Home » Archived » Visual Editor (VE) » Newbie: No New Java Visual Class Wizard
Newbie: No New Java Visual Class Wizard [message #64115] Mon, 04 October 2004 08:15 Go to next message
Originally posted by: nomail.nomail.com
I've installed Eclipse SDK 3.0.1, EMF 3.0.1, GEF 3.0.1 and VE 1.0.1 but I
do not see the "Visual Class" option under Java perspective, File > New.
However, under "Open with" I see the "Visual Editor" option. Is something
wrong with my configuration? What went wrong?
Help is appreciated.
-Jo
Re: Newbie: No New Java Visual Class Wizard [message #64276 is a reply to message #64115] Mon, 04 October 2004 11:39 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Did you install VE AFTER opening at least once the Java Perspective in
your workspace? If you had, then Eclipse won't merge in new things to
the first level menu.
Rich Kulp
Re: Newbie: No New Java Visual Class Wizard [message #64637 is a reply to message #64276] Tue, 05 October 2004 04:00 Go to previous messageGo to next message
After closing and reopening the Java Perspective the "Visual Class" option
now shows up. But I don't see the selection of SWT widgets on the palette.
It only displays Swing and AWT elements ...
And thanks for your help!
-Jo
Re: Newbie: No New Java Visual Class Wizard [message #64798 is a reply to message #64637] Tue, 05 October 2004 10:27 Go to previous messageGo to next message
> -Jo
If you create a new Visual Class based on the SWT Application or SWT
Composite, the SWT palette should show up. Have you tried this? You
can also go to the Java project's build path properties and add the SWT
library to the project.
- Jeff
Re: Newbie: No New Java Visual Class Wizard [message #64821 is a reply to message #64798] Tue, 05 October 2004 10:39 Go to previous messageGo to next message
> > -Jo
> - Jeff
Yes, that's what I've done. And the SWT lib is part of the project's build
path. BTW, I'm running Eclipse on WinXP.
- Jo
Re: Newbie: No New Java Visual Class Wizard [message #64841 is a reply to message #64798] Tue, 05 October 2004 10:52 Go to previous messageGo to next message
> > -Jo
> - Jeff
I am having trouble finding the Java Visual Class Wizard with Eclipse
3.0.1 and VE 1.0.1 . The features.xml file under
eclipse/features/org.eclipse.ve_1.0.1 contain:
requires
import feature="org.eclipse.jdt" version="3.0.0" match="compatible"
import feature="org.eclipse.emf" version="2.0.1" match="compatible"
import feature="org.eclipse.gef" version="3.0.0" match="compatible"
requires
www.eclipse.org/vep states that VE 1.0 supports Eclipse 3.0.1. I'm new to
Eclipse and if anyone can help me get started I would appreciate it. I am
running Eclipse on Red Hat 9.0.
Cindy Taylor
Re: Newbie: No New Java Visual Class Wizard [message #64863 is a reply to message #64841] Tue, 05 October 2004 12:40 Go to previous message
>>>-Jo
>> - Jeff
> requires
> requires
> Cindy Taylor
I finally got VE to work. I was missing the EMF and GEF plugins. Even
though I could only load EMF-SDO version 2.0.1, VE does now work with
Eclipse 3.0.1.
Cindy Taylor
Re: Newbie: No New Java Visual Class Wizard [message #600623 is a reply to message #64115] Mon, 04 October 2004 11:39 Go to previous message
Rich Kulp
Re: Newbie: No New Java Visual Class Wizard [message #600759 is a reply to message #64276] Tue, 05 October 2004 04:00 Go to previous message
-Jo
Re: Newbie: No New Java Visual Class Wizard [message #600825 is a reply to message #64637] Tue, 05 October 2004 10:27 Go to previous message
> -Jo
- Jeff
Re: Newbie: No New Java Visual Class Wizard [message #600832 is a reply to message #64798] Tue, 05 October 2004 10:39 Go to previous message
> > -Jo
> - Jeff
- Jo
Re: Newbie: No New Java Visual Class Wizard [message #600842 is a reply to message #64798] Tue, 05 October 2004 10:52 Go to previous message
> > -Jo
> - Jeff
requires
requires
Cindy Taylor
Re: Newbie: No New Java Visual Class Wizard [message #600850 is a reply to message #64841] Tue, 05 October 2004 12:40 Go to previous message
>>>-Jo
>> - Jeff
> requires
> requires
> Cindy Taylor
Eclipse 3.0.1.
Cindy Taylor
Previous Topic:JFrame Application terminate
Next Topic:Getting Exception if using Visual Editor (Remote VM)
Current Time: Sat Nov 22 02:32:28 EST 2025
Powered by FUDForum. Page generated in 0.05438 seconds
