!!HELP!! Errors in CDT after loading source in plugin projects [message #64430] |
Thu, 13 March 2003 10:47 |
Originally posted by: derek.p.gilbert.intel.com
I could not access the CDT CVS from behing our corporate firewall. So, I
download the CDT plugins. I then downloaded the source zip from the stable
builds (1.0.1 F1 - source). I abstracted them both to the same directory
so that the source zips were extracted into thier correct plugin
directory. I then imported these plugins into eclipse which then created
plugin projects for the entire CDT and included thier source. However,
after the import eclipse does a rebuild of all projects. I am gettings
about 6 errors and 50 warnings in the tasks list. When I run a "Run-time
Workbench" with these plugins everything seems to work fine and I can
debug through the CDT. Should I be getting errors though when I build. I
want to extend the CDT but I won't be able to build. How do I import the
CDT correctly into eclipse? I tried to follow the "2.1.1 Using Features to
Build the CDT Distribution" but I didn't see any feature in
org.eclipse.cdt_1.0.1. Did I do this correctly by abstracting the source
files into the plugins and importing them. That should work. Below I
copied all the Warnings and Errors from Eclipse tasks. The errors are only
occuring in:
org.eclipse.cdt.core.parser - BinaryContainerAdapter.java
org.eclipse.cdt.core.parser - BinaryFileAdapter.java
org.eclipse.cdt.ui.editor - CEditor.java
Thanks here are the errors
Kind Status Priority Description Resource In Folder Location
Error Class must implement the inherited abstract method
IResource.getRawLocation() BinaryFileAdapter.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/co re/model/parser line
24
IResource.accept(IResourceProxyVisitor,
int) BinaryFileAdapter.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/co re/model/parser line
24
IResource.getRawLocation() BinaryContainerAdapter.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/co re/model/parser line
25
int) BinaryContainerAdapter.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/co re/model/parser line
25
Error Cannot reduce the visibility of the inherited method from
TextEditor CEditor.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
1564
Warning Unknown attribute
'actionID'. plugin.xml org.eclipse.cdt.debug.ui line 647
Warning Referenced class 'org.eclipse.cdt.debug.core.ICBreakpoint' in
attribute 'objectClass' cannot be
found. plugin.xml org.eclipse.cdt.debug.ui line 343
Warning The assignment to variable token has no
effect MIInferior.java org.eclipse.cdt.debug.mi.core/src-cdtmicore/org/eclipse/cdt/ debug/mi/core line
73
Warning The static field MGridData.BEGINNING should be accessed in a
static
way DialogField.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/wiz ards/dialogfields line
36
Warning The static field CCodeReader.EOF should be accessed in a static
way CPairMatcher.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/tex t line
178
157
Warning The static field ISourceViewer.CONTENTASSIST_PROPOSALS should be
way EditTemplateDialog.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/pre ferences line
444
Warning The static field GridData.BEGINNING should be accessed in a
static
way AbstractElementListSelectionDialog.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/dia logs line
105
Warning The static field ITextOperationTarget.SELECT_ALL should be
440
Warning The static field GridData.FILL should be accessed in a static
104
Warning The static field ITextOperationTarget.PASTE should be accessed
in a static
436
90
Warning The static field ITextOperationTarget.COPY should be accessed in
a static
432
89
Warning The static method forName(String) from the type Class should be
way ErrorParserManager.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/core line
133
Warning The static field ITextOperationTarget.CUT should be accessed in
a static
428
Warning The static field ITextOperationTarget.UNDO should be accessed in
a static
424
Warning The static field IContentAssistant.CONTEXT_INFO_ABOVE should be
114
Warning The static field IContentAssistant.PROPOSAL_OVERLAY should be
113
static
way SelectionList.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/dia logs line
73
72
Warning The static method translation_unit() from the type CPPParser
way CStructurizer.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/pa rser line
39
Warning The static field CPairMatcher.RIGHT should be accessed in a
static
way BracketPainter.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
91
Warning The static method setParserCallback(ParserCallback) from the
type CPPParser should be accessed in a static
37
Warning The static method ReInit(InputStream) from the type CPPParser
35
Warning The static field PE.Attribute.PE_TYPE_OBJ should be accessed in
a static
way PE.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/utils/coff line
410
Warning The static field PE.Attribute.PE_TYPE_EXE should be accessed in
a static
408
Warning The static field PE.Attribute.PE_TYPE_SHLIB should be accessed
in a static
406
Warning The method getInitialSelections() from the type SelectionDialog
is
deprecated SelectionStatusDialog.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/dia logs line
127
is
89
Warning The static field CCorePlugin.PLUGIN_ID should be accessed in a
static
way ConversionWizard.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/ui/wizards/conv ersion line
142
Warning The static method getMatchingFunctions(String) from the type
CCompletionContributorManager should be accessed in a static
way CCompletionProcessor.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/tex t line
348
Warning The static field Window.OK should be accessed in a static
way OpenOnSelectionAction.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
257
24
24
25
25
'org.eclipse.cdt.core.debug.ui.CDebugModelPresentation' in attribute
'class' cannot be found. plugin.xml org.eclipse.cdt.ui line 398
Warning Required attribute 'id' not
defined. plugin.xml org.eclipse.cdt.ui line 355
defined. plugin.xml org.eclipse.cdt.ui line 348
Warning Unknown attribute 'actionID'. plugin.xml org.eclipse.cdt.ui line
278
Warning Referenced resource 'icons/full/obj16/file_obj.gif' in attribute
'icon' cannot be found. plugin.xml org.eclipse.cdt.ui line 217
Warning The static field MGridData.FILL should be accessed in a static
way TabFolderPage.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/ui/wizards line
60
addElementChangedListener(IElementChangedListener) from the type CoreModel
way IndexManager.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/co re/index line
254
58
removeElementChangedListener(IElementChangedListener) from the type
CoreModel should be accessed in a static
246
Warning The static method interrupted() from the type Thread should be
245
Warning The static method sleep(long) from the type Thread should be
99
Warning The static method debugLog(String) from the type MIPlugin should
way RxThread.java org.eclipse.cdt.debug.mi.core/src-cdtmicore/org/eclipse/cdt/ debug/mi/core line
73
way CSourceViewerConfiguration.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/tex t line
175
Warning The static method log(IStatus) from the type CDebugUIPlugin
way AddExpressionActionDelegate.java org.eclipse.cdt.debug.ui/src-cdtdebugui/org/eclipse/cdt/debu g/internal/ui/actions line
162
way OpenIncludeAction.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
150
Warning The type OpenPerspectiveMenu is
deprecated CView.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/cvi ew line
890
Warning The static method getActivePage() from the type CDebugUIPlugin
150
Warning The constructor OpenPerspectiveMenu(IWorkbenchWindow,
IAdaptable) is
890
Warning The static method getResourceBundle() from the type CUIPlugin
way CView.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/cvi ew line
526
way BuildConsoleView.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/bui ldconsole line
89
Warning The type CreateFolderAction is
524
a static
88
Warning The constructor CreateFolderAction(Shell) is
524
521
Warning The type CreateFileAction is
519
Warning The constructor CreateFileAction(Shell) is
519
141
way StringDialogField.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/wiz ards/dialogfields line
79
140
101
95
94
Warning The static method getNextToken() from the type
CPPParserTokenManager should be accessed in a static
way CPPParser.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/pa rser/generated line
9823
9816
9806
9789
9764
way MGridLayout.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/wiz ards/swt line
661
Warning The static method ReInit(ASCII_CharStream) from the type
9728
Warning The assignment to variable widgetY has no
effect MGridLayout.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/wiz ards/swt line
659
Warning The static method ReInit(Reader, int, int) from the type
ASCII_CharStream should be accessed in a static
9727
Warning The static field MGridData.END should be accessed in a static
656
9701
Warning The static field MGridData.CENTER should be accessed in a static
654
Warning The static method ReInit(InputStream, int, int) from the type
9700
Warning The static method backup(int) from the type ASCII_CharStream
way CPPParserTokenManager.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/pa rser/generated line
2348
644
Warning The static method adjustBeginLineColumn(int, int) from the type
2347
639
Warning The static method GetSuffix(int) from the type ASCII_CharStream
2346
637
2344
2335
2333
Warning The static method getBeginColumn() from the type
2329
Warning The field AbstractTextEditor.PREFERENCE_FONT is
deprecated CEditorPreferencePage.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/pre ferences line
582
Warning The static method getBeginLine() from the type ASCII_CharStream
2329
1564
Warning The static method canActionBeAdded(ISelection) from the type
SearchForReferencesAction should be accessed in a static
way CEditor.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
660
2327
2325
2321
2321
2319
2317
2313
Warning The static field CView.TAG_SHOWLIBRARIES should be accessed in a
static
way ShowLibrariesAction.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/cvi ew line
59
2312
2310
Warning The static method GetImage() from the type ASCII_CharStream
2297
Warning The static field AbstractTreeViewer.ALL_LEVELS should be
way CContentOutlinePage.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
136
2296
2287
2284
Warning The static method readChar() from the type ASCII_CharStream
2284
Warning The assignment to variable miEvent has no
effect EventManager.java org.eclipse.cdt.debug.mi.core/src-cdtmicore/org/eclipse/cdt/ debug/mi/core/cdi line
47
Warning The static method getEndColumn() from the type ASCII_CharStream
2281
Warning The static method getEndLine() from the type ASCII_CharStream
2280
2275
2254
Warning The static method BeginToken() from the type ASCII_CharStream
2183
2181
2165
2142
2141
2140
2139
2138
2019
1928
1912
1241
Warning The import org.eclipse.jface.viewers.IStructuredSelection is
never
used SelectionUtil.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/uti l line
15
1219
1185
1143
1083
1015
945
869
739
625
505
425
311
231
162
Warning The import org.eclipse.cdt.internal.parser.ParserCallback is
never
used CPPParserTokenManager.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/pa rser/generated line
4
way MISession.java org.eclipse.cdt.debug.mi.core/src-cdtmicore/org/eclipse/cdt/ debug/mi/core line
279
Warning The static method getFunctionInfo(String) from the type
way AddIncludeOnSelectionAction.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
137
Warning The static method log(Throwable) from the type CUIPlugin should
way CContentProvider.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui line
82
57
55
41
static
way ConvertProjectWizardPage.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/ui/wizards/conv ersion line
514
static
507
way FilterSelectionAction.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/cvi ew line
59
way TemplatePreferencePage.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/pre ferences line
393
371
Warning The static field Coff.FileHeader.FILHSZ should be accessed in a
static
way Coff.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/utils/coff line
451
way CEditorActionContributor.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/edi tor line
39
way StringButtonDialogField.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/internal/ui/wiz ards/dialogfields line
80
Warning The static field GridData.END should be accessed in a static
way CBreakpointPropertiesDialog.java org.eclipse.cdt.debug.ui/src-cdtdebugui/org/eclipse/cdt/debu g/internal/ui/actions line
463
Warning The static field Elf.ELFhdr.ELFDATA2LSB should be accessed in a
static
way Elf.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/utils/elf line
858
Warning The static field Elf.ELFhdr.EI_DATA should be accessed in a
static
858
static
846
static
846
Warning The static field Elf.Section.SHT_DYNSYM should be accessed in a
static
749
Warning The static field Elf.Section.SHT_SYMTAB should be accessed in a
static
747
Warning The static field Elf.Attribute.ELF_TYPE_SHLIB should be accessed
in a static
629
Warning The static field Elf.Attribute.ELF_TYPE_OBJ should be accessed
in a static
626
Warning The static field Elf.Attribute.ELF_TYPE_EXE should be accessed
in a static
623
Warning The static field Elf.Attribute.ELF_TYPE_CORE should be accessed
in a static
620
Warning The static field Elf.Dynamic.DT_NULL should be accessed in a
static
533
Warning The static method delay() from the type IndexManager should be
way CTagsRunner.java org.eclipse.cdt.core/src-cdtcore/org/eclipse/cdt/internal/co re/index line
31
static
way StdMakeProjectWizard.java org.eclipse.cdt.ui/src-cdtui/org/eclipse/cdt/ui/wizards line
109
Derek
FUDForum. Page generated in 0.10397 seconds
