.com
I am trying to use a couple of the newer features in the Grid control --
both column grouping and column headers. When I use them both together, the
column header text and the control are painted too high on the screen. The
simplest way to replicate this is to use GridSnippt4 as a base and to add a
header control to one of the grouped columns. I've attached a screen
capture of the error. I've put the modified snippet and the image into
bugzilla at https://bugs.eclipse.org/bugs/show_bug.cgi?id=280207
Dan Healy
Re: Column Group and Header Control Conflict when Drawing [message #64691 is a reply to message #64507] Fri, 19 June 2009 03:06 Go to previous message
I've seen your bug report but didn't had time to take look.
Tom
> Dan Healy
Re: Column Group and Header Control Conflict when Drawing [message #595206 is a reply to message #64507] Fri, 19 June 2009 03:06 Go to previous message
Tom
> Dan Healy
Previous Topic:Freeze column in Grid
Next Topic:Row-wise table editing
Current Time: Fri Nov 14 18:23:35 EST 2025
Powered by FUDForum. Page generated in 0.04051 seconds
