Home » Eclipse Projects » Eclipse Platform » CVS connection problem using Eclipse
CVS connection problem using Eclipse [message #64289] Thu, 05 June 2003 14:11 Go to next message
Originally posted by: removespam-les.carter.help-me.to
I can connect to my CVS repository using Eclipse 2.0.? when I'm using Win
XP, but when I switch over to my linux box (SuSE 8.0) using Eclipse 2.1,
even though I'm using the same connection details, I get an IO failure,
connection refused (even though I can telnet into the pserver). The SuSE
install has all current update patches applied.
Can anyone cast some light as to what might be going on?
Re: CVS connection problem using Eclipse [message #65304 is a reply to message #64289] Fri, 06 June 2003 06:29 Go to previous message
Is this reproduceable? Is there anything in the .log file? Could you try
using extssh or ext and see if you can connect using one of those
connection methods?
Jean-Michel
Previous Topic:Eclipse and CVS
Next Topic:Ant: Jar task fails with NoClassDefFoundError
Current Time: Sat Nov 08 22:35:08 EST 2025
Powered by FUDForum. Page generated in 0.03841 seconds
