Home » Modeling » M2T (model-to-text transformation) » How to Access All Elements
How to Access All Elements [message #64281] |
Mon, 13 July 2009 06:23  |
I am using a CheckValidator for my language.
In the code generator workflow, I want to validate
all elements in all models, including those imported
into my language. In other words, I need the equivalent
of 4.3.1's allElements() extension to get a collection
of truly all model elements the generator will process.
How can I do this in the 0.7 release?
Markus
Markus Völter
voelter - ingenieurbüro für softwaretechnologie/itemis
Ötztaler Strasse 38, 70327 Stuttgart-Untertürkheim, Germany
Tel. +49 (0) 171 / 86 01 869
Email: voelter@acm.org
Web: http://www.voelter.de
Blog: http://www.voelter.de/blog
SE Radio Podcast: http://www.se-radio.net
omega tau podcast: http://www.omegataupodcast.net
Re: How to Access All Elements [message #64326 is a reply to message #64281] |
Mon, 13 July 2009 09:24   |
Hi Markus,
there is some functionality in EcoreUtil doing what you're looking for:
EcoreUtil.getAllContents(resourceSet, true);
You'll have to write a JAVA extension and in Java do some conversion
from Iterator to List, because EcoreUtil returns iterators and in Xtend
you'll want a list.
This might be something for the standard-lib.
Sven
Markus Voelter schrieb:
> Markus
Re: How to Access All Elements [message #64601 is a reply to message #64326] |
Fri, 17 July 2009 09:31   |
> you'll want a list.
I have implemented this:
public static List<EObject> allElements( EObject anElementInRootResource ) {
ResourceSet rs = anElementInRootResource.eResource().getResourceSet();
TreeIterator<EObject> all = EcoreUtil.getAllContents(rs, true);
List<EObject> result = new ArrayList<EObject>();
while ( all.hasNext() ) {
result.add(all.next());
return result;
But if I run it, I get:
3234 [main] ERROR org.eclipse.xtend.XtendComponent - Error in Component of type org.eclipse.xtend.XtendComponent:
EvaluationException : java.lang.ClassCastException: org.eclipse.xtext.linking.lazy.LazyLinkingResource cannot be cast to org.eclipse.emf.ecore.EObject
bwin::ai::btarget::stresstest::vis::main.ext[656,13] on line 18 'file.allElements()'
bwin::ai::btarget::stresstest::vis::main.ext[556,21] on line 15 'toGraphVizmodel(file)'
nofile[0,10] on line 1 'top(model)'
Where is this standard-lib? I'd have a couple of other things to contribute.
Markus
> Cheers,
> Sven
>> Thanks,
>> Markus
Markus Völter
Re: How to Access All Elements [message #64624 is a reply to message #64326] |
> you'll want a list.
return result;
Markus
> Cheers,
> Sven
>> Thanks,
>> Markus
Markus Völter
Re: How to Access All Elements [message #64762 is a reply to message #64647] |
Tue, 21 July 2009 03:50   |
It seems the TreeIterator doesn't just contain the EObjects, but
also the Resources that contain them. In the following output ...
org.eclipse.xtext.linking.lazy.LazyLinkingResource.......... ........
org.eclipse.xtext.linking.lazy.LazyLinkingResource.......... .............
org.eclipse.xtext.linking.lazy.LazyLinkingResource.......... ............................................................ ............................................................ ............................................................ ........................
.... each dot is an EObject, and the other ones you can see.
is this intended? Do I have to traverse the LazyLinkingResource
myself?
Markus
Sven Efftinge wrote:
> Hi Markus,
>> ResourceSet rs =
>> return result;
> I cannot see where this ClassCastException could occur in the given
> code. Could it be that 'file' in the Xtend code is a Resource and not an
> EObject?
>> contribute.
> I'm talking of the std-lib project you initialized for Xpand.
> It is part of M2T/Xpand.
> Cheers,
> Sven
Markus Völter
Re: How to Access All Elements [message #64785 is a reply to message #64762] |
Tue, 21 July 2009 06:04   |
Hi Markus,
this seems to be intended even if is somewhat counter-intuitive.
Please use the Iterators and Lists classes from google collections for
your convenience:
Iterator<EObject> iter = Iterators.filter(
EcoreUtil.getAllContents(resourceSet, true), EObject.class);
return Lists.newArrayList(iter);
Hope that helps,
Sebastian
Am 21.07.2009 9:50 Uhr, schrieb Markus Voelter:
> myself?
> Markus
>> Hi Markus,
>>> return result;
>> an EObject?
>>> contribute.
>> Cheers,
>> Sven
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: How to Access All Elements [message #64831 is a reply to message #64785] |
Wed, 22 July 2009 04:58  |
yes it helps, thanks.
Markus
Sebastian Zarnekow wrote:
> Hi Markus,
> your convenience:
> Hope that helps,
> Sebastian
>> myself?
>> Markus
>>> Hi Markus,
>>>> return result;
>>> an EObject?
>>>> contribute.
>>> Cheers,
>>> Sven
Markus Völter
Current Time: Sat Jul 26 17:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.04185 seconds
