Home » Eclipse Projects » GEF » Figure is not a child of this parent
Figure is not a child of this parent [message #64191] Tue, 11 February 2003 07:34 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
I get the following exception when deleting an edit part that was previously
created with drag and drop from the palette. I added debug statements to the
figure throwing this exception. Thus I know the figure was correctly added
to it. I did a litte debugging and I might be possible that the figure of
the edit part that was delete doesn't have a parent set.
Do I have to set it manually? I don't think so.
Cu, Gunnar
!SESSION Feb 11, 2003
13:30:33.776 ---------------------------------------------
java.version=1.4.1-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -dev bin -update -data
E:\estudio-runtime-workspace -debug
file:z:\rnd_beehive_source_eclipse_vob\plugins\.metadata\.pl ugins\org.eclips
e.pde.core\.options -os win32 -ws win32 -arch x86 -nl de_DE -install
!ENTRY com.intershop.beehive.eclipse.core 4 -1 Feb 11, 2003 13:30:33.776
!MESSAGE IWAG0003E Figure is not a child of this parent
!STACK 0
java.lang.IllegalArgumentException: IWAG0003E Figure is not a child of this
parent
at org.eclipse.draw2d.Figure.remove(Figure.java:1031)
at org.eclipse.draw2d.FreeformLayer.remove(FreeformLayer.java:4 9)
com.intershop.enfinitystudio.internal.gefextensions.grid.Gri dFigure.remove(G
ridFigure.java:166)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.removeCh ildVisual(Abstra
ctGraphicalEditPart.java:671)
org.eclipse.gef.editparts.AbstractEditPart.removeChild(Abstr actEditPart.java
:844)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.
java:763)
com.intershop.enfinitystudio.internal.vpm.editor.edit.Pipeli neEditPart.handl
eEvent(PipelineEditPart.java:222)
com.intershop.enfinitystudio.internal.vpm.editor.edit.Abstra ctBeehiveElement
EditPart$1.run(AbstractBeehiveElementEditPart.java:188)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:123)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:18)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:1979)
EditPart.elementChange(AbstractBeehiveElementEditPart.java:1 80)
com.intershop.beehive.eclipse.core.common.BeehiveElementMana ger.informElemen
tChangeListeners(BeehiveElementManager.java:747)
com.intershop.beehive.eclipse.core.common.BeehiveElementMana ger.doFireBeehiv
eElementChangeEvent(BeehiveElementManager.java:734)
eElementChangeEvent(BeehiveElementManager.java:716)
com.intershop.beehive.eclipse.core.common.BeehiveElementMana ger.doFinishBeeh
iveElementChange(BeehiveElementManager.java:616)
com.intershop.beehive.eclipse.core.common.BeehiveElementMana ger.finishBeehiv
eElementChange(BeehiveElementManager.java:599)
com.intershop.enfinitystudio.internal.vpm.editor.edit.comman ds.DeletePipelin
eNodeCommand.redo(DeletePipelineNodeCommand.java:95)
eNodeCommand.execute(DeletePipelineNodeCommand.java:49)
org.eclipse.gef.commands.CompoundCommand.execute(CompoundCom mand.java:102)
at org.eclipse.gef.commands.CommandStack.execute(CommandStack.j ava:64)
org.eclipse.gef.ui.actions.EditorPartAction.execute(EditorPa rtAction.java:54
at org.eclipse.gef.ui.actions.DeleteAction.run(DeleteAction.jav a:115)
at org.eclipse.gef.KeyHandler.performStroke(KeyHandler.java:68)
at org.eclipse.gef.KeyHandler.keyPressed(KeyHandler.java:44)
at org.eclipse.gef.KeyHandler.keyPressed(KeyHandler.java:46)
org.eclipse.gef.ui.parts.GraphicalViewerKeyHandler.keyPresse d(GraphicalViewe
rKeyHandler.java:186)
org.eclipse.gef.tools.SelectionTool.handleKeyDown(SelectionT ool.java:225)
at org.eclipse.gef.tools.AbstractTool.keyDown(AbstractTool.java :626)
at org.eclipse.gef.tools.SelectionTool.keyDown(SelectionTool.ja va:327)
at org.eclipse.gef.DefaultEditDomain.keyDown(DefaultEditDomain. java:150)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchKeyPr essed(DomainEven
tDispatcher.java:154)
org.eclipse.draw2d.LightweightSystem$EventHandler.keyPressed (LightweightSyst
em.java:386)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:118)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1467)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1450)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
!ENTRY com.intershop.beehive.eclipse.core 4 -1 Feb 11, 2003 13:30:44.221
!STACK 0
parent
ridFigure.java:166)
:844)
java:763)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:707
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphica
lEditPart.java:541)
EditPart.handleEvent(AbstractBeehiveElementEditPart.java:254 )
eEvent(PipelineEditPart.java:239)
com.intershop.beehive.eclipse.core.common.BeehiveDescribable BaseElement.load
(BeehiveDescribableBaseElement.java:307)
com.intershop.enfinitystudio.internal.vpm.editor.PipelineEdi tor.dispose(Pipe
lineEditor.java:451)
at org.eclipse.ui.internal.WorkbenchPage$5.run(WorkbenchPage.ja va:940)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:852)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:938)
org.eclipse.ui.internal.WorkbenchPage.closeAllEditors(Workbe nchPage.java:688
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:957)
org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:4
16)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:930)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:337)
org.eclipse.ui.internal.WorkbenchWindow.access$3(WorkbenchWi ndow.java:326)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:382)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:65)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:380)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:102)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:260)
:852)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:2 57)
at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:21 4)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:390)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:388)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:380)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:374)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:333)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:482)
org.eclipse.jface.window.ApplicationWindow.handleShellCloseE vent(Application
Window.java:215)
at org.eclipse.jface.window.Window$2.shellClosed(Window.java:43 3)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:152)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:861)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:845)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1258)
at org.eclipse.swt.widgets.Shell.WM_CLOSE(Shell.java:1148)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2705 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1218)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2177 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1287 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:73)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:392)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2779 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:12 92)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1408)
a:845)
..java:25)
Re: Figure is not a child of this parent [message #64695 is a reply to message #64191] Thu, 13 February 2003 05:38 Go to previous messageGo to next message
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> schrieb im Newsbeitrag
news:b2ap6g$oad$1@rogue.oti.com...
this
> parent
There might be threading issues. I don't understand it. The figure is a
child of the parent but Figure#getParent returns null and the exception is
thrown.
http://dev.eclipse.org/bugs/show_bug.cgi?id=31755
Cu, Gunnar
Re: Figure is not a child of this parent [message #64765 is a reply to message #64695] Thu, 13 February 2003 09:09 Go to previous messageGo to next message
Why might there be threading issues? Are you updating you model on a
background thread?
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:b2fr31$h32$1@rogue.oti.com...
> this
> > parent
> thrown.
> Cu, Gunnar
Re: Figure is not a child of this parent [message #64834 is a reply to message #64765] Thu, 13 February 2003 09:16 Go to previous message
"Randy Hudson" <none@us.ibm.com> schrieb im Newsbeitrag
news:b2g7ej$sfg$1@rogue.oti.com...
> background thread?
Not really. The model update may by executed in an operation that doesn't
run in the UI tread but that is not in the background and the events are
fired after updating the model in no seperate thread.
Cu, Gunnar
Previous Topic:Dragging above or left from (0,0) moves figure.
Next Topic:Need help fixing "class must implement abstract method" error !!
Current Time: Sat Nov 08 13:42:29 EST 2025
Powered by FUDForum. Page generated in 0.03415 seconds
