| Check of OCL constraints embedded in UML2 profile [message #64274] |
Wed, 05 November 2008 06:08  |
Hello all,
this is what I am trying to do:
1. Define a UML2 profile
2. Embed OCL constraints in the UML2 profile
3. Validate a model using the profile - and thus the embedded OCL
constraints
The OCL constraints tipically check that model element with a given
stereotypes have certain properties. A typical OCL constraint is thus
something like:
myStereotype.base_BaseClass.<ocl_expression>
The first two steps were quite easy (I use the Papyrus UML editor which
embeds an OCL parser/validator); but I have serious problems with the
validation part (for the papyrus users: the tutorial for OCL constraints
doesn't seem to work).
I googled around looking for tutorial/solutions with no results (or
partial results lacking detailed info).
So the question is: is there a way to directly use OCL constraints
embedded in a UML2 profile to validate a model? If not, could you please
indicate a tutorial explaining how to use OCL constraints embedded in a
UML2 profile (likely via the validation frameworks)?
Thanks in advance,
Matteo
| Re: Check of OCL constraints embedded in UML2 profile [message #64362 is a reply to message #64339] |
Wed, 05 November 2008 12:13   |
Hello Christian,
thanks for the hint. Before trying it, I would like to know if I could
use UML2 static profiles for my purpose (generating genmodel model out
or a UML2 profile containig OCL constraints).
Matteo
Christian W. Damus wrote:
> Hi, Matteo,
> The org.eclipse.emf.validation.examples.ocl example plug-in (installed
> via the "New -> Example..." wizard if you have the EMF Validation
> Framework SDK) demonstrates a simple way to contribute constraints from
> an OCL text file. It's a pretty bare-bones example of a custom
> constraint provider that doesn't put its constraints in the plugin.xml.
> You could adapt this example to have the constraint provider get the
> stereotypes applied to a UML element and find Constraints attached to
> the Stereotypes. For any Constraint that is specified by an OCL
> expression (usually as an OpaqueExpression with a language "OCL"), you
> could create an AbstractOCLModelConstraint that parses and evaluates it.
> HTH,
> Christian
> Matteo Bordin wrote:
>> Hello all,
>> constraints
>> something like:
>> which embeds an OCL parser/validator); but I have serious problems
>> with the validation part (for the papyrus users: the tutorial for OCL
>> constraints doesn't seem to work).
>> please indicate a tutorial explaining how to use OCL constraints
>> embedded in a UML2 profile (likely via the validation frameworks)?
>> Thanks in advance,
>> Matteo
| Re: Check of OCL constraints embedded in UML2 profile [message #64431 is a reply to message #64362] |
Wed, 05 November 2008 14:07  |
Originally posted by: cdamus.zeligsoft.com
Hi, Matteo,
The UML2 run-time provides traceability between your UML profile and the
generated EPackage, so this should work as well with OCL as a dynamic
profile.
Just be sure to register your package and your profile on the various
EMF and UML2 extension points, and you should be fine.
Christian
> Hello Christian,
> Matteo
>> Hi, Matteo,
>> from an OCL text file. It's a pretty bare-bones example of a custom
>> HTH,
>> Christian
>>> Hello all,
>>> constraints
>>> something like:
>>> Thanks in advance,
>>> Matteo
FUDForum. Page generated in 0.05092 seconds
