Re: [ATL][UML] Superimposition Exception "Pattern not equal for execution environment and modul [message #64331 is a reply to message #64287] |
Fri, 19 October 2007 03:52  |
Andreas Schwab schreef:
> Hello all,
> I solved the exception
> "Pattern not equal for execution environment and module in main (getasm
> != load 0 @ 0)
> Reason was a reference on a model 'In' while there only was a model
> named 'IN' ;-)
Hmm, are you sure? The exception listed typically occurs when you try to
superimpose an ATL 2004 compiled transformation on top of an ATL 2006
compiled transformation.
The exception is caused by one of the superimposition "sanity checks":
if superimposition finds unexpected instructions at the point where it
wants to merge the instructions of the superimposed module, it throws an
exception.
Can you re-check for the cause of this exception? We can then add an
entry to the FAQ for this exception ;-).
Dennis
> Nevertheless my other problem still exists...
> Cheers
> Andreas Schwab
FUDForum. Page generated in 0.04715 seconds
