Home » Newcomers » Newcomers » using other classes in a project : class cannot be resolved or is not a type
using other classes in a project : class cannot be resolved or is not a type [message #64323] Sat, 14 May 2005 17:09 Go to next message
When I try to create an object wich depends on another class, eclipse
can't compile the java file ("[OtherClassName] cannot be resolved or is
not a type"). With the command line (javac) on winXP it works well.
The class I want to use is in the same directory as the .java file and I
don't have the source of that file, only the class (but the class works
fine because javac can compile it using command line).
How can I fix this problem?
thanks
Re: using other classes in a project : class cannot be resolved or is not a type [message #64555 is a reply to message #64323] Mon, 16 May 2005 07:35 Go to previous messageGo to next message
> thanks
No one with an idea?
gs
Re: using other classes in a project : class cannot be resolved or is not a type [message #64759 is a reply to message #64323] Mon, 16 May 2005 10:58 Go to previous messageGo to next message
The .class that you depend on must be included on the build path of the
project, not in its source path.
For example, let's say you have a project like this:
MyProject/
source/
com/
foo/
ClassYouWrite.java
lib/
If the .class that you depend on is in package com.x.y, then you would
place that .class in lib/com/x/y directory and include lib/ on the build
path for the Project.
The Help tutorials would explain this in detail - I urge you to go
through them to better understand Eclipse project structures.
Eric
Re: using other classes in a project : class cannot be resolved or is not a type [message #64828 is a reply to message #64759] Mon, 16 May 2005 14:08 Go to previous message
>> is not a type"). With the command line (javac) on winXP it works well.
>> I don't have the source of that file, only the class (but the class
>> works fine because javac can compile it using command line).
> MyProject/
> source/
> com/
> foo/
> ClassYouWrite.java
> lib/
> Eric
source and class files are in the same project directory (small
project). Also the .class I want to use is that project directory.
Shouldn't it be automaticly recognized / in the classpath?
gs
Previous Topic:Having problems upgrading to 3.0.2 from Update Manager.
Next Topic:Viewing every constructors
Current Time: Tue Nov 18 21:33:27 EST 2025
Powered by FUDForum. Page generated in 0.08347 seconds
