Home » Eclipse Projects » Plugin Development Environment (PDE) » Deleting a launch configuration doesnt clean up the file system data
Deleting a launch configuration doesnt clean up the file system data [message #64466] Wed, 10 June 2009 04:25 Go to next message
In the eclipse PDE, perform the following steps
1) Click on Run -> Run Configurations
2) Create a new Eclipse Application Launcher
3) A new Launch Configuration is created with the name "New Configuration"
4) Use the default values and launch the configuration
5) A new eclipse application launches successfully
6) Close the application and delete the launch configuration "New
Configuration" by right clicking on the configuration and select delete.
7) The launch configuration gets deleted from "Run Configurations" window.
But the associated file system data does not get cleaned up.
Is this behavior of eclipse intentional or is this a defect?
Awaiting Response. Thanks in Advance.
Re: Deleting a launch configuration doesnt clean up the file system data [message #64513 is a reply to message #64466] Wed, 10 June 2009 05:19 Go to previous messageGo to next message
> window. But the associated file system data does not get cleaned up.
There can be multiple launch configurations associated with one
runtime workspace. So isn't the current behaviour the expected one?
- Prakash
http://blog.eclipse-tips.com
Re: Deleting a launch configuration doesnt clean up the file system data [message #64653 is a reply to message #64513] Thu, 11 June 2009 02:27 Go to previous message
Prakash,
Its true that there can be multiple launch configuration for a single
workspace. But the issue here is when you delete a launch configuration in
the UI (PDE), then the associated configuration data in the file system is
not getting cleaned up.
Re: Deleting a launch configuration doesnt clean up the file system data [message #598212 is a reply to message #64466] Wed, 10 June 2009 05:19 Go to previous message
- Prakash
Re: Deleting a launch configuration doesnt clean up the file system data [message #598258 is a reply to message #64513] Thu, 11 June 2009 02:27 Go to previous message
Prakash,
Previous Topic:Target Pltatform Based On Update Site
Next Topic:Target Pltatform Based On Update Site
Current Time: Tue Jul 22 01:36:10 EDT 2025
Powered by FUDForum. Page generated in 0.24853 seconds
