| [AGR] Inconclusive results when playing back hierarchic test suites [message #64340] |
Wed, 05 April 2006 09:34  |
Hello.
I have a master test suite which does not directly define any test cases
but simply invokes other test suites. I find that, if the invoked test
suites reside in different folders from the master test suite, the
master test suite cannot be played back successfully: the Eclipse
workbench is briefly instantiated, but the bodies of the invoked test
suites are never executed and then the process ends with inconclusive
results. If instead the suites are organized in a flat structure (as
opposed to a hierarchical one), all works well.
Please note that a hierarchical organization is not a problem when a
suite invokes test cases from other suites directly, they can be located
anywhere and all functions properly.
Has anybody encountered this problem? Is it a bug or a limitation?
TIA
Barbara
PS: Thank you very much, Ali, for a fantastic tool! I have been doing
GUI testing with Rational XDETester, and I must say that AGR is such a
breath of fresh air!... :-)
I finally feel in control of things and capable of defining verification
points at whatever granularity I feel necessary.
| Re: [AGR] Inconclusive results when playing back hierarchic test suites [message #64412 is a reply to message #64340] |
Wed, 05 April 2006 11:47   |
--------------060708090101010605070802
On further examination in my real testing environment, it turns out that
I get the same inconclusive results also when my master test suite is
located in the same folder as the suites that I am invoking from the
master suite.
Just in case it is of any help, I am attaching the .execution file that
shows the problem.
Thanks to anyone that might shed some light on the issue.
B.
Barbara Rosi-Schwartz wrote:
> Hello.
> TIA
> Barbara
Content-Type: application/x-zip-compressed;
name="ProvaMaster.zip"
Content-Disposition: inline;
filename="ProvaMaster.zip"
UEsDBBQAAAAIAH2NhTR6TGJtawMAAIIDAAAjAAAAUHJvdmFNYXN0ZXJfMTE0 NDI1MTAwNjA2
OC5leGVjdXRpb24L8GZmEWHgAMIjza0mDEhAAIiDUovzS4uSU53z80pS80qK 70bE5t8yEKmd
v+W/QKr+bedCoUkOAjlcPwMmhm3V2nIreqqU+B5B602yGf//zmGI5BAJ2tK1 rf/G9e/zqs/Z
uvl9P55sE/yso9DH0/+q9KxVCkwvJSZ7+u+VbE3P/Xr8+/n5u+R6k73euXV0 t1xkt3GeezFU
wkZpBlflF6mPJWpTjkuUd6W4TfNZpr5H+Xr1q5COJcwHkjZmXKi4tCCHqS6W p0tgn+SmjGeC
bcteGr15LuAXKDM38ZCri0LU/KiDrxZnmhyfcpe3w0GnSVJl30S+g5J+FqeK /eYvMnyksCzZ
5DHDM80Df7VYDywV4eXcE7TqyIHTXB317NMzP+5Y/qtNsG3b011tyTumXear 1c7Y2fZsZm70
9drwUA+R007hPecWd3d4Z6xSmie0U4Vb1HU6q3Rkp9sUrlszllj8N/XZ6LBK JCBwV4buNctn
TZuW12zdI3dGUDBmolfJNNWybrtJ1Y9twpwObrzT88jlXF/erLal2bNyI7Zx 9Z21UyjmWvzo
QLEJa1/mjEnL6qwXv1z9zzf0RZOC2QrBvezblMJdtdzblwsonZO/NHPXK5dv QVK9E1wnRzy6
/S79uU7Zr+3XWyP1FH0knX9K+EtWnVjlOdNigskft4A57ik2k9lYVK8Wm37e oM9+mzn1SPEv
91WhHzNl/frnbg59mr5s7a7qI2f+8s91lNS60bx1dmm5RJyjI69ju8eSk3K2 t8uC+U3VsxeH
XhV+I1aSaxbw8Guo74uIebJZu17OXDd/9oUb6YeyvrAbPwyrPj6zgN37/ZkW /Qs/XdT2+Ajs
jFo3lTX3l+/6pbt1/bN/R93/lrv3JbvuWvkb0U37NMV/xSXM2Be2Y8PO661T X/Q/O5RV7b6r
YPbS788O/bKaf6L18Jd5zm3vL3bImSWviI6L5zYyrsq/3bPvWURj6IyLd/KP nX3Bn37Mq/r4
rMLupeXpx25ZNW9nTXfdqqJledW20PnHr2Uckr3890XXCUc1ll+yfxd95JhE 1+H3U88er/vX
ZWsgdd7gP9f5KVLvz53a3sWTKH7lV5CK8n+mAG92jpqT28M/MDEwVAsxMAR4 MzKJMCDyC7Kc
AAM6QM89Ad6sbCBxRiC0A9J6zCAtAFBLAQIUABQAAAAIAH2NhTR6TGJtawMA AIIDAAAjAAAA
AAAAAAAAAAC2gQAAAABQcm92YU1hc3Rlcl8xMTQ0MjUxMDA2MDY4LmV4ZWN1 dGlvblBLBQYA
AAAAAQABAFEAAACsAwAAAAA=
--------------060708090101010605070802--
| Re: [AGR] Inconclusive results when playing back hierarchic test suites [message #65840 is a reply to message #64412] |
Tue, 11 April 2006 16:02   |
Hi Barbara,
You're right, I've opened the following defect to handle this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=136186
Thanks.
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:e10ose$1ol$1@utils.eclipse.org...
> master suite.
> shows the problem.
> B.
> > Hello.
> > TIA
> > Barbara
FUDForum. Page generated in 0.43679 seconds
