Home » Eclipse Projects » GEF » draw2d TextExample.java
draw2d TextExample.java [message #64302] Tue, 11 February 2003 16:21 Go to next message
In the TextExample, it has an example to render source code.
I am wonder what is the best way to implement color syntaxing when use that
I am thinking I can scan the content to look for key words and create a
number of TextFlow objects for text before the keyword, the keyword itself
and text after the keyword. And then set the font of each TextFlow
accordingly.
Is there a better approach than this? My concern is performance, since I
need to create a lot of small TextFlow objects.
Thank for any feedback.
Re: draw2d TextExample.java [message #64325 is a reply to message #64302] Tue, 11 February 2003 16:58 Go to previous messageGo to next message
There is probably a lighterweight approach. If you know that you are going
to use the same font, and only change the color, you could use a single
TextFlow. The subclass could store highlight regions, and override
paintFigure() to break up the text into its regions. This is similar to how
the JDT does it.
"Hal" <otaconss2@hotmail.com> wrote in message
news:b2bo33$j1l$1@rogue.oti.com...
that
> accordingly.
Re: draw2d TextExample.java [message #64347 is a reply to message #64325] Tue, 11 February 2003 17:01 Go to previous messageGo to next message
what if I need to Bold and use a different color for keywords (same as JDT),
will your approach works too?
Thanks.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b2bq79$kta$1@rogue.oti.com...
going
how
> the JDT does it.
> that
itself
> > accordingly.
Re: draw2d TextExample.java [message #64369 is a reply to message #64347] Tue, 11 February 2003 17:07 Go to previous message
only for monospace fonts :-)
news:b2bqch$l16$1@rogue.oti.com...
JDT),
> Thanks.
> going
> how
> > the JDT does it.
> > that
a
> itself
> > > accordingly.
I
Previous Topic:Caching Edit Parts
Next Topic:Connection Anchor
Current Time: Sun Aug 31 15:54:20 EDT 2025
Powered by FUDForum. Page generated in 0.04061 seconds
