Home » Archived » Test and Performance Tools Platform (TPTP) » How do i get AGR to record on the workbench I want.
How do i get AGR to record on the workbench I want. [message #64480] Wed, 05 April 2006 13:50 Go to next message
Originally posted by: louis.maccubbin.graniteedge.net
I'm new to Eclipse and TPTP, so my terminology may not be correct.
I'm can't seem to get the "AGR" to record on my application (workbench).
I'm using TPTP 4.1.0.1. I've followed the TPTP user guide and I'm
able to record and play back actions as described in the User guide.
But now I want to record and play back actions in my own app.
I've unchecked the "Use current workbench as context" and that doesn't work.
I've also tried defining the context as described in section 2.2.1 of
the uses guide. this causes java error: "Ordinal Not Found. the ordinal
43 could not be located in the dynamic link library hcdco.dll."
Has anyone else experienced these same difficulties, how did you make
it work?
Louis
Re: How do i get AGR to record on the workbench I want. [message #64527 is a reply to message #64480] Wed, 05 April 2006 22:02 Go to previous messageGo to next message
Have u install AGR?
Automated GUI Recording
TPTP's Automated GUI Recorder allows users to record and playback user
interactions under the Eclipse platform. The purpose of the feature is to
allow users to automate functional test cases for applications developed
under the Eclipse environment. Please refer to the user guide for more
details. This item is not required as part of TPTP's platform.
Download the feature here.
And maybe u should use eclipse -clean to start eclipse after u install
all required plug-ins
"Louis MacCubbin" <louis.maccubbin@graniteedge.net>
??????:e11052$vn1$1@utils.eclipse.org...
> Hello,
> I'm using TPTP 4.1.0.1. I've followed the TPTP user guide and I'm able to
> record and play back actions as described in the User guide. But now I
> work.
> I've also tried defining the context as described in section 2.2.1 of the
> uses guide. this causes java error: "Ordinal Not Found. the ordinal 43
> Has anyone else experienced these same difficulties, how did you make it
> work?
> Thanks
> Louis
Re: How do i get AGR to record on the workbench I want. [message #64833 is a reply to message #64527] Thu, 06 April 2006 12:10 Go to previous messageGo to next message
Hi Simoom,
Yes i've installed AGR. My problem here is that I can't get AGR to
record on my application. When I follow the example given in the user
guide I can record and playback fine, but this is just for an empty
workspace, not my app.
How do i get the perspective to focus on my application?
Louis
simoom wrote:
> Have u install AGR?
>> Hello,
>> work.
>> work?
>> Thanks
>> Louis
Re: How do i get AGR to record on the workbench I want. [message #65882 is a reply to message #64833] Tue, 11 April 2006 16:12 Go to previous message
You have to have AGR installed in the workbench that you expect to use as
your context. You can't have workbench A using AGR to tell it to record a
test case in workbench B. You can only playback the test suite in A using
B.
"Louis MacCubbin" <louis.maccubbin@graniteedge.net> wrote in message
news:44353D5D.2010709@graniteedge.net...
> Hi Simoom,
> Thanks
> Louis
> simoom wrote:
> > Have u install AGR?
user
to
install
> >> Hello,
(workbench).
to
> >> work.
the
it
> >> work?
> >> Thanks
> >> Louis
Previous Topic:RAC vs IAC
Next Topic:AGR: Minimal feature set?
Current Time: Sat Aug 23 02:30:05 EDT 2025
Powered by FUDForum. Page generated in 0.24452 seconds
