| How do i get AGR to record on the workbench I want. [message #64480] |
Wed, 05 April 2006 13:50  |
Originally posted by: louis.maccubbin.graniteedge.net
I'm new to Eclipse and TPTP, so my terminology may not be correct.
I'm can't seem to get the "AGR" to record on my application (workbench).
I'm using TPTP 4.1.0.1. I've followed the TPTP user guide and I'm
able to record and play back actions as described in the User guide.
But now I want to record and play back actions in my own app.
I've unchecked the "Use current workbench as context" and that doesn't work.
I've also tried defining the context as described in section 2.2.1 of
the uses guide. this causes java error: "Ordinal Not Found. the ordinal
43 could not be located in the dynamic link library hcdco.dll."
Has anyone else experienced these same difficulties, how did you make
it work?
Louis
| Re: How do i get AGR to record on the workbench I want. [message #65882 is a reply to message #64833] |
Tue, 11 April 2006 16:12  |
You have to have AGR installed in the workbench that you expect to use as
your context. You can't have workbench A using AGR to tell it to record a
test case in workbench B. You can only playback the test suite in A using
B.
"Louis MacCubbin" <louis.maccubbin@graniteedge.net> wrote in message
news:44353D5D.2010709@graniteedge.net...
> Hi Simoom,
> Yes i've installed AGR. My problem here is that I can't get AGR to
> record on my application. When I follow the example given in the user
> guide I can record and playback fine, but this is just for an empty
> workspace, not my app.
> How do i get the perspective to focus on my application?
> Thanks
> Louis
> simoom wrote:
> > Have u install AGR?
> > Automated GUI Recording
> > TPTP's Automated GUI Recorder allows users to record and playback
user
> > interactions under the Eclipse platform. The purpose of the feature is
to
> > allow users to automate functional test cases for applications developed
> > under the Eclipse environment. Please refer to the user guide for more
> > details. This item is not required as part of TPTP's platform.
> > Download the feature here.
> > And maybe u should use eclipse -clean to start eclipse after u
install
> > all required plug-ins
> > ??????:e11052$vn1$1@utils.eclipse.org...
> >> Hello,
(workbench).
> >> I'm using TPTP 4.1.0.1. I've followed the TPTP user guide and I'm able
to
> >> record and play back actions as described in the User guide. But now I
> >> work.
the
> >> uses guide. this causes java error: "Ordinal Not Found. the ordinal 43
it
> >> work?
> >> Thanks
> >> Louis
FUDForum. Page generated in 0.03734 seconds
