| Not getting Instance of IResource [message #64283] |
Mon, 08 June 2009 09:44   |
Eclipse User  |
Was just trying out some example. I want to create a trigger point at
instance of IResource. However when I declare this instance in the
plugin.xml I get error as "org.eclipse.core.resources.IResource" in
attribute "value" is not in the plug-in classpath.
below is the snippet of my xml
<triggerPoints>
            <or>
               <and>
                  <instanceof
                        value="org.eclipse.core.resources.IResource">
                  </instanceof>
                  <test
                        forcePluginActivation="true"
                        property="org.eclipse.core.resources.extension"
                        value="properties">
                  </test>
               </and>
               <instanceof
value="com.eclipse.ui.dagger.navigator.PropertiesTreeData">
               </instanceof></or>
         </triggerPoints>
Does this mean the IResource package is not available in my eclipse
installation?
FUDForum. Page generated in 0.04794 seconds
