| plug in for XSD [message #64260] |
Tue, 04 October 2005 04:55  |
Originally posted by: smaskar.gmail.com
I am planning to write a plugin for XSD. If you have any document/links
that will explain me the basic for this plugin please send it to me.
Proposed Plugin for XSD.
1. Functionality to create the new file of type XSD using the file menu.
2. Design view (where user can add/delete the elemets)
3. Any action from design view will update my XSD file
I am reading the few documents from the eclipse.org regarding to the EMF
framework
Santosh
| Re: plug in for XSD [message #64316 is a reply to message #64291] |
Tue, 04 October 2005 07:44  |
Thanks Merks, It is very useful information.
Santosh
Ed Merks wrote:
> Santosh,
> Sorry. Documentation is sparse. Looking at XSDMainExample in the
> org.eclipse.xsd.example should help get you started in terms of
> standalone/headless invocation of tests cases.. The samples in
> XSDPrototypicalSchema should help you to understand how to construct
> schemas bottom up.
> Note that the first thing is already available:
> There's also a sample schema editor that does the second thing:
> And it's possible to register popup actions that will appear in the
> editor to do the third thing. The org.eclipse.emf.ecore.editor plugin
> shows global actions registered against an EClass instance but you could
> use the same approach for registering actions against an XSDSchema
> instance the same way.
> The WTP project uses the XSD model to implement a really nice schema
> editor. I'd suggest having a look at that too.
> Santosh Maskar wrote:
>> Hi
>> document/links that will explain me the basic for this plugin please
>> send it to me.
>> EMF framework
>> Thanks,
>> Santosh
| Re: plug in for XSD [message #596788 is a reply to message #64260] |
Tue, 04 October 2005 06:58  |
--------------070803040708030908020507
Santosh,
schemas bottom up.
> Hi
> send it to me.
> EMF framework
> Santosh
Content-Type: multipart/related;
boundary="------------090808000809040409000703"
--------------090808000809040409000703
<html>
<head>
</head>
Santosh,<br>
<br>
schemas bottom up.<br>
<br>
Note that the first thing is already available:<br>
<blockquote><img src="cid:part1.09090500.02040107@ca.ibm.com" alt=""><br>
</blockquote>
There's also a sample schema editor that does the second thing:<br>
<blockquote><img src="cid:part2.06050903.04010700@ca.ibm.com" alt=""><br>
</blockquote>
<br>
could use the same approach for registering actions against an
XSDSchema instance the same way.<br>
<br>
editor. I'd suggest having a look at that too.<br>
<br>
<br>
<blockquote cite="middhtg24$bbn$1@news.eclipse.org" type="cite">Hi
<br>
<br>
<br>
<br>
menu.
<br>
<br>
<br>
<br>
EMF framework
<br>
<br>
<br>
Santosh
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-3.jpg"
Content-ID: <part1.09090500.02040107@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-3.jpg"
/9j/4AAQSkZJRgABAQIAJQAlAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAHyAfADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDWuvincW+pX1qNGttlrcyW 4keYDeUOCcCI
47fn3po+Ktyemj2P/f8A/wDtNYWgLbjxrrM9xCs32e/u5UjboWDqO/sSfwpP EGpWN7cyzSSM
m852i4gwPzYV60cPRTScOi6v/Mz5mlds0br4zz2k/lP4fgY4BDLOuCPxiqEf G+T/AKF6L/v+
v/xusHw/Po9nrOrXes6YupWEOmDfC20sA9xFGWU9A4Dkggj2Izmty98D+Ffs UmoRat5ukWGm
wyxzp+6M5nupgpkdY5DuVQEPyZJAztAwJnQw8ZWcfz/zM3Od9GSD43SH/mX4 v+/y/wDxulHx
skP/ADAIv+/y/wDxuqui+A/CGrLdXkGvzSaZbal5U1y80dv5Vs0O5GYSLkN5 pEecYbBwB25b
xn4ct/C+o2FhHK7XTWEM19G8iOYbhs7k+XoAMEDngg5ORRGhhpS5VHX5kudR K9ztR8apP+gB
F/3+X/43Sj40Sf8AQBi/7/L/APG68oFPFa/U6P8AL+LJ9tPuerf8Lnk/6AMX /f5f/jdKPjLJ
/wBAGL/v6v8A8bryoU8UfU6Pb8WHtp9z1MfGOQ/8wKL/AL+r/wDG6cPjFIf+ YHF/39X/AON1
5aKcKX1Oj2/Fh7afc9RHxgkP/MDi/wC/q/8AxunD4vSH/mCRf9/V/wDjdeXi nij6nR7fiw9t
PuenD4uSH/mCRf8Afxf/AI3Sj4tyf9AWL/v4v/xuvMxTxS+qUe34sPbT7npY +LMh/wCYLF/3
8X/43Sj4ryH/AJg0X/fxf/jdebCnCj6pR7fixe2n3PSB8VpP+gNF/wB/F/8A jdOHxUk/6A8X
/fa//G684FPFH1Sj2/Fj9tPueij4pSf9AeL/AL7X/wCIpw+KMh/5hEX/AH2v /wARXnYp4pfV
KPb8WHtp9z0IfE+Q/wDMIi/77X/4inD4myH/AJhMX/fa/wDxFefCnij6pR7f ixe2n3O/HxLk
P/MJi/76X/4inf8ACypP+gVF/wB9L/8AEVwAp4o+qUe34sPbT7nej4kSf9Aq L/vpf/iKUfEe
Q/8AMLi/76X/AOIrhBThS+qUe34sPbT7ndj4iyH/AJhcX/fS/wDxFKPiHJ/0 DIvzX/4iuGFP
FH1Wj2/MPbT7nbj4gyf9AyL81/8AiKcPiBJ/0DYvzX/4iuJFPFH1Wl2/MPbT 7naDx9If+YbF
+a//ABFOHjyQ/wDMOi/Nf/iK4wU4UvqtLt+Ye2n3OyHjuT/oHRf+O/8AxFKP HMn/AED4v/Hf
/iK48U8UfVaXb8w9tPudePG8h/5h8X/jv/xFKPG0h/5cIv8Ax3/4muSFPFH1 Wl2/MPbT7nWD
xpIf+XCL/wAd/wDiaUeMpD/y4xfkv/xNcqKeKX1Wl2/MPbT7nUjxhIf+XGL8 l/8AiaUeL5P+
fKL8l/8Aia5cU8UfVaXb8w9tPudN/wAJbJ/z5Rfkv/xNKPFkn/PnF+S//E1z Ypwo+rUu35h7
afc6QeKpD/y5xf8AfK//ABNKPFEh/wCXSL/vlf8A4mudFPFL6tS7fmHtp9zo R4mk/wCfSL/v
lf8A4mlHiST/AJ9Yv++V/wDiawBTxR9WpdvzD29Tubw8RyH/AJdYv++V/wDi aUeIZD/y7Rf9
8L/8TWGKeKPq1Lt+Ye3qdzaGvyf8+0X/AHwv/wATThr0n/PvF/3wv/xNYop4 pfVqXb8w9vPu
bA1yQ/8ALvF/3wv/AMTThrUh/wCWEX/fC/8AxNZAp4o+rUu35i9vU7mqNZkP /LCL/v2v/wAT
Thq8h/5Yxf8Aftf8KyhTxR9XpdvzD29TuaY1WT/nlF/37X/ClGpyf88ov+/a /wCFZwp4pfV6
fYPb1O5oDUpD/wAs4v8Av2v+FTxTXM0fmJFb7c4ywjXn8R7issVZnMA0KQ3U vk24MvmyeaY9
i7Vyd4IK4HOQRjrWValCEeZL8zWlUnOVmy9uuv8Anna/nFWXeaqZbPU4onh8 y3R0do1X5H2B
sBgOoDDoeD7ivPNB1XUbjV9Kh1fUtRTQDIf7HvJU8l9SYfcFw4bPTJQEL5vU 5PynpdP/AOPf
xP8A9fU//otK5lZ30/M3d1bU5Obwd4vj1zUbu00S5aOW+muIJo5oxuVm4OCw 7Y/Oqtz4B8U3
l0bmfwxO0pOSQ8KjP0D4r6ItP+POD/rmv8qmrqWPqpLRfcHL0ufMd78PPHM8 8hg0O5ijkjEU
ii4jG9QwbDANyMgHHqAadZ+BfiTp8iSWVnqNs6RGFGhvFQrGW3FQQ/C7iTjp k5r6aooeOqPd
L+vmQ6Kbvc+Z5vA3xIuftX2i01GX7Xs+0+ZeK3nbPu78v82O2elRXXw78fX9 091e6Xd3Nw+N
8s1yju2BgZJbJ4AH4V9O0UfXai6L+vmL2Ee58vD4YeM/+gHL/wB/Y/8A4qnD 4Y+Mv+gHL/39
j/8Aiq+n6Kf16p2X9fMPYRPmIfDLxl/0A5f+/sf/AMVTh8M/GP8A0BJf+/sf /wAVX03RS+vV
Oy/r5h7CJ8zD4aeMP+gJL/38j/8AiqcPht4v/wCgJL/38T/4qvpeij69U7L+ vmHsInzUPhv4
v/6Asv8A38T/AOKpw+HHi7/oCy/9/E/+Kr6Too+vVOy/r5h7CJ83j4c+Lf8A oCy/9/E/+Kpw
+HXiz/oDS/8AfxP/AIqvo6ij67U7L+vmHsInzmPh54s/6A0v/fxP/iqcPh74 r/6A0v8A32n+
NfRVFH12p2X9fMPYRPncfD7xV/0B5f8AvtP8acPh/wCKv+gPL/32n+NfQ1FL 67U7L+vmHsIn
z2PAHin/AKBEv/faf404eAvFH/QIl/77T/GvoKij67U7L+vmHsInz+PAfif/ AKBEv/faf408
eBPE3/QJl/77X/GvfaKPrtTsv6+YewieCDwL4m/6BMv/AH0v+NOHgfxL/wBA mX/vpf8AGvea
KPrtTsv6+YewieEDwR4k/wCgVL/30v8AjTh4J8Sf9AqX/vpf8a91oo+uVOy/ r5i9hE8MHgrx
H/0Cpf8Avpf8acPBfiL/AKBcv/fS/wCNe40UfXKnZf18x+wieIDwZ4h/6Bcv /fS/404eDvEP
/QMl/Nf8a9topfXKnZC9hE8UHg/xB/0DJfzX/Gnjwhr/AP0DJfzX/GvaKKPr lTsg9hE8YHhH
Xv8AoGy/mP8AGnjwlr3/AEDZfzH+NeyUUfW6nZB7CJ46PCeu/wDQNl/Mf404 eFdc/wCgdL+Y
/wAa9goo+t1OyD2ETyEeFtb/AOgdL+n+NOHhfW/+gdL+n+NeuUUfW6nZB7CJ 5KPDOtf9A+X9
P8acPDWs/wDQPl/T/GvWKKPrdTsg9hE8pHhvWP8AoHy/pTh4c1j/AJ8Jf0r1 Sil9bn2Qewie
Wjw7q/8Az4S/pTx4e1b/AJ8ZfyFen0UfW59kH1eJ5kNA1X/nxl/KnDQdV/58 Zfyr0uij61Py
D6vE82Ghap/z5S/lThoep/8APlL+Vej0UfWp+QfV4nnQ0TU/+fKX8qcNG1L/ AJ85fyr0Oij6
1PyD6vE8+Gj6j/z5y/8AfNPGkah/z5y/98131FH1qfkH1eJwY0nUP+fSX/vm nDSr/wD59Jf+
+a7qil9an5B9XicONMvv+fWX/vmnDTb3/n1l/wC+TXbUUfWp+QfV4nFjTrz/ AJ9Zf++TVe+0
3xDKI47GcWsSZYhrMyMzHHfcOOBxj1/DvKY0oUUpVpTVmkVGiou6Z51/Yvi3 /oKL/wCC3/7O
o4tGvNJ0nVmvJDLLc+ZMz+T5YyUAxjJ/u5r0CSZm4zgVi+I/+QFdf9c3/wDQ TUPROyRVrvcP
Ft1rtj8P7258NW/n6vHbKbdAgc9RuKqfvMF3EDnJAGD0PM3vjyHwva6neyav qWrpZ2QnksdT
sxZ3W5pUjiaMeRFmIszh2IbaQmO4PdXOmw6tocdpM0iAiKRJIyA0ciMro4yC Mqyq2CCDjBBG
RXO3/wANNK1o6jJrd/qWp3F7ZLYmeZ442iiWTzQEESIud4VssG+6B0yDmWcP 46+J0134W8Qa
XY3FpBqEFlb3sN9oeqm5QKbqON0MgRCj/MOADkNyR33NU+MtnpsusSG0sTa6 VqBsZYZNSCX0
21lV5IrfYQygs2MuMhDnHbpNX8CReINEvdK1nX9ZvYLpFTczQxmMB1f5RHEq kkovLKxAyFxu
bMkHgmCyvNRk0/WdVsrXUbt7y6s4HiCPI4AkIcxmVN2P4XBGflK8YAI9G8XX 2vapqaWGjRtp
unam+mzTNebZy6bQzrFs2lAW/wCegO0EgE4U5/w58QeI9duPEa6ylo0FlrFz aRvHNlothTEQ
URKGQAn94SGPda2LDwbbaZql5dWOpalBbXt6b+4sUkQRPOduW3bPNAJUEqH2 nkEbSVNjRvC9
toOqand2F3drBqNw93NZMUaITvt3SKdu8E7em4rycAcYAMvxl45Twp5oA0p5 IbQ3TQ3uqrbS
TD5sLCgV2djsI5CjJUAk7ttzVPFbW3w+bxZpumyXqfYkvktZJVhYxEB2Jb5g CqEtgZztwM5q
vqvgGy1K/wBZu4dT1KwOtW6W+ox2piK3CqjICfMjcqdrFflI6A9ea3LDRrOx 8PW2h7PtFjBa
JZ7LgB/MjVAmHGMHIHPGD6UAcPd/Fu3WfU4dO0z7bJFLp0OmjzzH9ve8TzEH zJ+6woJ+brjn
BqPSfFtzp+l+K9TQRvZ6frt5Fcy6zq7gRBdm0Q7YGIQk4WPqDgAsW42NN+GG g6anhlFku508
OvcPZrcFHDNK24l/k5KtgqRjBAPNRyfC/TDefaodW1WCQarPq4CtC6C4lCjd seNlO3b8hIJX
cTnPQAkk8cXdr4f0m91PTtN0W/v0eQ2ur6slssSqRgbthYuQynbs+XkMVIAb D074t3uvPYw6
D4Rnv7q70r+0REb6OHYVuDA6ksMbQVYhhknK/KMkjqJvBayatbawmvarFq8V o1k98gty80Jk
8wKymIxjB6FVU+pNV/C3w40fwjf2l5YXN9JJa6e+noJ3QgxtO05Jwo+bcxGe mO2eaAOP+IHj
jWNQ8CeLZ9Et/sNrpOoDT3v1v3iuRIksQYoipjaS23PmAkZOO1ewVw+qfC3R 9Vs9YsX1DVbe
w1W7N9PaQTIqC4JUtICULHOz7rFkGchQQpXuKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigBGYKp
ZiAAMkntVf8AtGx/5/Lf/v6v+NN1UO2kXojxvMEgXPTO04rhf+EW8Sf3LD/v 5/8AY0Ad5/aN
j/z+W/8A39X/ABo/tGx/5/Lf/v6v+NcH/wAIt4k/uWH/AH8/+xoHhbxIDnZp 5+r/AP2NAHfp
d20n3LiJv91wazL3WJIrwG3CyWluQLthzjPYe6j5j7EVmWui6q9m9vdxW8Yc YLwS4YfTj9Ks
efc6VAunukbXHy/ZRGoVZMnBGB028E+xz7Vz15yjtt3NIJM3vNWWMSIweNhl WU5BFQMSTUOm
6cLHzXabzJZjudUXZGD/ALKj9Sck1PJ1rejPmWq1M5Kz0IzWT4j/AOQFdf8A XN//AEE1qM6j
vWT4icNod0B/zzf/ANBNbS+ElbnRWn/HnB/1zX+VTVDaf8ecH/XNf5Vm+KPt n9gy/YvP3ebD
532fPmfZ/NTz9m35t3leZjZ8+fu/NisijYorz/7RoCXOmWfgO+0Oya+1AW9/ LpMUEh8sW1w4
yF4DZQlScgEchhuU17XxTrqeKL43NxBPDby3Yk0a3kEt2IIhJ5bpbrCHRnCR kM8xRvM4ALoA
AekUV43Hr95qWo2sN94otDZ6bewXL6xZXtvci2EtveRkPL5CRKCyxqA0ZOZf vEsoXpNG1/Xb
vxzJaXN/YiH7Xcwyab54aaKBC4jl8lYQ8e4LG295ShEnABdAAD0CivP/ABH4 qvdP8ZWltbX0
FvGt3aWj2N1dRo90JZEVpYofKMkigSY3CVQGibKkKQ1jxRqerWeo+ILm01We 3h0bRItQjtFi
iaOeTNySJCyF9pEKDCspxnBB5oA7iivL5Nf8XXesavaWF/Yi+/06G303z0aa IIsgt5fJ8kGP
cVhbfLKYyJOAN6AbGmeIdZ1PXtNEa7dN1GV7+3OUO6wWJ4/TIy5tJecN/pOz GI2oA7iiuH1H
7H/wlE+fP/sn+0LX+0sY2/2hiH7N/t7ceRu28bvJxx59cfep4btrR4Ip/Dms WLS2ZvdWghj8
xI1vrYFbybcwlaUFmLHYCYnO0/wgHtFFcv4W+x/2jqH9g+R/wjflQ/ZfsuPs /wBozJ53lY42
48nO35N+/wDj8yuX0bxDrwsdLurnWZ7pntNHupUlhhCyG+mMMinYikKgXcmC DuJ3FxgAA9Qq
OOeGZ5kiljd4X2SqrAlG2hsN6HaynB7EHvXmdv4s1ZrGCWPWPtE09pHLq6bI j/YcjTQI64VR
5exJbhsT7yPs+TkK+csa/eWt5qY0vxRaSafcanI8mt3V7bwLI6WtmEjEogki yd0nyhAT5RO7
5W3AHsEc8MzzJFLG7wvslVWBKNtDYb0O1lOD2IPepK5PwRNc3L69PeiMXcl7 A8wjjdFDmwtC
2FcB1Gc8MAR35rrKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAq6k23S7tvSFz/wCOmsu01PVL m3Sby7QKwyB8
2a0dXz/Yl/jr9nk/9BNVrCHbYxLjoP61cLdTOo30Hrd338S2/wCG6pBd3HdY /wAAad5ftR5f
tV2j2Mrz7gt1KWwVT8jUjBJMSPGheMEoxXJXIwcelMEfIqXb8p+lZVeVI0p8 3URcKcDqRniq
0xy1WSSFycYxxVNzliazwy3ZrNkZrM1//kCXX/XJ/wD0E1pmszX/APkCXX/X J/8A0E11T+Ei
O50tp/x5wf8AXNf5VNUNp/x5wf8AXNf5VNWBYUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAVNUGdJvF9YHH/jpp0HlpAi71GB60t9MlvY zzSDcqRsxX+9
gdKy49U0q4P7u6APoVI/mKlyaCyZr7ov+eif99Ubov8Anon/AH1VJEgkGUnQ j2YUNLZwD95M
n86n2jDlRdymM7lx9aR2CqxfAQDOaypPEGlwk5uMn0CE/wBKo3fiOylt5FWY 5KEAeW3PH0qJ
c09xpJbGzJOrqNp+XFQlh61l2sks0abVIG0da0EiKj5jk12QVlZEPzHGszX/ APkCXX/XJ/8A
0E1pmszX/wDkCXX/AFyf/wBBNOfwijudLaf8ecH/AFzX+VTVyWR/euPwvJ1H 5B8D8KMj+9c/
+Btx/wDHK5+ZGljraK5LI/vXP/gbcf8AxyjI/vXP/gbcf/HKfMgsdbRXJZH9 65/8Dbj/AOOU
ZH965/8AA24/+OUcyCx1tFclkf3rn/wNuP8A45Rkf3rn/wADbj/45RzILHW0 VyWR/euf/A24
/wDjlGR/euf/AANuP/jlHMgsdbRXJZH965/8Dbj/AOOUZH965/8AA24/+OUc yCx1tFclkf3r
n/wNuP8A45Rkf3rn/wADbj/45RzILHW0VyWR/euf/A24/wDjlGR/euf/AANu P/jlHMgsdbRX
JZH965/8Dbj/AOOUZH965/8AA24/+OUcyCx1tFclkf3rn/wNuP8A45Rkf3rn /wADbj/45RzI
LHW0VyWR/euf/A24/wDjlGR/euf/AANuP/jlHMgsdbRXJZH965/8Dbj/AOOU ZH965/8AA24/
+OUcyCx1tFclkf3rn/wNuP8A45Rkf3rn/wADbj/45RzILHW0VyWR/euf/A24 /wDjlGR/euf/
AANuP/jlHMgsdbRXJZH965/8Dbj/AOOUZH965/8AA24/+OUcyCx1tFclkf3r n/wNuP8A45Rk
f3rn/wADbj/45RzILHW0VyWR/euf/A24/wDjlGR/euf/AANuP/jlHMgsdbRX JZH965/8Dbj/
AOOUZH965/8AA24/+OUcyCx1tFclkf3rn/wNuP8A45Rkf3rn/wADbj/45RzI LHW0VyWR/euf
/A24/wDjlGR/euf/AANuP/jlHMgsdbRXJZH965/8Dbj/AOOUZH965/8AA24/ +OUcyCx1tFcl
kf3rn/wNuP8A45Rkf3rn/wADbj/45RzILHW0VyWR/euf/A24/wDjlGR/euf/ AANuP/jlHMgs
dbRXJZH965/8Dbj/AOOUZH965/8AA24/+OUcyCx1tFclkf3rn/wNuP8A45Rk f3rn/wADbj/4
5RzILHW0VyWR/euf/A24/wDjlGR/euf/AANuP/jlHMgsdWyqwwwB+oqMwxf8 8k/75Fcxkf3r
n/wNuP8A45SZX1uf/A24/wDjlHMgsdN5MY/5Zp/3yKa0Uf8AzzX8q5v5fW4/ 8Dbj/wCOUfL/
ANPH/gbP/wDHKfOhWZ0Bij/55p/3yKYYo/8Anmv5Vg4T/p4/8DZ//jlG2P0n /wDAyf8A+OU/
aIOVm7gAcAD6Uw1i7I/Sf/wMn/8AjlJsi/uz/wDgZP8A/F1XtULkZsGszX/+ QJdf9cn/APQT
UXlw/wB2b/wMn/8Ai6q6kka6VeFVkB8h/vTyP/CezMRSdRNWBRaZboorkvFF pO2peRCm6LXL
ZdMnJIyoVyx2ejeTJdNk5GY0HXhsTQ62ivO/7QuWa217VWSxkef7JPLDGr+S tvZ3LSsgYOQy
ztOuRnKoByCSz21+5GiRPH4lhY3Fy7reS3lrHHAqquIJJlheMyndv2hOgYBi EyxYR6DTEmil
eVI5Edom2SKrAlGwGwfQ4YH6EetcJpviDWdQ0O81eW9SKPdZp5cUKhbdJorZ 5pdzZ4QSOw3c
L8xbcMBc9daazfUpLPxD9rtpdRYma2mtjeXbC2tgqwqU8qTBJBUANwuCTlWL AenUVSsZ/Nu9
ST7X5/lXITy/L2+R+6jbZn+LO7fn/bx2q7QMKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAqrqf/ACCrz/rg/wD6CatVV1P/AJBV 5/1wf/0E0AWq
hmvLa3cJNcQxsRkB3AOPxqasy106y1L4gxQ39nb3US6VI4SeJXUN5qDOCOvJ /OhK4mWf7TsP
+f22/wC/q/40f2nYf8/tt/39X/Guh/4RPw3/ANC/pX/gFH/hR/wifhv/AKF/ Sv8AwCj/AMKr
lFc57+07D/n9tv8Av6v+NH9p2H/P7bf9/V/xpl7Y6VPf3Npo/hnQSlpxcXV1 aRiNW/ujGOnc
5psNhpS3ccNx4f0KSXciiGCwX98rByGU7SOigj5tuN24qfu5TqQhuEJc7aiS /wBp2H/P7bf9
/V/xo/tOw/5/bb/v6v8AjWrqWi+FdMt1kk8O6bLJI4jgt4rKIyTyEEhEBAGc AkkkAAFmIUEj
Lii8OrqMNtqPgyx0qN7S5unkvobUeWkJhBY+WXXafOPJYY2HjBzWvKFxP7Ts P+f22/7+r/jR
/adh/wA/tt/39X/GrskHw+h0uHVJYvDCafM+yK7ZbcRO3PCv0J+VuAex9KsR 6T4Jm1SbS4tP
8PvqEKb5bRYYTKi8csmMgfMvJHcetHKFzK/tOw/5/bb/AL+r/jR/adh/z+23 /f1f8a6H/hE/
Df8A0L+lf+AUf+FH/CJ+G/8AoX9K/wDAKP8Awo5Quc9/adh/z+23/f1f8aP7 TsP+f22/7+r/
AI10P/CJ+G/+hf0r/wAAo/8ACj/hE/Df/Qv6V/4BR/4UcoXOe/tOw/5/bb/v 6v8AjR/adh/z
+23/AH9X/Guh/wCET8N/9C/pX/gFH/hR/wAIn4b/AOhf0r/wCj/wo5Quc9/a dh/z+23/AH9X
/Gj+07D/AJ/bb/v6v+NdD/wifhv/AKF/Sv8AwCj/AMKP+ET8N/8AQv6V/wCA Uf8AhRyhc57+
07D/AJ/bb/v6v+NH9p2H/P7bf9/V/wAa6H/hE/Df/Qv6V/4BR/4Uf8In4b/6 F/Sv/AKP/Cjl
C5z39p2H/P7bf9/V/wAaP7TsP+f22/7+r/jXQ/8ACJ+G/wDoX9K/8Ao/8KP+ ET8N/wDQv6V/
4BR/4UcoXOe/tOw/5/bb/v6v+NH9p2H/AD+23/f1f8a6H/hE/Df/AEL+lf8A gFH/AIUf8In4
b/6F/Sv/AACj/wAKOULnPf2nYf8AP7bf9/V/xo/tOw/5/bb/AL+r/jXQ/wDC J+G/+hf0r/wC
j/wo/wCET8N/9C/pX/gFH/hRyhc57+07D/n9tv8Av6v+NH9p2H/P7bf9/V/x rof+ET8N/wDQ
v6V/4BR/4Uf8In4b/wChf0r/AMAo/wDCjlC5z39p2H/P7bf9/V/xo/tOw/5/ bb/v6v8AjXQ/
8In4b/6F/Sv/AACj/wAKP+ET8N/9C/pX/gFH/hRyhc57+07D/n9tv+/q/wCN H9p2H/P7bf8A
f1f8a6H/AIRPw3/0L+lf+AUf+FH/AAifhv8A6F/Sv/AKP/CjlC5z39p2H/P7 bf8Af1f8aP7T
sP8An9tv+/q/410P/CJ+G/8AoX9K/wDAKP8Awo/4RPw3/wBC/pX/AIBR/wCF HKFznv7TsP8A
n9tv+/q/40f2nYf8/tt/39X/ABrof+ET8N/9C/pX/gFH/hR/wifhv/oX9K/8 Ao/8KOULnPf2
nYf8/tt/39X/ABo/tOw/5/bb/v6v+NdD/wAIn4b/AOhf0r/wCj/wo/4RPw3/ ANC/pX/gFH/h
Ryhc57+07D/n9tv+/q/40f2nYf8AP7bf9/V/xrof+ET8N/8AQv6V/wCAUf8A hR/wifhv/oX9
K/8AAKP/AAo5Quc9/adh/wA/tt/39X/Gj+07D/n9tv8Av6v+NdD/AMIn4b/6 F/Sv/AKP/Cj/
AIRPw3/0L+lf+AUf+FHKFznv7TsP+f22/wC/q/40f2nYf8/tt/39X/Guh/4R Pw3/ANC/pX/g
FH/hR/wifhv/AKF/Sv8AwCj/AMKOULnPf2nYf8/tt/39X/Gj+07D/n9tv+/q /wCNdD/wifhv
/oX9K/8AAKP/AAo/4RPw3/0L+lf+AUf+FHKFznv7TsP+f22/7+r/AI0f2nYf 8/tt/wB/V/xr
of8AhE/Df/Qv6V/4BR/4Uf8ACJ+G/wDoX9K/8Ao/8KOULnPf2nYf8/tt/wB/ V/xo/tOw/wCf
22/7+r/jXQ/8In4b/wChf0r/AMAo/wDCj/hE/Df/AEL+lf8AgFH/AIUcoXOe /tOw/wCf22/7
+r/jR/adh/z+23/f1f8AGuh/4RPw3/0L+lf+AUf+FH/CJ+G/+hf0r/wCj/wo 5Quc9/adh/z+
23/f1f8AGj+07D/n9tv+/q/410P/AAifhv8A6F/Sv/AKP/Cj/hE/Df8A0L+l f+AUf+FHKFzn
v7TsP+f22/7+r/jR/adh/wA/tt/39X/Guh/4RPw3/wBC/pX/AIBR/wCFH/CJ +G/+hf0r/wAA
o/8ACjlC5z39p2H/AD+23/f1f8aP7TsP+f22/wC/q/41t3PhPw55IA0DSxl0 GRaRg4LD2rn3
0rw5E8SSaFo6NK2yNWgALtgtgc8nCk/QH0pNWHcnjv7OWRY47uB3chVVZASS egAqxWHJZafZ
+MPDP2HTbK0L3Mm8wQhS2Imxk9cc1uUmAVV1P/kFXn/XB/8A0E1aqrqf/IKv P+uD/wDoJoGW
qq6R/wAlHT/sES/+jo6tVV0j/ko6f9giX/0dHTjuJnX3gDvbRs7KJJGU7ZCh P7t+hDA+/Gem
cDG4Oazibdl5/mznE7jru9+PvH6YH90YLhts9oN2N0pGN2M/Ixx94Z/JunTj IsVZJ5lrNuNI
udbsNUF1HYapOLmC8g52NndtOSO/GM9qseDtPEuuQ3WmpdLpdtGQ01ycmeQr tO3rgdCQDj5R
+G3qHia9m1uTSNDgtpbiEfvHuHwCe6qMjOO/Pr6UWniK9e4jjnNtJOsixNBb hj5hO/JU4IyN
nHzY4bcQemdWCopSn1Mo4a8rp7GtrWmzXwsrm0aMXmn3H2q3SUkRyN5bxlHI BIBWRwGGdpwc
MAVOHqOj+JNXuoL6QWOn3ENpcW+y2vZJPMV5bZ9vmeUjR7lhkQsoLJuVlyeB ua9rQ0Gwju2s
Lu9D3EVuI7Ux7g0jhEJ3uowWZV6/xA9MkV7zxfoNrb6q6anaXc+l281xdWlr Okk6LEPnBTdk
EHjnHJAOK0NTk7fwVr9u09za+RZalNdyPDejWZ7l7ON4reNsiWIi5yYclJMA YUKwOGXpNE0b
UtO16+m3x2ukyvNItml01wJZpJN5m+dFMJ+9mNWZCXJGCCW0F8S6CyWTrrem lL9ylmwukxcM
GCkR8/OQxAwM8nFZ/iDxlpui28RjvNNknluPs4+0XywwxNiUkyyYYoMwSqPl OXXbxyQAdJRV
OPVtNm1SbS4tQtH1CFN8tosymVF45ZM5A+ZeSO49ap/8JZ4b/s7+0f8AhINK +w+b5H2n7bH5
fmY3bN2cbsc464oA2KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KAK97IkVsZJH
VER0ZmY4AAYZJNeQ+I/CWieJ9Xg1K88SX0Utvj7MlteRIkBGDlPlJDEgHOc8 DsAB61qlpb31
g1tdwRzwSOgeORQysN46g1yH9iaB/wBC7pX/AIDipY0ZvnRSeKvCscd4t00c 7q8m5SzHyjy2
0AAnHYAegrerDkstPs/GHhn7DptlaF7mTeYIQpbETYyeuOa3KTGFVdT/AOQV ef8AXB//AEE1
aqrqf/IKvP8Arg//AKCaQy1VXSP+Sjp/2CJf/R0dWqq6R/yUdP8AsES/+jo6 cdxM6+8Ad7aN
nZRJIynbIUJ/dv0IYH34z0zgY3BzWcTbsvP82c4ncdd3vx94/TA/ujBcNtnt BuxulIxuxn5G
OPvDP5N06cZFirJPKbqyPhT4jS63qH2n7AzyTxPFHuVy4IKkkgKQWP5D14m8 CaXeTeJ7jUoZ
bg6UrSSK0sezzHcYAAyc4B5wccCu11zWRF4e1K5024R5YLZ5FmjKuqMBx7E+ 3Pv1GaNt4huG
e0RikrlYlMYVt05dWJcfLgZ25HIAG7dtP3dquMUad5Lf3RxvKXKuxd8V2Gpa lpMMGlxWkk6X
ttcMLqdol2xTJLgFUc5JQL0/iJ7YOHqfgi81Tw8mktdQQ7tQ1K4klALbY7lL tVwMDLD7ShIy
Bw3PTPYX1xLaWck8NlPeyLjEEBQO+SBwXZV468kdPXis/TfFGj6nFpfl30EN 1qdol5bWU0qL
O0bLuB2ZycAHOMj5TzxWIjm9a8I6pr1695d21oHvbJLG6t01e6jihVXlO7ES p9pDLLyj+Xja
QG+YkaFh4Umsn051Fojw67e6pcsmQZVmW5VO3LhZogc9lIBOBnoDq2mrbpcN qFoIHt2ukkMy
7WhUAtIDnBQBlJboNw9ar3PiHTYfDV14gguY73T7a3luDJaOsgdYwSwUg4J+ Ujr1oA4/XvA2
s69qMiXF3H9nke7zeNfzsVjlt5okVbPHlKU81RuDAsEJOC5FaGsaFrmtXFjq VxZ2kV3aJPAL
W11y5t1ZJDE28zxxK+QYseXtIO4HdkAVsW3imyZ54dTjk0a4gRZGh1CWJT5Z WRg4ZHZCMQyn
G7IEbEgDBNx9d0eO8urOTVbFLq0iM9zC1wgeGMAEu65yq4IOTxyKAJNJsF0r RrHTkEYS0t44
F8tWC4VQvAZmIHHdifUnrVysu08RaVdPYQfb7SO8vrdbmCza5jaV0KlsqFYh hgNypI4OCRzV
O+8b+G9PnSKfWbH/AI+/sc7i6j22smyRwJSW+TPlMozzuwMdcAHQUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQBDc/6pf8Aron/AKEK5aupuf8AVL/10T/0IVy1TIpG Tef8jj4X/wCv
mX/0Ua1qybz/AJHHwv8A9fMv/oo1rVL2AKq6n/yCrz/rg/8A6CatVV1P/kFX n/XB/wD0E0DL
VVdI/wCSjp/2CJf/AEdHVqqukf8AJR0/7BEv/o6OnHcTOvvAHe2jZ2USSMp2 yFCf3b9CGB9+
M9M4GNwc1nE27Lz/ADZzidx13e/H3j9MD+6MFw22e0G7G6UjG7GfkY4+8M/k 3TpxkWKsk4G6
W31GE6Zst2ht7u48xXD7UHmOFX5HXt/D0xyccZtlrya5s47eSxkuIiTDELQh QAMc/P8AKgO0
/VVxk4Bt+LRYW1pcy/2bZPqM1tK8NxcW6MpdAMKSeS2CSF5yEb0qDwPeK1ms EtjDBfSebJL5
ESLsRZNqLLtC4Y5YD5RnY5xxWt6fLtf18yOWXNdOx0epSalFbq2l2lpcz7wG S6uWgULg8hlj
ck5xxjueeOeHbwNrMKaPYpdx3lpp76fsne/ntxHHbtEWX7MgaOUsY3YM7ZBk A6IprvL64ltL
OSeGynvZFxiCAoHfJA4Lsq8deSOnrxWfpvijR9Ti0vy76CG61O0S8trKaVFn aNl3A7M5OADn
GR8p54rIsx18I3lrBqYs7zY3yw6cplKiG13iWSEMFzDvLNFuj+7HHAQC0dV7 Twlqa+D/ABZp
kvkQ3Ws+d5CtfzXYj3W0cI3zSKHPzIT0OAQB0rrDq2mrbpcNqFoIHt2ukkMy 7WhUAtIDnBQB
lJboNw9ar3PiHTYfDV14gguY73T7a3luDJaOsgdYwSwUg4J+Ujr1oAy7jwZZ fbtHmt4vOW01
AXc739xJcyMFhmSMK8hY/K8oZRkBTuI5PNeLQ7+wvIHuPIOmabqF3qqTQmSS eYzCcmPyQnG3
7Q2CrMW2D5Ru+XUtvFNkzzw6nHJo1xAiyNDqEsSnyysjBwyOyEYhlON2QI2J AGCbj67o8d5d
Wcmq2KXVpEZ7mFrhA8MYAJd1zlVwQcnjkUAcH4d8A6hZQ6X9shjI2WE9wH1K 4UW8sEMCFPs8
Z8qU7oARIW4LD5WCANsWmga9Z6RodmsOmyP4eeMWbG7dReqsEluTJ+6PknbI HwPM5G3P8VdB
aeItKunsIPt9pHeX1utzBZtcxtK6FS2VCsQwwG5UkcHBI5qnfeN/DenzpFPr Nj/x9/Y53F1H
ttZNkjgSkt8mfKZRnndgY64AOgorD1nxHDpOs6RpbG0WfUXbY13dCBSqsisq cEvKTKu1MDdh
vmGObE3iXQbayF7PremxWhdUE73SKhZkEijcTjJQhgO4IPSgDUorLufEug2V xc293remwT2q
B7iOW6RWhUlQC4JyoJdACf7w9RRrWtDRhZKthd3097cfZ4YLUxhi3lvISTI6 qAFjbv6UAalF
Z9vq8D2ck96v9nSQxefcQXc0W+3jywDuUdlCnYxBzjg9wQIx4i0pDbpc39pa y3NxLbW8U1zG
GmdJDGQgDHcd2OByMgEA5AANSiub0/x34e1HS7XU49StIrOe3M7yzXUKi3I8 rMcnz5VwZkBA
yASASCV3aEniXQYdLh1SXW9NTT5n2RXbXSCJ254V84J+VuAex9KANSis++1m zstDk1cP9ptR
EJYvsxDm43Y2LHzhmclQoB+YsAOtU18X6DHpdlf3+p2mmpeISkd/OkLqy4Do wLcOjHaw/hII
NAG5RWXZeIdNvtb1HRormMahYOBLbs67ypSN96rnOz94q5IHII+ufB4zsnuG F1Z3djZ/aLi2
jv7pohBJJAZPMA2yFlAEMrbnVRhDzkgEA6SisPxJ4mtvDum3dwRHcXEFvJP9 mE6IxCxSyDIJ
zhvJcDaGPBOMKxFPxH470fw7cpbSXEFzdJ5r3NpDcIZ4Y47aSct5ec8iMAZw PnBz6gHUUVy9
l4wS7n0i3CWM8l/L5bS2GoLcQoClywKsAGb/AI9iDlVGWIBYqwrc03VtN1m3 a40vULS+gVyj
SWsyyqGwDglSRnBBx7igC5RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQBDc/6pf+uif+hCuWrqbn/VL/10T/0IVy1TIpGTef8A I4+F/wDr5l/9
FGtasm8/5HHwv/18y/8Aoo1rVL2AKq6n/wAgq8/64P8A+gmrVVdT/wCQVef9 cH/9BNAy1VXS
P+Sjp/2CJf8A0dHVqqukf8lHT/sES/8Ao6OnHcTOvvAHe2jZ2USSMp2yFCf3 b9CGB9+M9M4G
Nwc1nE27Lz/NnOJ3HXd78feP0wP7owXDbZ7QbsbpSMbsZ+Rjj7wz+TdOnGRY qyTlfGVpc3Fu
fsNrd3Fz9nkcqs8qxFEx8mwHaXYuAMjOAxByoFUPA+n3NqIBd2N9bLska3Uy SIiKrbMSxBtg
ZgwZc5P3ugVc9Bc6zKZZIrW3cPE7K5lUdvQbhwRzk9sdc8VP+EhnF7HGyIG3 JH9nAbdJuDfM
DgqD8vHzYA3biD0ipUVNJy6jiuZ2RsalJqUVuraXaWlzPvAZLq5aBQuDyGWN yTnHGO55454d
vA2swpo9il3HeWmnvp+yd7+e3Ecdu0RZfsyBo5SxjdgztkGQDoimuw1rWhow slWwu76e9uPs
8MFqYwxby3kJJkdVACxt39Kp6T4ss9V1aWxVPs7LFGVEzgO0xkuEkh29CyG1 kyVLA4JHAybE
Z6+Eby1g1MWd5sb5YdOUylRDa7xLJCGC5h3lmi3R/djjgIBaOq9p4S1NfB/i zTJfIhutZ87y
Fa/muxHuto4RvmkUOfmQnocAgDpXSXviXQdNSN7/AFvTbVJHkRGnukQMyNtc DJ5KtwR2PBqx
qGp22mCF7uSOKKR2UyySoixhY3kLEswyAqHpkjrjAJABh3Hgyy+3aPNbxect pqAu53v7iS5k
YLDMkYV5Cx+V5QyjICncRyea8Wh39heQPceQdM03ULvVUmhMkk8xmE5MfkhO Nv2hsFWYtsHy
jd8vSabq2m6zbtcaXqFpfQK5RpLWZZVDYBwSpIzgg49xWPo3jOy1ZLN57O70 xL63W5s2vmiA
uI2ZFBXZI2DuliG1tpJkAAPOADl/DvgHULKHS/tkMZGywnuA+pXCi3lghgQp 9njPlSndACJC
3BYfKwQBti00DXrPSNDs1h02R/DzxizY3bqL1VgktyZP3R8k7ZA+B5nI25/i rpE13R5Ly1s4
9VsXuruIT20K3CF5oyCQ6LnLLgE5HHBqvb+KdEngs5TqljGt9K8Vnuu4j9pK vs/dlWIfJxwD
kbgCAeAAST6bNL4q0/VFaPyLeyubd1JO4tI8DKRxjGImzz3HXtz+meF9S8Pa X4a/sy302a70
vTHsZ7dpmgidpPJaSVXWNiTvhJwUG7eSSCMHY1bxfoOjGdLvU7Tz7d4RcQLO nmQLJIkYd1LA
qgMiEk9Ac88VsQTw3VvFcW8sc0EqB45I2DK6kZBBHBBHOaAOL0LwReaIdMi+ 1QTQ2OoRXG/B
VnjTTBafdwcMXG7GSNvfPFF34QvJPB/hPSpLLStTk0fyftNteyEQTbLaSE4P lv0Zwwyvbsa7
iigDk7nQdSvU0uX+z9Gs30tA9vaxu0sTsG4iLeWmyIKkbDCnEgjbb+5Akp2f hTWLHWIrm0lg
tWe7mkuryO7djLbtdzTiA27RlDlZceYGV1LNgkDD9xRQB5+PBesNbeHrV3sV j0WKK1WQTOTP
HHc2UgcrsGxittJlcsASo3EEkSarY6h4c8RXfiaCGO9NxcSRx2qpcMdkkFqp ZjDDKwIa0Ixt
wQ4+YHg95RQBxcPhfU7vwL4U0WS7k057JLNr/wAoxtIDDFuVULK6kiZIiexC nnnBk0DwnqOj
eIftM2o/bLGL7b5LTbRN/pL20rbgiKv+tjuD7BkA9B2FFAHJ+CfDupeF7QWN wbSaB7e3aSaO
VtyTR28MBQKVwyEQ7t+4H5sbeM1ht8PLy7/tO3a30rTvtkuotJqlqxe5uo7n zgscq7E+VfOR
seYwzCvHQr6RRQB5v4h8HeJPE9ze3VzHpVlJNafZo447ySYcW19HuLGJcfNd pxg8Kx64Bk13
wbr2o6bNo1uNNFn9o1G6jupLlxIzXUVyAhjEZACtc43bzkJnGTtHolFAHD+K /BF54k1qedLq
CC1ntFtmYgs6fuL6IsFxg83cZAyM7W6cZ1PC+hXGl3F7eXcEcM9ykUW0anc3 7FULkZlnwQMy
HChRjk5bdhekooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKAIbn/AFS/9dE/9CFctXU3P+qX/ron/oQrlqmRSMm8/wCRx8L/ APXzL/6KNa1Z
N5/yOPhf/r5l/wDRRrWqXsAVV1P/AJBV5/1wf/0E1aqrqf8AyCrz/rg//oJo GWqq6R/yUdP+
wRL/AOjo6tVV0j/ko6f9giX/ANHR047iZ194A720bOyiSRlO2QoT+7foQwPv xnpnAxuDms4m
3Zef5s5xO467vfj7x+mB/dGC4bbPaDdjdKRjdjPyMcfeGfybp04yLFWScJr7 3tvPdzXUb20c
krNC8Y4lKqduSGODhVI6ZPbji1DDqM0iz2ls00aNmOWRBuxuyACXUspAQ553 dzxWhqPiHTXn
W0E8waOfEu20d9pXOMZQg4YLyKqJrV02ookUk8hMirEkkOxHQ7gSx+UjnZk7 cqdoAbd82WMc
mo3vFLTTzsFDlu7NM0PEWgnXpdHVpZI4LS9NxMYriSCQr5E0YCPGQwO6Rc8j jP0OPc+D7m08
QQ6ro6WhSzS3MFtPM6+c6i8WQySbWIJ+1795DFmVs4zuroNa1oaMLJVsLu+n vbj7PDBamMMW
8t5CSZHVQAsbd/SjTvEOm6kkQS5jiuHdozazOolWRWkVkKgnJDQzDKkg+WxB IGa1A871jRdf
0jRdWto7GC8v/EVpdWrQwNO6W7PPcypiRYCpz9rxmTylGzO7BJXpPF3gmXWd Pmi024kWed7h
5Ptt7NIgMlpcQrsViwQbp1JCgDA9gK6CPxLoM2lzapFremvp8L7JbtbpDEjc cM+cA/MvBPce
tV9F8U6brOk3GordWkcEDzl2FyrKIY5pY1mLcAIwiZgenB5OM0AWINNmi8Va hqjNH5FxZW1u
igncGjedmJ4xjEq457Hp35e2+HUEXgzTdKmSO5vIksY7pru5luIikUsLzJGJ MhEYRn5VVQcI
CAAMdBq3i/QdGM6Xep2nn27wi4gWdPMgWSRIw7qWBVAZEJJ6A554q5dazZ22 nQXkb/aludot
EtiHa6ZhuUR84OQCc5ChQWJCgkAGHeeHdSm1S8jiNp/Z99qdrqUs7SsJYmg8 j92se0hw32df
mLrjzD8p2/NzcXge+1OO5u2gzDqf2iOSG4v7m08qF7u5lR3iix525LgZicoV 27cgs23uP+Ej
tbTTvtuuJ/YMZl8pRqdxAm84yMMkjLzzxnPynjFWP7d0f+2P7I/tWx/tP/ny +0J533d33M7v
u89OnNAHPv4e1gafdaXGli1quoHU7a4a4cPJJ9sF0Inj8shFzlN4ZjwG287R 1kBma3ia4jjj
nKAyJG5dVbHIDEAkZ74GfQVzfh7xtYa7py35msYrWSKW5V0vo5PJiQRk+cDg xyASjco3KmOX
5XOxp+u6Pq+P7N1Wxvc7sfZrhJM7du77pPTemfTcvqKANCis9Nd0eSJpU1Wx aNIjOzi4QhYw
qOXJz90LJGxPTDqehFUz4v0H7bpduup2jpqiSmzuEnQxTNG6IUVt3zOWkAAG fut6UAblFZdp
4i0q6ewg+32kd5fW63MFm1zG0roVLZUKxDDAblSRwcEjmpNM13R9b83+ydVs b/yceZ9kuEl2
ZzjO0nGcHr6GgDQooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigCG5/1S/wDXRP8A0IVy1dTc /wCqX/ron/oQ
rlqmRSMm8/5HHwv/ANfMv/oo1rVk3n/I4+F/+vmX/wBFGtapewBVXU/+QVef 9cH/APQTVqqu
p/8AIKvP+uD/APoJoGWqq6R/yUdP+wRL/wCjo6tVV0j/AJKOn/YIl/8AR0dO O4mdfeAO9tGz
sokkZTtkKE/u36EMD78Z6ZwMbg5rOJt2Xn+bOcTuOu734+8fpgf3RjNm1ndc W4SzuSPtMkMZ
8yJfOdQ4KqDKpP3WbBB4UnHGRpWV2t7bCZY5I/ndCkmNylWKkHBI6g9DVknD SHSmvis40WKU
6jcCSScqz4zL99Djjpg7vSrtm1v/AGpLDYNazoTaszafD+7XErE7tpYA4Gck jit+bV5A0jQW
vnQxMyE7iHcqcMFUKQecjkrkg9sE2bfU7W6n8iMyiTaXCyQOmQCASNwGeo/O so1VK0ebb/hh
+ya96xn+ItBOvS6OrSyRwWl6biYxXEkEhXyJowEeMhgd0i55HGfocu68C288 uuRwCC3hv9EX
S4ZypkmiLNO0rMTy24yoxJbLspLc810mpalDpluskiySySOI4LeIAyTyEEhE BIGcAkkkAAFm
IUEinZa8bnUYLC60q+0+6nimmRLkwtlIjECcxyOOTMuP91s44zqIw59A1671 uPxFLDpseoW7
wiKxW7dopFjS5TLTeUCpP2tjgRt/qwM/NlcuTwd4kTRdbghj0p7rXLS5trhX vJFS18ye6lVl
YREycXWCCExs77uOk0vxhFrYtZNL0jUrq3lSFpZ18lFtjLGkoVw0gYkJIjHY GHzYBJBA6SgD
j38PawNPutLjSxa1XUDqdtcNcOHkk+2C6ETx+WQi5ym8Mx4Dbedo2NT0+81C 1027UQRanYSi
6jiMhaFpDE8bIX2htpWRwG25B2ttOCh2KKAOXmtfEkuo2Ws/2fpQvraKe1+y f2hJ5bRymFt/
m+RkMDDjbswQ2dwxg5+meCLzS/Dz6St1BNt1DTbiOUgrujtktFbIwcMfszkD JHK89cdxRQB5
/deEL+30Hw7ulgaTQdKSORUEj+bLFLaTBVCqWKt9lZchSw3AhWPFR6FZeIbn VrzxVHplpHcT
3EyJZ3VxNArRPDaKZAzQiQENakbWiXO4kHABb0SigDg/D/grUtE8L39ok9pH qdwlmhngdlMk
cFtBE0RkCh0DGOYB1BKCTcBu4o8P+E9Z0fWzqzR2heW4lV7d9SnuCkMqWql/ OkTe7g2pwhAB
Dgbht57yigDz/R/BesabpNpo8j2L2rS6fdXNysz745LWO3UokezDqxtR8xZS PMPynb82xoPh
u80v/hGPPkgb+ytEfT59jE7pD9mwVyBlf3LcnB5HHXHUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAQ
3P8Aql/66J/6EK5aupuf9Uv/AF0T/wBCFctUyKRk3n/I4+F/+vmX/wBFGtas m8/5HHwv/wBf
Mv8A6KNa1S9gCqup/wDIKvP+uD/+gmrVVdT/AOQVef8AXB//AEE0DLVVdI/5 KOn/AGCJf/R0
dWqq6R/yUdP+wRL/AOjo6cdxMTVfDgv9Q0+W6g1dHtb+eVRa6iYVnVhPgKFn Ta2JdxYDdhSp
4JrptOsWNkxuUnhkklmcxicgqGkkI+42M4ft3x3AxDNrO64twlnckfaZIYz5 kS+c6hwVUGVS
fus2CDwpOOMjSsrtb22EyxyR/O6FJMblKsVIOCR1B6GrJOPla8jurq1uLW/j iW5lcGCCVvND
OzKQ6A4GCOhzng4wQZbTS21G5HkDUrYqCHuZZJ42RSRkJvIyTgewxk9ADvTa vIGkaC186GJm
QncQ7lThgqhSDzkclckHtgmzb6na3U/kRmUSbS4WSB0yAQCRuAz1H5150cPR dS/P8jrdWaj8
JX1rTZr4WVzaNGLzT7j7VbpKSI5G8t4yjkAkArI4DDO04OGAKnH13QNS8WaC lrqcNpZXCXBA
W2u2mQwyRtDKdzRKQ/lTS7RtxuCEkjIrY1rWhowslWwu76e9uPs8MFqYwxby 3kJJkdVACxt3
9KF16yhSyXVHj0m7vXKQWd9cRLK7BgMKFdgxOV4Un7w78V6JyGXq+h3mqeIb a6XTNKg+zywt
Hq4mJvFjRw7RhfKGFf54yPMxtdjg5KnqK5fTPHmiXOi2Woanf2OktdRRSLHd 3sQyWhjlIBLA
nAlUchT0OMFSdyTVtNh1SHS5dQtE1CZN8Vo0yiV155VM5I+VuQOx9KALlFU9 N1bTdZt2uNL1
C0voFco0lrMsqhsA4JUkZwQce4rm7X4j6PeaPo+ox218P7Uu47VLYonnQb2V VklXd8sf7yI7
ueJo/wC+KAOworPi13R5vt3larYyf2fn7btuEP2bGc+Zz8mNrdcfdPpWXZeO NBuYdRu5dV02
DT7W9FnFetep5U7GGOX5WyBn52XAJ+4T7AA6Siuf/wCEusINT1O11CSCxhsJ TG1zPcxohAjt
3ydxBHNyq8AjjkgsoNyTxLoMOlw6pLrempp8z7IrtrpBE7c8K+cE/K3APY+l AGpRWPqfiKCx
tdNntbWfVP7SlEVqti8R8zMTy7gzuq7dkbHOeeMdasWmrwT+TFcr9gvpeljc zRGYZ37eEdgc
iJ2GCeFb0OADQorH/wCEs8N/2d/aP/CQaV9h83yPtP22Py/Mxu2bs43Y5x1x Vh9d0eOzuryT
VbFLW0lMFzM1wgSGQEAo7ZwrZIGDzyKANCiqaatpsiI6ahaMjpE6sJlIZZW2 xEc8h2GFP8R4
Gajm13R7eW2im1WxjkupWgt0e4QGWRW2Mign5mDfKQOQeOtAGhRWPc+IrOPU 9NsbaWC6ku7t
raQRzAmHEc7biBn+K3dMcchu6kVqQTw3VvFcW8sc0EqB45I2DK6kZBBHBBHO aAJKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKAIbn/AFS/9dE/9CFctXU3P+qX/ron/oQrlqmRSMm8/wCRx8L/APXzL/6K Na1ZN5/yOPhf
/r5l/wDRRrWqXsAVV1P/AJBV5/1wf/0E1aqrqf8AyCrz/rg//oJoGWqq6R/y UdP+wRL/AOjo
6tVV0j/ko6f9giX/ANHR047iYmq+HBf6hp8t1Bq6Pa388qi11EwrOrCfAULO m1sS7iwG7ClT
wTXTadYsbJjcpPDJJLM5jE5BUNJIR9xsZw/bvjuBhralNcSK9vpt5JHDO6ll aMB9u5DjMg7+
oPTpnBF6yu1vbYTLHJH87oUkxuUqxUg4JHUHoask4+VryO6urW4tb+OJbmVw YIJW80M7MpDo
DgYI6HOeDjBBltNLbUbkeQNStioIe5lknjZFJGQm8jJOB7DGT0AO9Nq8gaRo LXzoYmZCdxDu
VOGCqFIPORyVyQe2CbNvqdrdT+RGZRJtLhZIHTIBAJG4DPUfnXnRw9F1L8/y Ot1ZqPwmP4w0
GbXYdLEWn6bqCWd79oltNRcrFKvkyx4z5b8hpFYZX+HtUdhpmsWGrQ30OnaV FHPaW9lcWkV2
6paRwySlTERD+8ysv3SIwNgGSDkamta0NGFkq2F3fT3tx9nhgtTGGLeW8hJM jqoAWNu/pUlv
q8D2ck96v9nSQxefcQXc0W+3jywDuUdlCnYxBzjg9wQPROQ8/wBB8MeJPCut aWttZ2N9INPk
jkd7mSKFNsGnQ8uIm+YtbuQuOV5yCCKuR/D/AFKHT5tFtb6Oz0+bTPsV3crM 0pvWFoLdXa3Z
cQlcBsxyfMEAYHIKdo+u6PHeXVnJqtil1aRGe5ha4QPDGACXdc5VcEHJ45FR w+JdBuULwa3p
sqC3a6LJdIwEKsVaTg/cDAgt0BBFAGf4X0K40u4vby7gjhnuUii2jU7m/Yqh cjMs+CBmQ4UK
McnLbsLl2ngL7LoOlxKYP7Tt4tLinfP7v/RpYnkZDt3bnWJVJP3hFEDjaMbg 8U6bdS6WNLur
TUYL69azaa1uVdYmWCSbkrkE4jAxx94H66Gm6tpus27XGl6haX0CuUaS1mWV Q2AcEqSM4IOP
cUAcWngvWHsdKtpXsU/sK0itrJlmdvtnlzW0oaQbB5OfsijA8zHmE87cNHP4 P1y71a41u4ht
Bdy3ErCztdZubZQjw2qbjPHGrkg2v3NmDvBzlRnUPj9U8ODX5PDWuLYSRQyw Mq28j3HmuiRq
iJMW3HzAcEDoe+AZNQ+IOlWWpCxt7e71F3t4p4pbLy3ilMksUSxq5cDf+/hf BwNjq2eRkAw4
/h3f22o27wTWK2sEtuUVTIuEjOm8AHcRxYy4BZvvJknJIuarY6h4c8RXfiaC GO9NxcSRx2qp
cMdkkFqpZjDDKwIa0IxtwQ4+YHg9JJrxtPD2oazqOlX1jHYxSTPBMYWkdETc SvlyMvPIGWHI
7DmqcHjXTbi/0OyjguzPqyOQuxf9EZUZik/zZR8xyrjn5opB/CaAM+18Itfe EvBematZWkqa
WkLX1rdKsqkraSRbQMFWId1PpwSD0zci8IpY6tqV1o8djpfm6VHY2MsFspNq 4knd2CYC7S0k
bYz8xXnoDWpH4l0GbS5tUi1vTX0+F9kt2t0hiRuOGfOAfmXgnuPWqel+MdH1 CxtbmXULG2+2
3dxbWStdoftXlzNEGjPG/dhTgZ++Bz1IBz+k+DdWg8VW+r3KQQQxSwsYjq1x fuQkN4hIeZAR
zcphenysepwa/wDwr/U1tdIJmgkm03T9Pt/KivZrbzZIIrqN/wB9Gu9Fxchg QCTtKkAHNdha
eIbeXRbjU7pfs0MN3cWxAJkLGOd4V2gDLM5UYUAklgoyepb6+oikl1awn0SN fuPqM9uBJhWd
tpjlf7qozHOOAT0BwAc3D8PSxhSS5ktYJbd/tS2t1I7rMJJXhZXk3M5VrqZy 7YJkjhdVXBWo
28F6wmmX9rG9i8muae1rqUjTOotZJJLiSR4V2HzF3XT7VYoQEUFiWJHaR6tp s2qTaXFqFo+o
QpvltFmUyovHLJnIHzLyR3HrWXceN/Ddva2l5/bNjLY3N2bP7ZFdRtDFIImk w77sLwmPXLLx
zQBjzeAvtenW9nKYIlOt3uo3bwHDSLMLlUzlcOwEsQZXBUqpU7l4PYWP2z7H GL/yDdDIdoM7
GwSAwB5XIwduTtzjc2NxpjxFpSG3S5v7S1lubiW2t4prmMNM6SGMhAGO47sc DkZAIByBJa67
o99qM+nWeq2NxfQbvOtobhHkj2na25QcjBIBz0NAGhRWPN4ks4Ptu6Oc/Y9Q t9Pkwo5km8na
Rz90eemT14bg8Zjk8WaVb399a3lxHZpZOUmuLqaOKMEJA3GWyQftMYzjAOQc ZXcAblFZa+Jd
BZLJ11vTSl+5SzYXSYuGDBSI+fnIYgYGeTipJtd0e3guJ59VsYobbHnyPcIq xZdoxuJPy/Oj
Lz/EpHUGgDQorn9L8Y6PqFja3MuoWNt9tu7i2sla7Q/avLmaINGeN+7CnAz9 8DnqegoAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKAIbn/VL/
ANdE/wDQhXLV1Nz/AKpf+uif+hCuWqZFIybz/kcfC/8A18y/+ijWtWTef8jj 4X/6+Zf/AEUa
1ql7AFVdT/5BV5/1wf8A9BNWqq6n/wAgq8/64P8A+gmgZaqrpH/JR0/7BEv/ AKOjq1VXSP8A
ko6f9giX/wBHR047iZbuNJjlmxeWetiQzzCM2erPbJIGkeQYVJ0ycEnJGePQ VtadYsbJjcpP
DJJLM5jE5BUNJIR9xsZw/bvjuBi5cNtntBuxulIxuxn5GOPvDP5N06cZFirJ OHla8jurq1uL
W/jiW5lcGCCVvNDOzKQ6A4GCOhzng4wQZbTS21G5HkDUrYqCHuZZJ42RSRkJ vIyTgewxk9AD
2dV7Bt+nWzbt2YlO7duzwOc7mz/30fqetcSwMefmbZ0PEO1kjD8YaDNrsOli LT9N1BLO9+0S
2mouVilXyZY8Z8t+Q0isMr/D2qvc6DqV6mly/wBn6NZvpaB7e1jdpYnYNxEW 8tNkQVI2GFOJ
BG239yBJv6rLJDY7opTE7TRJvUAkBpFU4yCOhPaubt9cu5Fgka7ljiuihhaR kY+WxUZZViG1
vmUDkrk8npu6KlVQvdGMYtmR4l8D6/rlzcjz4JFf7ZsuZtSnA2y208UafZQh iTZ5qKXU7iEL
HlyKk8aeFNSutH8Q3FuI5jLcXN7HDHuaR1OlNahAoHLmTnHp3zxXb6TevqGm xXMkYUuMhlBC
uP7yhgDg+4/MYJzND8WQa3FZSvp19p8eoRLNYveeVi5UrvwpjdsNt+ba21iA xAIVttxkpJSX
UTVnY5/W/BeseKLma6v3sdPkni+yvHBM9wEjFteRhwxRNzbrwfLgDCZ3EnA3 PC+hXGl3F7eX
cEcM9ykUW0anc37FULkZlnwQMyHChRjk5bdhZLjxv4bt7W0vP7ZsZbG5uzZ/ bIrqNoYpBE0m
HfdheEx65ZeOa1I9W02bVJtLi1C0fUIU3y2izKZUXjlkzkD5l5I7j1qhHD6H 4L1LTvDtlpH9
i+H7F4X097i9srhi901vPE5Lr5C8lVkIJY8nHckWNW+HcNxJZQ2UdobBHY3M Nyo/eK15aTbM
BcFFitzEoPRVjXoMjpL7Xjb3klrY6VfarNDgXAszCBASAVVmlkQbiDnaCSAV JADLmxNruj28
FxPPqtjFDbY8+R7hFWLLtGNxJ+X50Zef4lI6g0AZ+p+F7P8A4Q3WdD0OxsdP +32k8SpDEIo/
MeMoGYIPpk4JwKy/EXgGHVo5o7KWO2N5cTyXMjoD5ayWc8GIwAMjzJjKVJGW klbOWroH8S6D
HcWlu+t6as96iPaxtdIGnVzhCgzlgx4BGc9qr6F4p03XJrq0iurRdQtri4il sluVeVFimaLe
y9QGwrcjjcBk9SAY8+ga9d63H4ilh02PULd4RFYrdu0UixpcplpvKBUn7Wxw I2/1YGfmyuOf
h9qk4uHu0tJH1FJorqFNVuoYoFe5uJukQT7SNtzgq/l/cIB+ckdRP41023v9 cspILsT6SiEr
sX/S2ZFYJB82XfMkS44+aWMfxCrmm+KNH1OLS/LvoIbrU7RLy2sppUWdo2Xc Dszk4AOcZHyn
nigCnF4ambw3Pps1xHHOdTm1CGVAXVW+2NcxbgcEjOwMARn5gGHDVHcaZrGu X2jy6xp2lQQ6
dqAvAkV29zvxDMgOGhTDK7xsPoTkEDNg+MdHPiFtJi1Cxl8i0ubm9lW7Q/ZP JeNSsg/h/wBY
xySMbD+Fi38RWd9q2n2thLBeWt7aXFyl3BMHT9zJEhUYyDkynnPG3HfgA5uH wTqEGqXEsFxH
CRcXl3aX7XtxMYpZ/NwVsyRCpTziN2W3BT8oLkrXsvB+uWutnWlhtFnge3eC 1n1m5uxKUS6j
bdNLGWjGLoEAKwyh6bsj0SigDz+TwXrCW2t2sL2Lx65Fc2txI8zqbWOS5upF dVCHzG23XKko
AUxuIbI2LXw3eQf2TukgP2PW73UJMMeY5vtW0Dj7w89Mjpw3J4z1FFAHJ+If BUPiLWzcXE8i
Wk1k9vOI3AcNsmijK5UjGy7uCc9xFjgMDTPhnxBZ21hc6bPYjU47S8FwXkZU E91cwzSmIlGw
o2zbCytj93uDfNXcUUAed694P1zVPD76fbQ2kCTWUtuLZNZuYo7eVy+6ZnSP N0X3KWEoHKty
29jWpF4WvLCzt5rKKxa/t9bu9VMbOYkuPOM6KHkCEhhHMvO1v9WF6fMOwooA 4PTPCuvWeoW1
2htLG4kuJJb65t755Q8LXc0/2fyXiCOMS7fMyjqWYjgbW7yiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAhuf9Uv8A10T/ ANCFctXU3P8A
ql/66J/6EK5apkUjJvP+Rx8L/wDXzL/6KNa1ZN5/yOPhf/r5l/8ARRrWqXsA VV1P/kFXn/XB
/wD0E1aqrqf/ACCrz/rg/wD6CaBlqqukf8lHT/sES/8Ao6OrVVdI/wCSjp/2 CJf/AEdHTjuJ
nY3DbZ7QbsbpSMbsZ+Rjj7wz+TdOnGRYqvcNtntBuxulIxuxn5GOPvDP5N06 cZFirJCqNlBH
LZ20xklYtGjZE7EHhT/fYH7o7nOTydxzeqvYNv062bduzEp3bt2eBznc2f8A vo/U9aAMnX5r
ax05bRZyt1cOn2fzWaQb1ZAGJJ4UHbnkZJ7s3PLWd2tleymWaydHH+npFGHN yWwARhQHOHTI
G05LHYfMXHX6/f2GnR29xey2cRjdpEe4TeUCoSSgzknoOOefeqF3dW08ZmRt Nuorp1tZ7iOA
OACRhSQWyfm4DDbk8noDnOTgnNrRFqLZs6MzPoenu7iRmtoyXU5DHaOQe9cr pfhnxAdA0fTb
2ex06bRbQR2dzZyNcl5xbtAsrK6IAqh2bZ824lfmAUhuq0e7a+0uCdoljDKN pQEIwxwyggEL
6ZA/EYJzdG8VLq+nJqcuk32m6Y9oLxb2+kt1jMZAYE7JWZflOfmAAAOSKqDT imiWrM5uy8H6
5a62daWG0WeB7d4LWfWbm7EpRLqNt00sZaMYugQArDKHpuyND/hGdZk8Z2Op 3Esc1va3s1yZ
21GfLRtFKiRra7fKQr5irvDZYIWPLkV0C+JdBZLJ11vTSl+5SzYXSYuGDBSI +fnIYgYGeTip
Jtd0e3guJ59VsYobbHnyPcIqxZdoxuJPy/OjLz/EpHUGqEc34m8M6zcw6smh yxq+pv8AaPOb
UZ7N7W4EKwq6mFT5ibUQ7GwMqSS24BJP+EXv7XQZ7WyaBJ59Vur65jhuZLX7 WkksjKrTxr5i
MA0RJUHPlbPunNbGteJLPRvDh1wRz6hanyvKSwUSvP5rqieWMgNkuuMHntmq 6eMtHk1xtMSb
dGmnnUGvwyG1WMbMgybvvBZI3Ixja6nOCKAOLsPCXiGEa3oX2W0WDU9MME93 JezSCATXN8/y
M0eZ3VZlLbihJxk/NkdZa+G7yD+yd0kB+x63e6hJhjzHN9q2gcfeHnpkdOG5 PGdSTxLoMOlw
6pLrempp8z7IrtrpBE7c8K+cE/K3APY+lV9G8U6bqtlo7S3Vpa6hqllFeRae 1ypl2um75V4L
AYbkD+E0AV4vCkMuu3mpXojcnU1vbYJg5UW0MWyTI6eZEJAAfvRxNnK4GHo/ gvWNN0m00eR7
F7VpdPurm5WZ98clrHbqUSPZh1Y2o+YspHmH5Tt+bsNC1P8Atvw9pmreT5P2 60iufK3btm9A
23OBnGcZwK0KAPN5vA2t3djpemzmxS10fT1tLeaG9lWS6Mc1rIpbEYMG4WuC VZyhfI3bedjw
/wCFbrTNch1OVIIt0V0J4xez3b75PsoUmWb5n+W2OThcZVQDgsewooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAhuf8AVL/10T/0IVy1dTc/6pf+uif+hCuWqZFIybz/AJHHwv8A9fMv /oo1rVk3n/I4
+F/+vmX/ANFGtapewBVXU/8AkFXn/XB//QTVqqup/wDIKvP+uD/+gmgZaqrp H/JR0/7BEv8A
6Ojq1VXSP+Sjp/2CJf8A0dHTjuJnY3DbZ7QbsbpSMbsZ+Rjj7wz+TdOnGRYq vcNtntBuxulI
xuxn5GOPvDP5N06cZFirJCqNlBHLZ20xklYtGjZE7EHhT/fYH7o7nOTydxze qvYNv062bduz
Ep3bt2eBznc2f++j9T1oA4T4i6LfSxW0tib2aLyZImiSVWIbCkEbssxKocgE 5KggZJJfoFjf
aZ4f1f7f5qmYu6wzNG4C+WBk7RyT0IJIwBwOc2fiF4gl0uCO0gt45Hkgkl3S 2hlCEYVSpPy5
G49c44yMHmtper2l9amO60qzt7lrgRq/2ExgRHYNyhg2Wy2P7oJXdjKht6k5 Qw95L3Te03TS
Wx6BXneieC9S03wxBpK6L4fsZ4Es5Xu7O4YtezW0kci+aPIUgOUbLZcruzhq 7fSb19Q02K5k
jClxkMoIVx/eUMAcH3H5jBOZo3ipdX05NTl0m+03THtBeLe30lusZjIDAnZK zL8pz8wAAByR
XNGSklJdTFqzsZeraBr2rJqRaHTYX1rTBpt4BduwtFVpsSRnyh5xKzk7T5eC mNxzkR3Pgmc6
PGkCwfa49butVZYbqW0+0ea06qGniG9WEcq5IBz5ez7pyOkXxLoLJZOut6aU v3KWbC6TFwwY
KRHz85DEDAzycVJNruj28FxPPqtjFDbY8+R7hFWLLtGNxJ+X50Zef4lI6g1Q jHXwzOnhOz0q
IQRTR6hBeyDzpZFG27W4ceY5Z3bAYbjjc3OEBwM/UPAWy4s30gwRx2vmzBJT tLyfarWeOPKr
xGFthEDglECABguK6TU/EOm6VoiazPcxtp7vABcI6lNsrqivuJA2fOGJz0ye akTXdHkvLWzj
1Wxe6u4hPbQrcIXmjIJDoucsuATkccGgDm4NA1601uTxFFDpsmoXDzCWxa7d Yo1kS2TKzeUS
xH2RTgxr/rCM/LlsvRfh7faa2nxXBguI0+wyzyDUrlEjkt4oUwtsuI5cmAMH cgjcMqwQBusv
/EUlrrMml2mialqM8VvHcStatAqosjSKoPmyoScxP0B7VcfXdHjvLqzk1WxS 6tIjPcwtcIHh
jABLuucquCDk8cigCPw1ps2jeFdI0u4aNp7Kyht5GjJKlkQKSMgHGR6CtSs+ HXdHuILeeDVb
GWG5z5EiXCMsuHWM7SD83zuq8fxMB1IqSz1bTdQuLq3stQtLme0fZcxwzK7Q tkjDgHKnKkYP
ofSgC5RXH3XxH0ez0fWNRktr4/2XdyWr2wRPOn2MytJEu75o/wB3Kd3HEMn9 w10kerabNqk2
lxahaPqEKb5bRZlMqLxyyZyB8y8kdx60AXKK5u18caDd3upLFqumtp9hb28s uoLeo0QaV5F2
M2cKR5a9TzvHHroWWtw6hrNxZW/lywR2VteR3McgZZVmaUDGOMYiznJzu9uQ DUooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKAKWr2zXelzwJczWzMBiaAgOmCDkEggf55HUcgfB55/wCKh1wf9t4+ Ov8Asf4dD052
9tdf8ez+2D+v+fT6jrWd09sfhj+Xp7dO2PkTGjnrPwnFa6vY38mq6ldSW02Y 0uZEZQWyp6ID
0J/Lp1C2a2BxJH2/eIPT+IfT0/TpxhMepY0FVdT/AOQVef8AXB//AEE1aqrq f/IKvP8Arg//
AKCaQy1VXSP+Sjp/2CJf/R0dWqq6R/yUdP8AsES/+jo6cdxM7G4bbPaDdjdK RjdjPyMcfeGf
ybp04yLFV7hts9oN2N0pGN2M/Ixx94Z/JunTjIsVZIVRsoI5bO2mMkrFo0bI nYg8Kf77A/dH
c5yeTuOb1V7Bt+nWzbt2YlO7duzwOc7mz/30fqetAHH+ODocKW9lqFpe3E0k MxikjllzGBHy
Qec8omcggfeb34K90zUpb0NFayTNdQSzQCKwc71Lg5HJ6ZXnJxkckEE9r8TN Tu7aGG0gify5
bedjJiLBJAQ4LfMCFdgSMcPwTzi5Zaxqq6Wx1F5WjNwN1ysYG2E7QRkBQOd2 W6jIwDyV3lWd
CmqjeltvO50UPaQjdu93p5f0zsYRIsMYmdHlCgOyKVUt3IBJwPbJ+prz7RPB epab4Yg0ldF8
P2M8CWcr3dncMWvZraSORfNHkKQHKNlsuV3Zw1dvpMt3PpsUl4jLKR/GuxyP VlBIU+2T+HQZ
mjeKl1fTk1OXSb7TdMe0F4t7fSW6xmMgMCdkrMvynPzAAAHJFc0ZcyTMGrOx l6toGvasmpFo
dNhfWtMGm3gF27C0VWmxJGfKHnErOTtPl4KY3HORHc+CZzo8aQLB9rj1u61V lhupbT7R5rTq
oaeIb1YRyrkgHPl7PunI6RfEugslk663ppS/cpZsLpMXDBgpEfPzkMQMDPJx Uk2u6PbwXE8+
q2MUNtjz5HuEVYsu0Y3En5fnRl5/iUjqDVCMceGZ4/B0OlwiCO6iu0vghmlk RpFuRc7Glcs7
bmG0yEZ5LbB9yq8vh7WLi8uFkSxS1v8AULTU7mRbh2eCSEQZiRfLAkUm3Hzl kI3k7flw25qf
iHTdK0RNZnuY2093gAuEdSm2V1RX3EgbPnDE56ZPNSJrujyXlrZx6rYvdXcQ ntoVuELzRkEh
0XOWXAJyOODQBz+seHbybxkdcg0PQ9UxaW8UD6hOY5LaSOSVyyEQyYz5i8gg 5X6UP4e1gafd
aXGli1quoHU7a4a4cPJJ9sF0Inj8shFzlN4ZjwG287Rsap4ks9Jlu4rmOcyW 9ot1GiqM3WWK
eXCCRvk3bF2+ssY6sKx7r4j6PZ6PrGoyW18f7Lu5LV7YInnT7GZWkiXd80f7 uU7uOIZP7hoA
NM8LXg8Xp4j1KKxEzfaZDDG5l+zyPHaxLsdkXPyW75bCkeZtwRkmPwd4OuPD 1xbG4WNhY2X2
GGc6jc3DTLlMsI5CEtwfKUlE3dQAwC/N1GmalDqtq9xAsiolxPbkOADuilaJ jwTxuQke2OnS
ubuviPo9no+sajJbXx/su7ktXtgiedPsZlaSJd3zR/u5Tu44hk/uGgCvd+Av tWg6pExg/tO4
i1SKB8/u/wDSZZXjZzt3bkWVlBH3RLKBnccx6j4K1LVLKfRZZ7SDT/tF/dRX iuzys10lwuxo
toChftTfMJDnyxwN3y9hHq2mzapNpcWoWj6hCm+W0WZTKi8csmcgfMvJHcet Y9r440G7vdSW
LVdNbT7C3t5ZdQW9Rog0ryLsZs4Ujy16nneOPUAw9T8K6/resPq97BY280X2 bybW01adPN8t
bpWzOkSPHxdA/KrZ2EHAbI2PC3hmfQr+6uJBAkdxaRJ5cc0spWQT3Mr5eQln /wCPgfOTliGO
1RgVqWWtw6hrNxZW/lywR2VteR3McgZZVmaUDGOMYiznJzu9udSgAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAI
br/j2f2wf1/z6fUdazuntj8Mfy9Pbp2x8mjdf8ez+2D+v+fT6jrWd09sfhj+ Xp7dO2PkTGgH
Ekfb94g9P4h9PT9OnGEx62BxJH2/eIPT+IfT0/TpxhMepY0FVdT/AOQVef8A XB//AEE1aqrq
f/IKvP8Arg//AKCaQy1VXSP+Sjp/2CJf/R0dWqq6R/yUdP8AsES/+jo6cdxM 7G4bbPaDdjdK
RjdjPyMcfeGfybp04yLFV7hts9oN2N0pGN2M/Ixx94Z/JunTjIsVZIVRsoI5 bO2mMkrFo0bI
nYg8Kf77A/dHc5yeTuOb1V7Bt+nWzbt2YlO7duzwOc7mz/30fqetAHJeNZoL OGCzl0P+0YZo
pv31wfMEe2FjhWZgVOEDEggkAldzZxn6jfaq8enxWcN5DazljeQx2wfyF+0L yp253AFht6hc
sVBXFdlrWrwaRbxyz3UFupLFml5+UKScKCCx4AwPWsi6eyljjuI10q5inmEc lzFbBtjMQOoL
fMc8ZGM9T0BVSfKueUfdSt5Ex1bhza3v6f1ubmkH/iXKoJ2pJIi5OcAOwA/A ACuJ0TwXqWm+
GINJXRfD9jPAlnK93Z3DFr2a2kjkXzR5CkByjZbLld2cNXZ6HOLnSIJFt44U IyoiUqjA87lB
AIBz3A/EYJzL3xrptj4X07xBLBdm0v7c3ESKi7wotpLnDDdjOyNhwTyR25Cg 04prYtpp6mfq
2ga9qyakWh02F9a0wabeAXbsLRVabEkZ8oecSs5O0+Xgpjcc5Edz4JnOjxpA sH2uPW7rVWWG
6ltPtHmtOqhp4hvVhHKuSAc+Xs+6cixf/EfR9PtbGeS2vn+1Wk908caIXtfK ieRo5hu+SQ+V
KoX+9E442nHQanqcun+Utvpd9qM0mT5doEG1RjJLSMiDkjjduOSQCAxFCMce GZ4/B0OlwiCO
6iu0vghmlkRpFuRc7Glcs7bmG0yEZ5LbB9yq8vh7WLi8uFkSxS1v9QtNTuZF uHZ4JIRBmJF8
sCRSbcfOWQjeTt+XDaGpeMdL03SdI1Q+fPY6rLGkE0SYCI8bSebJuI2xqisz E/dAJI4NEXjL
R31HWbWeb7JDpPlefe3LJHbv5hZRsctzh0ZDnGHUr1BoANc0nVNRvPtNrcwR NYxCbTFbp9rI
kVjN8pzHsIT5ecSSH7wRlx7vwF9q0HVImMH9p3EWqRQPn93/AKTLK8bOdu7c iysoI+6JZQM7
jnY8ReMdH8PeHpNWl1CxfdaSXNlE12ifbNqbgsZ53ZyoyAfvD1qTWfFOm6VZ aw0V1aXWoaXZ
S3kunrcqJdqJu+ZeSoOV5I/iFAEfhyy1jS3u7O8trH7C13d3MNxDdO0jebcP KqtGYwFwHIJD
nke/GPd+AvtWg6pExg/tO4i1SKB8/u/9JlleNnO3duRZWUEfdEsoGdxz3FFA HB6j4K1LVLKf
RZZ7SDT/ALRf3UV4rs8rNdJcLsaLaAoX7U3zCQ58scDd8sep+Fdf1vWH1e9g sbeaL7N5Nraa
tOnm+Wt0rZnSJHj4ugflVs7CDgNkegUUAcv4W8Mz6Ff3VxIIEjuLSJPLjmll KyCe5lfLyEs/
/HwPnJyxDHaowK6iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKAIbr/j2f2wf1/z6fUdazunt j8Mfy9Pbp2x8
mjdf8ez+2D+v+fT6jrWd09sfhj+Xp7dO2PkTGgHEkfb94g9P4h9PT9OnGEx6 2BxJH2/eIPT+
IfT0/TpxhMepY0FVdT/5BV5/1wf/ANBNWqq6n/yCrz/rg/8A6CaQy1VXSP8A ko6f9giX/wBH
R1aqrpH/ACUdP+wRL/6Ojpx3Ezsbhts9oN2N0pGN2M/Ixx94Z/JunTjIsVXu G2z2g3Y3SkY3
Yz8jHH3hn8m6dOMixVkhVGygjls7aYySsWjRsidiDwp/vsD90dznJ5O45vVX sG36dbNu3ZiU
7t27PA5zubP/AH0fqetAHCfEXRb6a3gksDezRmCWExJKrENhSPvZZsrGcgHJ KgjkkmTQbG+0
3QNYN/5wM7SOsU7RyHbsAySowSccjpgDgc57HU0WVLeF4reQSS4/fxeYowrH OMjnj9a5VNX0
O8ZIbNNPkZ3UNL/Z7RgIWC7k3A7uTgNgqCRkjIDVPEctJxa0RgsNH23tE9Wd xXnd94N17UPC
Vp4bcabFBpllLb2t2ty7NcMbSW2QvH5YEQIl3nDPjbgbs7hP481q+/4VNqGp 200tpcgQlJ7d
2jJBlQbkPDAEEjnHfqME+N+b44+03ETeK79VhnMQmbUZ9kqLG0rzRnq8axqH JAJxJHgHcK1o
UfbQ507I0nPkly2PafFXgL+1LK7XSTBFcXctxLIZztVfMs54Aq7VJC+ZMZCP 70krdWwbmq23
irVbe3hm0zRjbF3+12f9qShZ1wuxS/2fJQnfuTaN2FBYqXQ+FR33iGSC4uR8 R3+yQNFG05u7
7aXkEhCgeXuziJiTjHI5z0g06/8AGuoeIV0V/FV/ZzlXcy3OpyCFUWMyby6k gqVGQwyCCDnB
zW31N/zEe28j6M1XR5taOhteQWhS2uGlvbdmMiMrW00TIuVG8bpR1AyM8dqw 28F3mnaxaahp
TwT/AGCK2EUd3MUe5kRbxJXlkVDhm+1+YWCsWYNkDO6vE2n8epo66g+v6wrt fCxWyN5OLkyH
dghP7pZHT13IwxwaqR6n8QpdRl06O+8UPfRLvktlluDKi8clc5A+ZefcetH1 J/zIXtvI9ru/
BuvRaTrUFkNNnn1yymt7kTXLxLatJNcy5QiNjKAboryE/wBWD/FhY9Q+Ht9d RatbRmBln/tC
W2uZtSuWAkuVmAH2b/VR7fPILjeSFJ2gvlfH9Wv/ABxpt3qoj1zxDcWOnXcl pJerPOItyvt5
O4hScrxn+IV6t8JbnVP7d8X6Zqer3mpf2dcx28clzKz/AHWlUkBidudo4z6V FTDckOa9yo1b
u1j1KiiiuU1CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigCG6/49n9sH9f8+n1HWs7 p7Y/DH8vT26d
sfJo3X/Hs/tg/r/n0+o61ndPbH4Y/l6e3Ttj5ExoBxJH2/eIPT+IfT0/Tpxh MetgcSR9v3iD
0/iH09P06cYTHqWNBVXU/wDkFXn/AFwf/wBBNWqq6n/yCrz/AK4P/wCgmkMt VV0j/ko6f9gi
X/0dHVqqukf8lHT/ALBEv/o6OnHcTOxuG2z2g3Y3SkY3Yz8jHH3hn8m6dOMi xVe4bbPaDdjd
KRjdjPyMcfeGfybp04yLFWSFUbKCOWztpjJKxaNGyJ2IPCn++wP3R3Ocnk7j m9Vewbfp1s27
dmJTu3bs8DnO5s/99H6nrQBTvo1tjYhDIQbj+ORnPETDqSfT88nqTXHabaah p39pQm0ltdK+
ySD7PLcrPGJM8eV3Cbc8MB24610Pi3Wo9ISxSbSor2K4kZd07hI42A+UFipA LcgZwM9SBkiT
V4tLsTbwLY2KSXDhd5hUlF3KpIG085YAEjaCRk8gElNU6blJaMSjzyst0ZHx e/5JdrP/AGw/
9HR14DNq+kXM8CI9/YR6fOF065t4w8yW4Lv84MigyeYVfKkYMknYIo+obTyP EGhqNRsoJ4Jg
C0cke6KUDBDBXGcZwRkduMjBPKb/AAJ9ltpl8KWLvPbrKYV06DfDI0qQpBIO iStKxQBiBmOT
JGw104bFQjT231IqUm5Hi174g0XVdOnsL+91VmLW7/2g1qks1y0f2jJkUyjB AnVAd7cRjpwB
lx+IIm1+bUJYHSE6fLYxRqQzKv2VrePceMnG0sQB3IA4Fe+yW/h+K4trRvhl /plwk0iWwtLD
cI4zGGcnzduMyqAM54PAHJuXtn4CsdBXW5dB0f7AZY4mkNhEnlF5ViO8OBs2 s3zhsFdrAjIx
W6xcF0Zn7GXc8HsvGm6C7TVBM73PlxFovm2R/ZrmGR8M3LlrjzSMgOxckruz Uc2t6Lc6Qmgy
S38djAsRjvFtUaV2R7h8GLzAFB+0sM7z/qxx83y/QiaV8PpLy1s47Dww91dx Ce2hWG3LzRkE
h0XGWXAJyOODVO/0/wANWusyaXafD+DUZ4reO4la1s7NVRZGkVQfNdCTmJ+g Paj63T7MPZS7
njOr+ObPUFvZIPOgd/tkUMZsLdnkjnllfJnbLx8TEFFBB2nDDeSvoPwav4tV 8SeN9RgV1hu7
uOeNXADBWeZgDgnnBrsX0r4fR3l1ZyWHhhLq0iM9zC0NuHhjABLuuMquCDk8 cirukyeE7CBJ
9GfRbeG+xskszEi3G1xHwV+9h5FXvhnA6msqmIhKDjFFRpyUrtm9RVOz1bTd QuLq3stQtLme
0fZcxwzK7QtkjDgHKnKkYPofSubuviPo9no+sajJbXx/su7ktXtgiedPsZla SJd3zR/u5Tu4
4hk/uGuQ2OwoqnHq2mzapNpcWoWj6hCm+W0WZTKi8csmcgfMvJHcetY9r440 G7vdSWLVdNbT
7C3t5ZdQW9Rog0ryLsZs4Ujy16nneOPUA6Sisuy1uHUNZuLK38uWCOytryO5 jkDLKszSgYxx
jEWc5Od3tzqUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQBBdjdAAc4LoODj+IVxl14w0PT7prW 81XS7a4jxuim
vdjrwCMgvkcbT+VdleyJFbGSR1REdGZmOAAGGSTXmOuaD4U8RahY32p/Y5p7 NsoTKuJF5+Rx
/EuTnB7+xYGWNGxPqz3HiHwwtpOv2S5ndiYZCyTL5RK85ORwCO3APYVfrEmu YLjxj4Z8ieOX
bcyZ2OGx+6b0rbpMYVV1P/kFXn/XB/8A0E1aqrqf/IKvP+uD/wDoJpDLVLAI oLo3SwIbkp5f
m5YMEznaCCOM8/gPQUlFAFz+0ZfT/wAiP/8AFUf2jL6f+RH/APiqp0UXEXP7 Rl9P/Ij/APxV
H9oy+n/kR/8A4qqdFFwH3Zt79dt5ZW9wNpXE25+CVbHJ6ZVT9VHpUElnps0z TS6TYvKxJZ2j
JJJ5JJzUlFPmew1psXP7Rl9P/Ij/APxVV3aCSK6iks4Hju8/aUbcRNlQh3jP zfKAvPYAdKjo
pXEFnFZackCWOnWlqkCOkKwKUEauwZwuDwGYAkDqQCak3QeR5H2ODyfN8/y/ m2+Zv8zfjP3t
/wA2eu7nrUdFFwJGaB/M3WcDebKk8mdx3yJt2ueeWGxMHqNq+gqvdWemX2ow ajeaRY3F9Bt8
m5mjLyR7TuXaxORgkkY6GpKKLgSboPI8j7HB5Pm+f5fzbfM3+Zvxn72/5s9d 3PWozFZNfpft
p1obxHZ0uCp8xWZAjENnIJVVUnuFA6Ciii4EkLQW/wBn8izgi+zRGCDZuXyo ztyi4Pyr8i8D
j5R6Cq8lnpku/wAzSLF/M3b90ZO7d5m7PPOfOlz6+Y/945koouASxWU9v9nm 060kg3yP5bqS
u6QMJDgnGWEjgnvvbPU1I7QSXi3j2cDXSY2zHcXXAcDDZzwJJAP99vU1HRRc CS3aC0lkltrO
CGSX/WPHuUv8zPyQefmd2+rsepNWP7Rl9P8AyI//AMVVOii4Fz+0ZfT/AMiP /wDFUf2jL6f+
RH/+KqnRRcC5/aMvp/5Ef/4qj+0ZfT/yI/8A8VVOii4Fz+0ZfT/yI/8A8VR/ aMvp/wCRH/8A
iqp0UXAuf2jL6f8AkR//AIqj+0ZfT/yI/wD8VVOii4Fz+0ZfT/yI/wD8VR/a Mvp/5Ef/AOKq
nRRcC5/aMvp/5Ef/AOKo/tGX0/8AIj//ABVU6KLgXP7Rl9P/ACI//wAVR/aM vp/5Ef8A+Kqn
RRcC5/aMvp/5Ef8A+Ko/tGX0/wDIj/8AxVU6KLgXP7Rl9P8AyI//AMVR/aMv p/5Ef/4qqdFF
wLn9oy+n/kR//iqP7Rl9P/Ij/wDxVU6KLgXP7Rl9P/Ij/wDxVH9oy+n/AJEf /wCKqnRRcC5/
aMvp/wCRH/8AiqP7Rl9P/Ij/APxVU6KLgXP7Rl9P/Ij/APxVH9oy+n/kR/8A 4qqdFFwLn9oy
+n/kR/8A4qj+0ZfT/wAiP/8AFVToouBc/tGX0/8AIj//ABVH9oy+n/kR/wD4 qqdFFwLn9oy+
n/kR/wD4qj+0ZfT/AMiP/wDFVToouBc/tGX0/wDIj/8AxVH9oy+n/kR//iqp 0UXAmupo762e
2u7aK4gfG6KYs6tg5GQWweQDWb/Ymgf9C7pX/gOKtsyoMswUZAyTjknAqt9t Xz/KzH5mzd5X
mjzd2M7dvTp3z/jRcCS10/SbG6jubTRNOgnjOUkjh2sp9iDU1IrK4yrBhkjI OeQcGloAKq6n
/wAgq8/64P8A+gmrVVdT/wCQVef9cH/9BNAy1RRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBHLuBjYOVUP8wC7twII x7ckHPtVSW1S
41CNGZRDb4nESrgmQlsMT6cHgdTnNX6i+zRdNnybPL2ZOzb6ben6UCFi3EyM XLKX+UFdu0AA
Y9+QTn3qSiigYVV1P/kFXn/XB/8A0E1aqrqf/IKvP+uD/wDoJoAtUUUUAFFF FABRRRQAUUUU
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAVV1P
/kFXn/XB/wD0E1aqrqf/ACCrz/rg/wD6CaALVFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFVdT/wCQ Vef9cH/9BNWq
q6n/AMgq8/64P/6CaALVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFVdT/AOQVef8AXB//AEE1aqrq f/IKvP8Arg//
AKCaAJjb2zElonJPJIuZh+gfA/Cj7La/88ZP/Aqf/wCLqSii4iP7La/88ZP/ AAKn/wDi6Pst
r/zxk/8AAqf/AOLqSii4Ef2W1/54yf8AgVP/APF0fZbX/njJ/wCBU/8A8XUl FFwI/str/wA8
ZP8AwKn/APi6Pstr/wA8ZP8AwKn/APi6koouBH9ltf8AnjJ/4FT/APxdH2W1 /wCeMn/gVP8A
/F1JRRcCP7La/wDPGT/wKn/+Lo+y2v8Azxk/8Cp//i6koouBH9ltf+eMn/gV P/8AF0fZbX/n
jJ/4FT//ABdSUUXAj+y2v/PGT/wKn/8Ai6Pstr/zxk/8Cp//AIupKKLgR/Zb X/njJ/4FT/8A
xdH2W1/54yf+BU//AMXUlFFwI/str/zxk/8AAqf/AOLo+y2v/PGT/wACp/8A 4upKKLgR/ZbX
/njJ/wCBU/8A8XR9ltf+eMn/AIFT/wDxdSVKtvIyK3yANyN0ijPbuaLsCt9l tf8AnjJ/4FT/
APxdH2W1/wCeMn/gVP8A/F1a+zSf3ov+/q/40fZpP70X/f1f8aNQKv2W1/54 yf8AgVP/APF0
fZbX/njJ/wCBU/8A8XVr7NJ/ei/7+r/jR9mk/vRf9/V/xo1Aq/ZbX/njJ/4F T/8AxdH2W1/5
4yf+BU//AMXVr7NJ/ei/7+r/AI0fZpP70X/f1f8AGjUCr9ltf+eMn/gVP/8A F0fZbX/njJ/4
FT//ABdWvs0n96L/AL+r/jR9mk/vRf8Af1f8aNQKv2W1/wCeMn/gVP8A/F0f ZbX/AJ4yf+BU
/wD8XUGr6nZ6FDDJfzBfPlWGJIVMzyO3AVUQFjk8dO49arf29B/0D9c/8El5 /wDGqeoaGh9l
tf8AnjJ/4FT/APxdH2W1/wCeMn/gVP8A/F1n/wBvQf8AQP1z/wAEl5/8ao/t 6D/oH65/4JLz
/wCNUahoaH2W1/54yf8AgVP/APF0fZbX/njJ/wCBU/8A8XWf/b0H/QP1z/wS Xn/xqj+3oP8A
oH65/wCCS8/+NUahoaH2W1/54yf+BU//AMXR9ltf+eMn/gVP/wDF1n/29B/0 D9c/8El5/wDG
qP7eg/6B+uf+CS8/+NUahoaH2W1/54yf+BU//wAXR9ltf+eMn/gVP/8AF1n/ ANvQf9A/XP8A
wSXn/wAao/t6D/oH65/4JLz/AONUahoaH2W1/wCeMn/gVP8A/F0fZbX/AJ4y f+BU/wD8XUGk
alaa7Yw3umyma3mYrGxRkJIYqRhgCOQRzWj9mk/vRf8Af1f8aWoFX7La/wDP GT/wKn/+Lo+y
2v8Azxk/8Cp//i6tfZpP70X/AH9X/Gj7NJ/ei/7+r/jRqBV+y2v/ADxk/wDA qf8A+Lo+y2v/
ADxk/wDAqf8A+Lq19mk/vRf9/V/xo+zSf3ov+/q/40agVfstr/zxk/8AAqf/ AOLo+y2v/PGT
/wACp/8A4urX2aT+9F/39X/Gj7NJ/ei/7+r/AI0agVfstr/zxk/8Cp//AIuj 7La/88ZP/Aqf
/wCLq19mk/vRf9/V/wAaPs0n96L/AL+r/jRqBV+y2v8Azxk/8Cp//i6Pstr/ AM8ZP/Aqf/4u
iO4hmlnjikV2gk8qTachWwGxnoeGHT6dRVs2kqsVYxAjggyrx+tGoFT7La/8 8ZP/AAKn/wDi
6Pstr/zxk/8AAqf/AOLq19mk/vRf9/V/xo+zSf3ov+/q/wCNGoFX7La/88ZP /Aqf/wCLo+y2
v/PGT/wKn/8Ai6tfZpP70X/f1f8AGj7NJ/ei/wC/q/40agVfstr/AM8ZP/Aq f/4uj7La/wDP
GT/wKn/+Lq19mk/vRf8Af1f8aPs0n96L/v6v+NGoFX7La/8APGT/AMCp/wD4 uj7La/8APGT/
AMCp/wD4urX2aT+9F/39X/Gj7NJ/ei/7+r/jRqBV+y2v/PGT/wACp/8A4uq2 oQwx6XeGONlP
kOMmaR/4T2ZiKs+fF9sltBKjTxIryKjBtobO3JHH8J46/mKh1P8A5BV5/wBc H/8AQTQBaooo
oGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFTTf6q3/65 n/0Jqhqab/VW
/wD1zP8A6E1AENFFFADPNTz1gDZlILbBycDPJHYcdelMFwTIwEEnlrKsJkyu N5C4AGdx++o4
Helt4ntlMMUqiBiWdWUBieTksB83QD5snknd2pkNpi7aZltUzcLL53PnbVCf KuF4ztI+8PvH
8XoIeLmBvN2zxnyv9Zhx8n19OhpsV1FMZGSSMxII8SBwQxcsAB+KfrUcdnL+ 7kmeKQwoNqvN
I5kcSxuflI2xg7D93pu74qZ4rk3DXjTxtdKsYjAdnXjzM/eUYOGGGxkZOOMg lkBLRSkYYgEE
DuO9JSGcf40/5DXhD/sN2v8A6OjrsK4/xp/yGvCH/Ybtf/R0ddhTewgrMbXb VPEq6E0cy3DW
wuFlIAiOSwCA5zvIR2xjojHsa065/VNCurvUr6/t5IUuPs1t9iZiRsnheZvm IGQjCQI2OSrO
OM0hl2w8Q6Zfx6fsu4Yri/tkuYLWWRVmZGXcDszk8A5xkcH0o1DxDpmmWEV7 Pdwm3l8tkdZF
wUd0TzMk42AyIS3QA/SuY0nwTd2DWUc/kzIv2SSWT7dcKiPBHEmBAuEk5hBD sQRuGVO0A6De
HL8x3TgWKzXU8N6ypuURyxTLKIg2OY2IYlsAh2kfafM2qCOgl1Gzh08ag1wh syqv56fMmw4w
+Rn5cHJboBkkgAmp4ZoriCOeCRJYZFDpIjBlZSMggjqCKglN+2ngwpbR3rKo Id2eONjjccgA
uByQPl3YAyucito+jJpP2qQzebcXcnnTskaxRlz1KoowOSeW3ORgMzbRgGad VdT/AOQVef8A
XB//AEE1aqrqf/IKvP8Arg//AKCaAMP4Vf8AIn6V/wBfM/8A6USV01cz8Kv+ RP0r/r5n/wDS
iSumoYkFRzzLb28kzglY0LkDrgDNSVDeQtcWU8KEBpI2QE9MkYoGOZ5If+Pm H7OMkEyTRcYU
k9HPQKabHcwzbPJljkDMV3LIuAQpPr6DoOaL6zhlMsdnDawRnzgCkITOYpEX 7oz1cdakvYRd
6hczuySIwKqrswJXy51xnHAJkX9fSnZCK39pWnmKPtVv5ZRm8wyjGQVG0e/z Z+gq3SWy3EEo
kkvC7LFIkaq7MIwWjIUMQCeEbk+oHPWmwxiG1t4RtJjgjRivTcEAP6g0mA+i iigZh+HP9frn
/YTk/wDQErorv/j8n/66N/Oud8Of6/XP+wnJ/wCgJXRXf/H5P/10b+dDEQ1D d3cFjavc3L7I
kxkgEkknAAA5ZiSAAMkkgDJNTVS1XT/7TsDbiXynWSOaNyu4B43WRMjIyu5R kZBIzgjrQMhi
1pUtZ7rVLObSLeHbmW/mgCHJx1SRgOcDnHUYzT317R0ntoH1axWa6VXt4zco GmVjhSgz8wJ6
Y61n3tv4g1KxMcsFnbFJFbyrbUpV+0LhgVMqxK8WCUbKg527TgE1kWXhDUYd D120kktlm1Gw
ktox9oklCO0t043Oy7mAE6DcRkkNx6gjqn1jTI7q4tX1GzW4tozNPEZ1DxIA CWYZyq4IOTxy
Khh1y1u9Ssrezkhure7tp50uYZQ6funjQgYyDzIec8bfyyLnw/qM2l3mk4tv srXbXsNwt1JH
I7m5Fx5ZCr+7GSV3qxIwGC9g/RfDlzp+rxahIsMeY7gSxi7muX3P9nCkyS8v xAecLjKgA4LE
A6eiiigZh6d/yN2uf9crX+T1pan/AMgq8/64P/6CazdO/wCRu1z/AK5Wv8nr S1P/AJBV5/1w
f/0E0dRFqiiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAVnahNrrTot
hb6b9njTaGnmcMxySTgLgdcdT0z3wNGigDD3+Kv+eGjf9/pf/iaN/ir/AJ4a N/3+l/8Aia3K
KLiMPf4q/wCeGjf9/pf/AImjf4q/54aN/wB/pf8A4mtyii4GHv8AFX/PDRv+ /wBL/wDE0b/F
X/PDRv8Av9L/APE1uUUXAw9/ir/nho3/AH+l/wDiaN/ir/nho3/f6X/4mtyi i4HF67o3irV5
NOuEXRo7jT7uK7iDTS7WZHVsN8mcfL2pv2f4kf8APzoP/fx//jVdtRRcLHE/ Z/iR/wA/Og/9
/H/+NUfZ/iR/z86D/wB/H/8AjVdtRRcLHE/Z/iR/z86D/wB/H/8AjVH2f4kf 8/Og/wDfx/8A
41XbUUXCxxP2f4kf8/Og/wDfx/8A41R9n+JH/PzoP/fx/wD41XbUUXCxxP2f 4kf8/Og/9/H/
APjVNls/iLNE8Uk+glHUqw82TkHr/wAsq7iii4WMPwdpd74a8M2llcC3lvLd 5ZNscjeWxaVn
A3Fc4+YAnb+Bo3+Kv+eGjf8Af6X/AOJrcoouBh7/ABV/zw0b/v8AS/8AxNG/ xV/zw0b/AL/S
/wDxNblFFwMPf4q/54aN/wB/pf8A4mjf4q/54aN/3+l/+JrcoouBh7/FX/PD Rv8Av9L/APE0
b/FX/PDRv+/0v/xNblFFwMPf4q/54aN/3+l/+Jo3+Kv+eGjf9/pf/ia3KKLg ZOg2F5Yx3r33
kedc3TT4gYsoBVRjJAPVTTbifxRNcyypbaOqu5YKbiUkAnpnYM1sUUXAw9/i r/nho3/f6X/4
mjf4q/54aN/3+l/+JrcoouBh7/FX/PDRv+/0v/xNG/xV/wA8NG/7/S//ABNb lFFwMPf4q/54
aN/3+l/+Jo3+Kv8Anho3/f6X/wCJrcoouBh7/FX/ADw0b/v9L/8AE0b/ABV/ zw0b/v8AS/8A
xNblFFwMbR7DUYdT1C+1EWqvcpEqrbuzAbN394D+8Kv6n/yCrz/rg/8A6Cat VV1P/kFXn/XB
/wD0E0AWqKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFVdT/wCQVef9cH/9BNFFAH//2Q==
name="moz-screenshot-4.jpg"
Content-ID: <part2.06050903.04010700@ca.ibm.com>
filename="moz-screenshot-4.jpg"
CAGDAvsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD1i20u2i01NQ1a1N3cSFMW 5wypvIUKFJ2k
8j5j79OlSvFosBQ3fh6G2idtvmyQQlVPvtJIHvjHrVvUm26Hbn/pta/+jUrj rJbSDxvJCy29
69xPO7OUdJ4MgHbIDw8eMBSRjoRRGnKd+V2shSmo2utzuP7C0f8A6BVj/wCA 6f4Uf2Fo/wD0
CrH/AMB0/wAKxNXuZrb4SX91byyQzx6FJJHJGxVkYQEggjkEHnNc9cJ4qttY 0a3jvZA9hcT6
baG4ll8q/Y2lxKktx/z1AVLYFhjEguMD7ppJ3Vxs7z+wtH/6BVj/AOA6f4Uf 2Fo//QKsf/Ad
P8K5t73VfGFlLLpkUltYRPCPs9xNJZzTvsYyxtNHuaMIzxAlRnzIZY24OaPD urXuoXa6XprR
2kGnIGvPtry30krG4nidElaRWADW77XYNkOvyrt2lgdJ/YWj/wDQKsf/AAHT /Cj+wtH/AOgV
Y/8AgOn+Fed6N4l1rw54I8OW7R2moPe6PbNYrDAYmiO+1gVX3S4lP+kqesQ+ QjI3ZW5P418S
2cU32q0sYJtPtL28u4pI1LzpAtu4QLHO4gZhOR8zSfdVtuG20Adx/YWj/wDQ Ksf/AAHT/Cj+
wtH/AOgVY/8AgOn+FcvceJtdDXGkWiQXWu2t20bGCyBSaFYoZGcJJcRhNpuY l5lYnqBgnZsW
viL+0vCUGr20tja3UmnwajJBdzfJDG678OwwVUhXUSYwNpO1tpUgGh/YWj/9 Aqx/8B0/wo/s
LR/+gVY/+A6f4Vy994r1hdDg1mKKC002TzZri5e0e6OnxpgCOaFJFcybt+8r kRFSpBAMlRyX
+par4i8O3sstomnrrt5axWywN5qtDBeRb2l34IPlsdoQY3AZOMkA6mbR9Dt4 ZJptO06OKNS7
u8CBVUckkkcAVn3Wm+ErzSRfSLpqWA5F3DIscfXb99SAeeOT1rX1b7F/Y19/ aP8Ax4/Z5PtP
X/V7Tu+7z0z05rm//Ui/z/2w+1/Z/wDPlUARy+GIYYI7rT4rfUrV1DBfKj3l SMhlYYVh0/xN
VobPTZ4xJHZ25HQgwgEHuCMcGux0n7F/Y1j/AGd/x4/Z4/s3X/V7Rt+9z0x1 5rN1jR3MjX9g
mZ/+W0I4Ew9R6N79+h9k0NMxP7MsP+fK2/79L/hR/Zlh/wA+Vt/36X/CpoZk njEkZyOhBGCD
3BHY1JUDKv8AZlh/z5W3/fpf8KP7MsP+fK2/79L/AIVaooGVf7MsP+fK2/79 L/hR/Zlh/wA+
Vt/36X/CrVFAFX+zLD/nytv+/S/4Uf2ZYf8APlbf9+l/wq1RQBV/syw/58rb /v0v+FH9mWH/
AD5W3/fpf8KtUUAVf7MsP+fK2/79L/hR/Zlh/wA+Vt/36X/CrVFAFX+zLD/n ytv+/S/4Uf2Z
Yf8APlbf9+l/wq1RQBV/syw/58rb/v0v+FH9mWH/AD5W3/fpf8KtUUAVf7Ms P+fK2/79L/hR
/Zlh/wA+Vt/36X/CrVFAFX+zLD/nytv+/S/4Uf2ZYf8APlbf9+l/wq1RQBV/ syw/58rb/v0v
+FH9mWH/AD5W3/fpf8KtUUAVf7MsP+fK2/79L/hVO0tWvrOC7tvCU7wTxrLG +LUblYZBwZMj
g1rVm/8ACPaJ/wBAfT//AAGT/ChMQWdtYXkBk/syKFlkkieOSJNysjlGB25H VT0JrNutS0W1
vri0bT7XfAwVi81rFklQ3AkkViMMOcYzn0roLe3gtIFgtoY4YlztjjUKoyc8 Ae9JoutWmkXO
rxXiXitLeCWMx2U0qsvkRLkMiEdVI69qaBmPptxpmqTTxWlutvLAqMZLeWFv vbgPmidh/Ccq
fbirc+pmy0q7urkDfakq+M4bpg8ZxkEHHOM1ZkvotT8S3d3bJcCD7HbxB5re SHLB5iQA6gnA
ZfzrI1xPM0XWk/vSoP8Ax2OmknKwm7K553aQeIPH+tTRjVRaGNDKiNIyIq5A wNoznkdfesmb
Q9bivbq2XV1JtpmhZn1FItxXqQHcEj3xXRaZo+pTXpi0pZvtBjLHypRGdgIB 5JHcjimf8I/q
VzLORZXEsizMkkgy+HUsHBwDuOdvO7seuRj3lGEVZWPKdSfNucdIuqRSvG2o XJKsVJS4LA49
CDgj3FN3al/z/wB3/wB/m/xrudL0FZNSWC6hLMqyHyiCu+RUYqhHXlgFwOec A5rRg0eLWbKW
e8hihmi8wRNbwpCJAsMjkFVAU7WVOQM4fBP3cJyguhqrvqea7tS/5/7v/v8A N/jRu1L/AJ/7
v/v83+NelDQbC38KmeW3klmn8plYOqmNt1yvXaTtwikrxkjqMVpeIdC04XN7 qF3DcTM1y4CQ
yJFy09zkk7CTxGvXnnrgACeeF7WHZ23PI92pf8/93/3+b/GjdqX/AD/3f/f5 v8a9PuvBmnWc
E0Mt4zXgE7R7VbkRu6/cCEHPlk5LjGeh2883/ZX+zVRlCWyE+ZHLRXGpxOJE v7glf70hYfkc
iuq0LxhNbSxR6nYWlzb8KZBAocDuenJr0TQksjpOitqw01tfWD/iRtOGwItv 7jztvH3s7c89
MfPurz+60+4mvrqS7BN2Z5PtBIGfN3Hf93j72enHpxXNFwrtxlFf12NZc1NX TPSdN/sbVbNL
q0tbZ429YlyD6EdjVv8Asyw/58rb/v0v+Fec6LPd6JdebBkxt9+M9GH+Nej2 N9DqFsJoTx0Z
T1U+hrgr0HSfkdFOoprzE/syw/58rb/v0v8AhR/Zlh/z5W3/AH6X/CrVFYGp V/syw/58rb/v
0v8AhR/Zlh/z5W3/AH6X/CrVFAFX+zLD/nytv+/S/wCFH9mWH/Plbf8Afpf8 KtUUAVf7MsP+
fK2/79L/AIUf2ZYf8+Vt/wB+l/wq1RQBV/syw/58rb/v0v8AhR/Zlh/z5W3/ AH6X/CrVFAFX
+zLD/nytv+/S/wCFH9mWH/Plbf8Afpf8KtUUAVf7MsP+fK2/79L/AIUf2ZYf 8+Vt/wB+l/wq
1RQBV/syw/58rb/v0v8AhR/Zlh/z5W3/AH6X/CrVFAFX+zLD/nytv+/S/wCF H9mWH/Plbf8A
fpf8KtUUAVf7MsP+fK2/79L/AIUf2ZYf8+Vt/wB+l/wq1RQBV/syw/58rb/v 0v8AhR/Zlh/z
5W3/AH6X/CrVFAFX+zLD/nytv+/S/wCFH9mWH/Plbf8Afpf8KtUUAVf7MsP+ fK2/79L/AIUf
2ZYf8+Vt/wB+l/wq1RQBV/syw/58rb/v0v8AhR/Zlh/z5W3/AH6X/CrVFAFX +zLD/nytv+/S
/wCFH9mWH/Plbf8Afpf8KtUUAVf7MsP+fK2/79L/AIUf2ZYf8+Vt/wB+l/wq 1RQBV/syw/58
rb/v0v8AhR/Zlh/z5W3/AH6X/CrVFAFX+zLD/nytv+/S/wCFH9mWH/Plbf8A fpf8KtUUAVf7
MsP+fK2/79L/AIUf2ZYf8+Vt/wB+l/wq1RQBV/syw/58rb/v0v8AhR/Zlh/z 5W3/AH6X/CrV
FAHQTWSahpEVu8kkQIjcPHjcpUqwxkEdQO1Vv7Cl/wCgzqH/AHzB/wDG64Tx j4i1/T/E97bW
WtT2lsioUjEMLBcx5Jy8ecZyeWx8jfMB5jQHhLxFr994qs7W+1qea3dpA8Mk MKhsLIQMiNGy
Cvscxt8ufMWHp9i7c1/zMeZXtY9Ii062TSU0ySNZ7VYBbskyhhIm3aQwxg5H XjFTyQQzPC8s
UbvC++JmUEo20rlfQ7WYZHYkd6rTTypqAiVsJ5W7GB1zTvOk/vfpWajdaFOV iknhfR20O10i
9sYNRtbfDD7dEkxkk53StkYMjFmLNjJLMe9WJdC0eb7D5ulWMn9n4+xbrdD9 mxjHl8fJjavT
H3R6VDp2t2Wr27XGmaja3sKvsaS2lWRQ2AcErkZwRx7irfnSf3v0quRi5kId J01rdLdtPtDA
lu1qkZhXasLABowMYCEKoK9DtHpUcWhaPBZrZxaVYx2qxSQLClugQRyEGRAu MbWIBI6HHNS+
dJ/e/Sq9lqkGpWiXdjeQXVtJnZNA6ujYODhhweQR+FHIw5kPvtC0fU4pIr/S rG7jklE7pPbp
IGkChA5BHLBQFz1wMdKkTSdNjRETT7RURIkVRCoCrE26IDjgIxyo/hPIxS+d J/e/SjzpP736
UcjDmRFcaFo93eR3lzpVjNdRS+fHNJbozpJhRvDEZDYRBnr8i+go/sLR/wC2 P7X/ALKsf7T/
AOf37Onnfd2/fxu+7x16cVL50n979KPOk/vfpRyMOZFiaGO4hkhmjSSKRSjo 6gqynggg9Qar
f2Tpv9m/2d/Z9p9h/wCfbyV8rru+7jHXnp15pfOk/vfpUcN6twheCdJUDshZ CGAZWKsOO4II
I7EEUcjDmRchhjt4Y4YY0jijUIiIoCqo4AAHQCn1U86T+9+lHnSf3v0o5GHM ihqehfaJnu7G
QQ3TY3Kf9XLj+9xkHHcfrWNM1zZgm+sp4FAyZAPMj+u5c4H+9iuknvVtbeS4 uJ0ihiQvJJIQ
qooGSSTwAB3qCz1uy1F5EsdRtbp40R3WCVXKq67kJx0DDkHuORSdO4+c5z+0 7D/n9tv+/q/4
0f2nYf8AP7bf9/V/xrqob1bhC8E6SoHZCyEMAysVYcdwQQR2IIonvVtbeS4u J0ihiQvJJIQq
ooGSSTwAB3
| Re: plug in for XSD [message #596802 is a reply to message #64291] |
Santosh
Ed Merks wrote:
> Santosh,
> schemas bottom up.
>> Hi
>> send it to me.
>> EMF framework
>> Thanks,
>> Santosh
FUDForum. Page generated in 1.09637 seconds
