Home » Eclipse Projects » Eclipse Platform » Classloader issue with Eclipse
Classloader issue with Eclipse [message #64427] Thu, 05 June 2003 15:11 Go to next message
I am doing a Transformation using Xalan in a plugin which is running on
JDK1.3.1_08. While creating new instance with TransformerFactory I am
getting the following error.
"javax.xml.transform.TransformerFactoryConfigurationError: Provider
org.apache.xalan.processor.TransformerFactoryImpl not found at
javax.xml.transform.TransformerFactory.newInstance(Unknown Source)"
in the line
TransformerFactory tFactory = TransformerFactory.newInstance();
The jar files are in classpath and there is no conflict. I even tried
setting the system properties. I disabled most of the plugins and running
with minimal plugins. I want to know is there anything in eclipse that is
conflicting with this setup. The same setup is working with JDK1.4.
Thanks in advance,
Dinesh
Re: Classloader issue with Eclipse [message #65732 is a reply to message #64427] Fri, 06 June 2003 11:51 Go to previous messageGo to next message
Originally posted by: jed_anderson.us.ibm.com
Dinesh,
You mention that the jar is on your CLASSPATH, but do you also have the
jar in the runtime tag of your plugin?
jkca
Dinesh Varadharajan wrote:
> in the line
> Thanks in advance,
> Dinesh
Re: Classloader issue with Eclipse [message #66691 is a reply to message #64427] Sun, 08 June 2003 01:46 Go to previous message
Originally posted by: shartrec.noxspamx.hinet.net.au
There was a bug raised against Xalan about this.
http://nagoya.apache.org/bugzilla/show_bug.cgi?id=9474
It has been fixed in the latest versions of xalan.
Trev
Previous Topic:-> SWT unit test methods
Next Topic:Is eclipse a debug bug?
Current Time: Sat Nov 22 04:02:20 EST 2025
Powered by FUDForum. Page generated in 0.03065 seconds
