Home » Language IDEs » Java Development Tools (JDT) » Starting ANT with keyboard shortcut
Starting ANT with keyboard shortcut [message #64241] Sun, 22 June 2003 04:11 Go to next message
Originally posted by: david.purple-sunshine.de
I've posted this before but received no answer, so I'll try it again -
sorry for reposting: is there any way I can start ANT with a keyboard
shortcut?
I have tried it with Windows/Preferences/Workbench/Keys but can't find
any way to start ANT there. Currently, I have to do Run/External
Tools/Run As/Ant Build to get what I need - which is a rather deep menu
link. Alternatively, I could use the context menu of build.xml - which
is much better but still a lot more than e.g. hitting F9.
Auch das geht vorüber. (Sufi-Weisheit)
Holger (David) Wagner Tel: +49 (89) 890 50 962
Dewetstrasse 1 Mobil: +49 (177) 274 12 45
D-80807 München Fax: +49 (177) 992741245
Re: Starting ANT with keyboard shortcut [message #64902 is a reply to message #64241] Mon, 23 June 2003 02:54 Go to previous messageGo to next message
Hai David,
AFAIK there is no direct shortcut for ant, but i defined a key for "Run Last
Launched External Tool" (eg F9 :). So after starting ant the first time, you
only have to press F9 th next time you want to run your ant-build.
Hope it helped to make your life a little easier ;)
regards,
jochen
"David (Holger Wagner)" <david@purple-sunshine.de> schrieb im Newsbeitrag
news:bd3oi7$91o$1@rogue.oti.com...
> shortcut?
> Auch das geht vor
Re: Starting ANT with keyboard shortcut [message #64953 is a reply to message #64902] Mon, 23 June 2003 04:19 Go to previous messageGo to next message
Hi Jochen,
Jochen Vogele wrote:
> Hai David,
Thanks a lot! This may not be a perfectly smooth solution - but it's a
very handy workaround! Hope they'll integrate ANT better soon...
regards,
david
Re: Starting ANT with keyboard shortcut [message #68447 is a reply to message #64953] Thu, 26 June 2003 20:00 Go to previous messageGo to next message
Originally posted by: darin_swanson.oti.com
Please log a bug report for this enhancement with how you would see this
feature working
Darins
"Holger (David) Wagner" <david@daten-raum.de> wrote in message
news:bd6dd0$rru$1@rogue.oti.com...
> Hi Jochen,
> > Hai David,
Last
you
> regards,
> david
> Auch das geht vor
Re: Starting ANT with keyboard shortcut [message #70836 is a reply to message #68447] Tue, 01 July 2003 06:43 Go to previous messageGo to next message
> feature working
Wouldn't this typically be a feature request?
thanks,
david
> Thanks
> Darins
>>Hi Jochen,
>>>Hai David,
> Last
> you
>>regards,
>>david
Re: Starting ANT with keyboard shortcut [message #70977 is a reply to message #70836] Tue, 01 July 2003 11:30 Go to previous message
Feature requests / enhancements are initiated with bug reports.
Darins
news:3F0165BB.8050502@daten-raum.de...
> > feature working
> thanks,
> david
> > Thanks
> > Darins
> >>Hi Jochen,
> >>>Hai David,
> > Last
time,
> > you
> >>regards,
> >>david
> >>Auch das geht vor
Previous Topic:Inclusions of only certain packages.
Next Topic:Performance problems
Current Time: Sat Nov 08 19:22:07 EST 2025
Powered by FUDForum. Page generated in 0.07006 seconds
