Home » Newcomers » Newcomers » Major compile errors
Major compile errors [message #64168] Sat, 14 May 2005 03:01 Go to next message
Originally posted by: vendors.tpsoft.com
Hi --
I'm running Eclipse 3.0.2 on Win2K SP2. I'm trying to compile PlaceLab
(from SourceForge) and I'm getting tens of thousands of errors.
Something's very wrong.
I'm using JDK1.5.0_03 and have set my environment variables properly as
far as I can see, I have set the two environment variables correctly:
JAVA_HOME=E:\Sysprog\Java\jdk1.5.0_03
PATH=...;E:\Sysprog\Java\jdk1.5.0_03\bin
Additionally, the Build Path for the project has jdk1.5.0_03:
C:\Program Files\Java\jre1.5.0_03
As far as I can tell, everything's in order. Yet, when I do a project
clean with automatic rebuild, I get about 15,000 compile errors.
Eventually, the compile stops and complains about not being able to find
java.lang.StringBuilder.
I'm having a hard time knowing where to start looking.
The only thing I can think of to do is to add the Eclipse configuration.
Any ideas where to go with this??
*** Date: 5/13/05 11:50 PM
*** Platform Details:
*** System properties:
ant.home=e:\Sysprog\Eclipse\plugins\org.apache.ant_1.6.2
ant.library.dir=e:\Sysprog\Eclipse\plugins\org.apache.ant_1. 6.2\lib
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M200409161125
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
E:\Sysprog\Eclipse\eclipse.exe -showsplash 600
-exitdata
E:\Sysprog\Eclipse\eclipse.exe -exitdata b10_40
-vm
C:\WINNT\system32\javaw.exe
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1116051979047
eclipse.vm=C:\WINNT\system32\javaw.exe
eclipse.vmargs=-cp
E:\Sysprog\Eclipse\startup.jar
org.eclipse.core.launcher.Main
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=E:\Sysprog\Eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_03\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_03\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_03
java.io.tmpdir=C:\DOCUME~1\BARRYD~1\LOCALS~1\Temp\
java.library.path=C:\WINNT\system32;.;C:\WINNT\System32;C:\W INNT;C:\WINNT\system32;C:\WINNT;C:\WINNT\System32\Wbem;C:\PR OGRAM
FILES\THINKPAD\UTILITIES;E:\comprog\Symantec\pcAnywhere\;e:\ comprog\symantec\winfax\macros;E:\sysprog\Microsoft\Support
Tools\;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program
Files\ATI Technologies\Fire GL 3D Studio Max;C:\Program Files\ATI
Technologies\Fire GL Control Panel;"E:\Sysprog\Symantec\Norton Ghost
2003\";E:\Sysprog\Java\jdk1.5.0_03\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_03-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_03
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_03-b07
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.executionenvironment=
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2000
org.osgi.framework.os.version=5.0
org.osgi.framework.processor=x86
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
os.arch=x86
os.name=Windows 2000
os.version=5.0
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=e:\Sysprog\Eclipse\configuration\org.eclips e.osgi\bundles
osgi.configuration.area=file:/e:/Sysprog/Eclipse/configurati on/
osgi.framework=file:/e:/Sysprog/Eclipse/plugins/org.eclipse. osgi_3.0.1/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/e:/Sysprog/Eclipse/
osgi.instance.area=file:/G:/PlacelabCVS/
osgi.logfile=G:\PlacelabCVS\.metadata\.log
osgi.manifest.cache=e:\Sysprog\Eclipse\configuration\org.ecl ipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=e:\Sysprog\Eclipse\plugins\org.eclipse.p latform_3.0.2\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_03\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_03\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_03\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_03\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_03\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_03\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_03\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_03\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=E:\Sysprog\Eclipse
user.home=C:\Documents and Settings\Barry Demchak
user.language=en
user.name=Barry Demchak
user.timezone=America/Los_Angeles
user.variant=
*** Features:
org.eclipse.emf (2.0.2) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.0.2) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.0.2) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.0.2) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.0.2) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.examples (2.0.1) "Examples for Eclipse Modeling Framework
(EMF)"
org.eclipse.emf.source (2.0.2) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.0.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.0.1) "GEF Examples"
org.eclipse.gef.sdk (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.0.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.2) "Java EMF Model"
org.eclipse.jem.sdk (1.0.2) "Java EMF Model SDK"
org.eclipse.jem.source (1.0.2) "Java EMF Model Source"
org.eclipse.pde (3.0.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.2) "Eclipse Platform"
org.eclipse.platform.source (3.0.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.2) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples"
org.eclipse.team.extras (3.0.0) "Eclipse FTP and WebDAV Support"
org.eclipse.ve (1.0.2) "Visual Editor"
org.eclipse.ve.sdk (1.0.2) "Visual Editor SDK"
org.eclipse.ve.source (1.0.2) "Visual Editor Source"
org.eclipse.xsd (2.0.2) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.2) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.0.2) "XML Schema Infoset Model (XSD) Source"
org.tigris.subversion.book (1.1.1) "Version Control with Subversion"
org.tigris.subversion.subclipse (0.9.30) "Subclipse"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in"
com.ibm.wtp.emf.workbench (1.0.1.1) "EMF Workbench"
org.apache.ant (1.6.2) "Apache Ant"
org.apache.lucene (1.4.3) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.2) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.compare.examples (3.0.0) "Compare Example"
org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.1) "File Buffers"
org.eclipse.core.resources (3.0.1) "Core Resource Management"
org.eclipse.core.resources.win32 (3.0.0) "Core Resource Management Win32
Fragment"
org.eclipse.core.runtime (3.0.2) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.2) "Debug Core"
org.eclipse.debug.ui (3.0.2) "Debug UI"
org.eclipse.draw2d (3.0.1) "Draw2d"
org.eclipse.draw2d.doc.isv (3.0.1) "Draw2D Documentation"
org.eclipse.emf.activities (2.0.0) "EMF Activities"
org.eclipse.emf.codegen (2.0.1) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.0.2) "EMF Ecore Code Generation"
org.eclipse.emf.codegen.ecore.ui (2.0.1) "EMF Ecore Code Generation UI"
org.eclipse.emf.codegen.ui (2.0.0) "EMF Template Code Generator UI"
org.eclipse.emf.common (2.0.1) "EMF Common"
org.eclipse.emf.common.ui (2.0.1) "EMF Common UI"
org.eclipse.emf.commonj.sdo (2.0.0) "CommonJ SDO"
Guide"
org.eclipse.emf.ecore (2.0.2) "EMF Ecore"
org.eclipse.emf.ecore.change (2.0.2) "EMF Ecore Change Model"
org.eclipse.emf.ecore.change.edit (2.0.0) "EMF Ecore Change Edit Support"
org.eclipse.emf.ecore.edit (2.0.0) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.0.1) "Sample Ecore Editor"
Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.0.0) "EMF Service Data Objects (SDO)
Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.0.0) "EMF Service Data Objects (SDO)
Editor"
Source"
org.eclipse.emf.ecore.xmi (2.0.2) "EMF XMI"
org.eclipse.emf.edit (2.0.1) "EMF Edit"
org.eclipse.emf.edit.ui (2.0.1) "EMF Edit UI"
(EMF)"
org.eclipse.emf.java (2.0.1) "EMF Java"
org.eclipse.emf.java.edit (2.0.0) "EMF Java Edit"
org.eclipse.emf.java.editor (2.0.1) "EMF Java Editor"
org.eclipse.emf.mapping (2.0.1) "EMF Mapping"
org.eclipse.emf.mapping.ecore2ecore (2.0.1) "Ecore to Ecore Mapping"
org.eclipse.emf.mapping.ecore2ecore.editor (2.0.1) "Ecore to Ecore Mapping
Editor"
org.eclipse.emf.mapping.ui (2.0.0) "EMF Mapping UI"
org.eclipse.emf.mapping.xsd2ecore (2.0.1) "XSD to Ecore Mapping"
org.eclipse.emf.mapping.xsd2ecore.editor (2.0.1) "XSD to Ecore Mapping
Editor"
org.eclipse.gef.doc.isv (3.0.1) "Graphical Editing Framework Documentation"
org.eclipse.gef.examples.flow (3.0.1) "GEF Flow Editor Example"
org.eclipse.gef.examples.logic (3.0.0) "GEF Logic Editor Example"
org.eclipse.gef.examples.source (3.0.1) "GEF Examples"
Resources"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.2) "Help System Base"
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.2) "Help System UI"
org.eclipse.help.webapp (3.0.2) "Help System Webapp"
org.eclipse.jdt.core (3.0.2) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.2) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.2) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.1) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.1) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.1) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.2) "Java Development Tools JUnit
runtime support"
org.eclipse.jdt.launching (3.0.2) "Java Development Tools Launching
Support"
org.eclipse.jdt.ui (3.0.2) "Java Development Tools UI"
org.eclipse.jdt.ui.examples.projects (3.0.1) "Java Development Tools
Example Projects"
org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection)
Support"
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support"
org.eclipse.jem.sdk (1.0.1) "Java EMF Model SDK"
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI"
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.2) "JFace"
org.eclipse.jface.text (3.0.2) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.1) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.1) "Refactoring UI"
org.eclipse.osgi (3.0.1) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde (3.0.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.build (3.0.1) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.2) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.1) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.2) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.1) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.1) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.win32.win32.x86 (3.0.2) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.sdk.examples.source (3.0.1) "Eclipse Platform Plug-in
org.eclipse.sdk.examples.source.win32.win32.x86 (3.0.1) "Eclipse Platform
org.eclipse.search (3.0.1) "Search Support"
org.eclipse.swt (3.0.2) "Standard Widget Toolkit"
org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin"
org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin (Win32)"
org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin"
org.eclipse.swt.win32 (3.0.2) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.1) "CVS Team Provider UI"
org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System
Example"
org.eclipse.team.extras.source (3.0.0) "Eclipse Team Extras Plug-in
org.eclipse.team.ftp (3.0.0) "FTP Deployment Provider"
org.eclipse.team.ui (3.0.1) "Team Support UI"
org.eclipse.team.webdav (3.0.0) "WebDAV Team Provider"
org.eclipse.text (3.0.1) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.2) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.1) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.1) "Default Text Editor"
org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example"
org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor Example"
org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor"
org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
org.eclipse.ui.externaltools (3.0.1) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.2) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.2) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.1) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.win32 (3.0.1) "Win32 fragment"
org.eclipse.ui.workbench (3.0.2) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.1) "Text Editor Framework"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.2) "Install/Update Core"
org.eclipse.update.core.win32 (3.0.0) "Install/Update Core for Windows"
org.eclipse.update.scheduler (3.0.1.1) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.1.1) "Install/Update UI"
org.eclipse.ve (1.0.1) "Visual Editor"
org.eclipse.ve.cde (1.0.2) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.2) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.2) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
org.eclipse.ve.sdk (1.0.1) "Visual Editor SDK"
org.eclipse.ve.swt (1.0.2) "Visual Editor for Standard Widget Toolkit"
org.eclipse.webdav (3.0.0) "WebDAV Client"
Guide"
org.eclipse.xsd.edit (2.0.1) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.0.1) "XML Schema Editor"
org.eclipse.xsd.test (2.0.1) "XML Schema Infoset Model Test"
org.junit (3.8.1) "JUnit Testing Framework"
org.tigris.subversion.javahl.win32 (0.9.30) "Win32 Fragment"
org.tigris.subversion.subclipse.core (0.9.30) "SVN Team Provider Core"
org.tigris.subversion.subclipse.ui (0.9.30) "SVN Team Provider UI"
*** User Preferences:
#Fri May 13 23:50:51 PDT 2005
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.jdt.junit/org.eclipse.jdt.junit.active _filters=org.eclipse.jdt.internal.junit.runner.*,org.eclipse .jdt.internal.junit.ui.*,junit.framework.TestCase,junit.fram ework.TestResult,junit.framework.TestSuite,junit.framework.A ssert,java.lang.reflect.Method.invoke,junit.framework.TestRe sult$1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program
Files/Java/jre1.5.0_03/lib/rt.jar
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1116045605098
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
@org.eclipse.help.ui=3.0.2
file_export_version=3.0
@org.eclipse.pde.core=3.0.2
@org.eclipse.jdt.ui=3.0.2
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.placelab|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry
kind\="lib" path\="C\:/Program
Files/Java/jre1.5.0_03/lib/rt.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/jre1.5.0_03/lib/jsse.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/jre1.5.0_03/lib/jce.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/jre1.5.0_03/lib/charsets.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/jre1.5.0_03/lib/ext/sunjce_provider.jar"/>\r\n<classpathentry
Files/Java/jre1.5.0_03/lib/ext/dnsns.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/jre1.5.0_03/lib/ext/localedata.jar"/>\r\n<classpathentry
Files/Java/jre1.5.0_03/lib/ext/sunpkcs11.jar"/>\r\n</classpath >\r\n
/instance/org.eclipse.pde.core/platform_path=e\:\\Sysprog\\E clipse
/instance/org.eclipse.team.cvs.core/repositories/%pserver%anonymous@cvs.sourceforge.net%%cvsroot%placelab/location=\:pserver\:anonymous@cvs.sourceforge.net\:/cvsroot/placelab
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=e\:/Sysprog/Eclipse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.jdt.launching=3.0.2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<javadoclocation>\r\n<location_01
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/rt.jar"
url\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n<location_01
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/ext/sunjce_provider.jar"
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/jsse.jar"
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/ext/dnsns.jar"
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/jce.jar"
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/sunrsasign.jar"
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/ext/ldapsec.jar"
url\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n<known_vm_installs>\r\n<vm_type
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm_install
id\="1116050788886"
javadoc_loc\="http\://java.sun.com/j2se/1.4.2/docs/api">\r\n<library
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/rt.jar"/>\r\n<library
path\="C\:/Program
Files/Java/j2re1.4.2_06/lib/sunrsasign.jar"/>\r\n<library
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/jsse.jar"/>\r\n<library
path\="C\:/Program Files/Java/j2re1.4.2_06/lib/jce.jar"/>\r\n<library
path\="C\:/Program
Files/Java/j2re1.4.2_06/lib/ext/dnsns.jar"/>\r\n<library
path\="C\:/Program
Files/Java/j2re1.4.2_06/lib/ext/ldapsec.jar"/>\r\n<library
path\="C\:/Program
Files/Java/j2re1.4.2_06/lib/ext/sunjce_provider.jar"/>\r\n </vm_install>\r\n</vm_type>\r\n<vm_type
id\="org.eclipse.jdt.launching.Standard11xVMType"/>\r\n</known_vm_installs >\r\n</javadoclocation>\r\n
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.cvs.ui.cvsworkspace- participant
/instance/org.eclipse.jdt.ui/Refactoring.ErrorPage.severityT hreshold=2
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.core.resources/description.autobuildin g=false
@org.eclipse.team.cvs.core=3.0.1
@org.eclipse.jdt.junit=3.0.1
@org.eclipse.jdt.core=3.0.2
/instance/org.eclipse.help.ui/browser.y=386
/instance/org.eclipse.help.ui/browser.x=774
/instance/org.eclipse.help.ui/browser.w=792
/instance/org.eclipse.jdt.core//org.eclipse.jdt.core.classpa thContainer.placelab|org.eclipse.jdt.launching.JRE_CONTAINER /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/j re1.5.0_03= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.ui=3.0.2
@org.eclipse.core.resources=3.0.1
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 ">\r\n<vmType
id\="0" name\="jre1.5.0_03" path\="C\:\\Program
Files\\Java\\jre1.5.0_03"/>\r\n<vm id\="1116050788886"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api" name\="jre1.4.2_06"
path\="C\:\\Program
Files\\Java\\j2re1.4.2_06"/>\r\n</vmType>\r\n</vmSettings >\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=e\:/Sysprog/Eclipse/plugins/org.junit_3 .8.1
@org.eclipse.ui.workbench=3.0.2
/instance/org.eclipse.help.ui/browser.h=766
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=6
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.team.pessimistic.ui.decorator\:true,org.eclipse.jdt.ui .override.decorator\:true,org.eclipse.pde.ui.binaryProjectDe corator\:false,org.eclipse.team.cvs.ui.decorator\:true,org.e clipse.ui.LinkedResourceDecorator\:true,org.tigris.subversio n.subclipse.ui.decorator\:true,
@org.eclipse.ant.ui=3.0.2
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
@org.eclipse.team.cvs.ui=3.0.1
@org.eclipse.team.ui=3.0.1
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
*** Update Manager Log:
Configuration=Sun Feb 13 13:59:49 PST 2005
Is current configuration=false
Configuration=Tue May 03 14:19:19 PDT 2005
Configuration=Tue May 03 15:27:54 PDT 2005
Configuration=Tue May 03 15:34:29 PDT 2005
Configuration=Tue May 03 15:40:59 PDT 2005
Configuration=Tue May 03 15:41:13 PDT 2005
Configuration=Fri May 13 22:55:43 PDT 2005
Configuration=Fri May 13 22:57:16 PDT 2005
Is current configuration=true
Re: Major compile errors [message #64192 is a reply to message #64168] Sat, 14 May 2005 03:49 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Barry,
R3.0.2 is neither supported to be run with J2SE 5.0 nor does it allow to
write J2SE 5.0 code. Either use a 1.4 VM or switch to 3.1M7. If you
still have problems afterwards I suggest you look in the Problems view
whether there are errors directly attached to your Java project. They
might indicate the build path problems.
Dani
Re: Major compile errors [message #64711 is a reply to message #64168] Mon, 16 May 2005 10:47 Go to previous message
Originally posted by: eclipse.rizzoweb.com
Barry Demchak wrote:
> Hi --
When you create a new Java project in Eclipse, it will automatically
include the default JRE/JDK libraries on the project's build path. Did
you manually add your 1.5 JRE stuff?
Also, as someone else mentioned, Eclipse 3.0.x does not support
writing/compiling code for JDK 1.5 (3.0.2 does run under 1.5 - I've done
it for a while). If PlaceLab needs 1.5 then you'll have to upgrade to
Eclipse 3.1 to build it.
Aside: the env vars JAVA_HOME, PATH, etc. have no effect in Eclipse. In
Eclipse you define JDKs/JREs you want it to use by going to
Preferences > Java > Installed JREs
HTH,
Eric
Previous Topic:Generate constructors using Fields not convenient in 3.1M7
Next Topic:Having problems upgrading to 3.0.2 from Update Manager.
Current Time: Sat Nov 01 15:08:00 EDT 2025
Powered by FUDForum. Page generated in 0.07089 seconds
