Home » Eclipse Projects » Eclipse Platform » obtaining a file under development for plugins
obtaining a file under development for plugins [message #64380] Thu, 05 June 2003 14:48 Go to next message
Originally posted by: dhavrda.motive.com
I would like to get a file during development of a plugin. I would like to
read the contents of this file during the wizard create file (for my type).
The problem is I dont know how to obtain the reference to this file in an
abstract way so as to work during dev time and deployed time. I am in my
method openContentStream of my Wizard. Here is what I am doing now.
URL url = new URL(MMEPlugin.getDefault().getDescriptor().getInstallURL(),
fileName);
return MMEPlugin.getDefault().openStream(new Path(url.getPath()));
thx,
dave
Re: obtaining a file under development for plugins [message #64495 is a reply to message #64380] Thu, 05 June 2003 15:42 Go to previous messageGo to next message
> fileName);
> thx,
> dave
Why not just use url.openStream(), that should work both in development
or in runtime. Assuming that in development the file is in the same
project in the root of that project that the plugin.xml is in.
Thanks, Rich Kulp
Re: obtaining a file under development for plugins [message #64539 is a reply to message #64495] Thu, 05 June 2003 15:51 Go to previous messageGo to next message
I guess my real problem is not opening the file but rather obtaining the
location of my file.
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bbo6h7$ksc$1@rogue.oti.com...
to
type).
an
my
> > URL url = new
> > fileName);
> > thx,
> > dave
> Thanks, Rich Kulp
Re: obtaining a file under development for plugins [message #64562 is a reply to message #64539] Thu, 05 June 2003 16:33 Go to previous messageGo to next message
Read the documentation for Platform.resolve() and read this:
http://eclipsewiki.swiki.net/114#platformurl
Jeff
Re: obtaining a file under development for plugins [message #64585 is a reply to message #64562] Thu, 05 June 2003 16:49 Go to previous messageGo to next message
Thanks. That helps.
"Jeff Hunter" <jxh106@po.cwru.edu> wrote in message
news:bbo9fe$nn0$1@rogue.oti.com...
> Jeff
Re: obtaining a file under development for plugins [message #64769 is a reply to message #64585] Thu, 05 June 2003 18:48 Go to previous message
Pay particular attention to the stmt in wiki that the resolved location
MAY NOT BE LOCAL.
That is why I suggested using url.openStream(). The URL does not need to
be resolved in that case, and it will work whether the file is local or not.
You were using the correct mechanism to find the URL for the file, you
just shouldn't try get the path from it for your purposes.
Rich
Previous Topic:Persist a WorkingSet?
Next Topic:can not access help contents
Current Time: Fri Nov 21 05:27:47 EST 2025
Powered by FUDForum. Page generated in 0.27932 seconds
