| An org.eclipse.emf.validation.examples.ocl example plug-in howto [message #64066] |
Mon, 03 November 2008 12:38  |
I know a lot of people, including myself, have had a lot of trouble
getting the very nice org.eclipse.emf.validation.examples.ocl example
plugin to work [see
http://wiki.eclipse.org/EMF-QTV_1.1_New_and_Noteworthy#New_V alidation_Constraint_Provider_Example]
with their own model/constraints. To this end I have written a quick howto
for new users. If I have time, and if people are interested, I can convert
this into an Eclipse Corner article. Any errors you find please report
them.
In case you don't know the purpose of the plugin was written to allow OCL
constraints to be defined in a text file. These constraints are then
applied to a model and can be validated using the Eclipse Validation
Framework.
So now the howto....
1. Install Eclipse Modeling Environment from
http://www.eclipse.org/downloads/packages/eclipse-modeling-t ools-includes-incubating-components/ganymeder
2. Create a new empty EMF project
File->New Project->Empty EMF Project
Project name: org.mycompany.product
3. Import an existing EMF model into the new project
Select the "model" folder
Right click and select Import->File System
In this example the model imported is myModel.ecore
4. Create the .genmodel for the EMF model so we can autogenerate the GEF
based model editor
New->Other->EMF Model
Select Ecore model importer
Select the myModel.ecore model
5. Open the new Product.genmodel
Select the root object and righ click
Select "Generate All"
This will create a GEF based editor off the myModel.ecore model
6. Bring the OCL example code into your project
File->New->Example->OCL Example
File->New->Example->General Validation Example
File->New->Example->Validation Adapter Example
7. Delete the following projects as we do not want to use the generated
"Library" example settings
org.eclipse.emf.examples.library
org.eclipse.emf.examples.library.edit
org.eclipse.emf.examples.library.editor
src folder from under org.eclipse.emf.validation.examples.ocl
Library.ocl file from constraints folder in
8. Place our OCL constraints file in the OCL folder in
Select the "constraints" folder
In this example the constraints imported are Product_constraints.ocl
9. Open plugin.xml in org.eclipse.emf.validation.examples.ocl
Change the last constraintProvider meta-data to match your models
namespace and OCL file
<constraintProvider
class=" org.eclipse.emf.validation.examples.ocl.OCLConstraintProvide r "
category="Constraints from an OCL Document">
<package
namespaceUri=" http:///org/eclipse/emf/examples/library/extlibrary.ecore/1. 0.0"/>
<ocl path="constraints/Product_constraints.ocl"/>
</constraintProvider>
10. Edit plugin.xml in org.eclipse.emf.validation.examples.ocl and change
the namespaceUri as noted below
*Delete
*Insert http://www.mycompany/product
11. Fix dependencies in org.eclipse.emf.validation.examples.general
*Remove the following
*Insert the following
myProduct
myProduct.editor
myProduct.edit
myProduct.tests
12. Edit plugin.properties in org.eclipse.emf.validation.examples.general
EXTLibraryConstraintsCategory=EXT Library Constraints
NonEmptyNameConstraint=Non-Empty Names
NonEmptyNameConstraint.description=All items in an EXT library model
should have some unique identifier or name.
# 0 - An EClass(metaclass) name for the element that was found to have
no unique identifier.
NonEmptyNameConstraint.message=A {0} has been found to have no unique
identifier (name or title).
ProductConstraintsCategory=Product Constraints
13. Edit plugin.xml in org.eclipse.emf.validation.examples.general
*Replace the first <extension/> with the following
<extension point="org.eclipse.ui.editorActions">
<editorContribution
id=" org.eclipse.emf.validation.examples.general.editorContributi on "
targetID="product.presentation.ProductEditorID">
<menu
label="%_UI_ValidationMenu_label"
path="Product.ProductMenuID/additions"
id="org.eclipse.emf.validationMenuID">
<separator name="additions"/>
</menu>
<action
label="%ValidateElementsAction.label"
icon="$nl$/icons/elcl16/validate_co.gif"
class=" org.eclipse.emf.validation.examples.general.actions.BatchVal idationDelegate "
menubarPath="ProductMenuID/org.eclipse.emf.validationMenuID/additions "
id=" org.eclipse.emf.validation.pde.example.general.ui.validateAc tion "/>
<action
label="%EnableLiveValidationAction.label"
class=" org.eclipse.emf.validation.examples.general.actions.EnableLi veValidationDelegate "
id=" org.eclipse.emf.validation.pde.example.general.ui.enableLive ValidationAction "/>
<action
label="%ShowValidationEventsAction.label"
class=" org.eclipse.emf.validation.examples.general.actions.ShowVali dationEventsDelegate "
style="toggle"
state="false"
id=" org.eclipse.emf.validation.pde.example.general.ui.showValida tionEventsAction "/>
</editorContribution>
</extension>
<extension point="org.eclipse.ui.popupMenus">
<viewerContribution targetID="Product.presentation.ProductEditorID"
id=" org.eclipse.emf.validation.examples.general.viewerContributi on ">
<menu
path="additions"
</menu>
<action
menubarPath="org.eclipse.emf.validationMenuID/additions"
<action
<action
style="toggle"
state="false"
</viewerContribution>
</extension>
14. Edit plugin.xml in org.eclipse.emf.validation.examples.general
*Remove the following second <extension/>
<extension point="org.eclipse.emf.validation.constraintProviders">
<category
name="%ProductConstraintsCategory"
id="org.eclipse.emf.validation.pde.example.general.ui.library "/>
<constraintProvider cache="true">
<package
<constraints
categories="org.eclipse.emf.validation.pde.example.general.ui.library ">
<constraint lang="Java"
class=" org.eclipse.emf.validation.examples.general.constraints.NonE mptyNamesConstraint "
severity="ERROR"
mode="Live"
name="%NonEmptyNameConstraint"
id=" org.eclipse.emf.validation.pde.example.general.ui.NameNotEmp ty "
statusCode="1">
<description>
%NonEmptyNameConstraint.description
</description>
<message>
%NonEmptyNameConstraint.message
</message>
<target class="Library">
<event name="Set">
<feature name="name"/>
</event>
<event name="Unset">
</event>
</target>
<target class="Book">
<event name="Set">
<feature name="title"/>
</event>
</event>
</target>
</constraint>
</constraints>
</extension>
15. Edit the BatchValidationDeligate.java file in
Change the following to reflect your model settings
*Delete import
org.eclipse.emf.examples.extlibrary.presentation.EXTLibraryE ditor;
*Insert import
Product.presentation.ProductEditor;
*Delete
protected EXTLibraryEditor editor = null;
*Insert
protected ProductEditor editor = null;
*Delete
public void setActiveEditor(IAction action, IEditorPart targetEditor) {
this.editor = (EXTLibraryEditor) targetEditor;
if ( targetEditor != null ) {
this.shell = targetEditor.getSite().getShell();
*Insert
this.editor = (ProductEditor) targetEditor;
16. Edit the EnableLiveValidation.java file in
*Delete import
*Insert import
*Delete
*Insert
*Delete
*Insert
17. Edit the NonEmptyNamesConstraint.java file in
*Delete this file
18. Fix dependencies in org.eclipse.emf.validation.examples.adaptor
*Remove
*Insert
myProduct
19. Edit Startup.java file in org.eclipse.emf.validation.examples.adapter
*Delete
import org.eclipse.emf.examples.extlibrary.EXTLibraryPackage;
*Insert
import Product.ProductPackage;
*Delete
public void earlyStartup() {
EValidator.Registry.INSTANCE.put(
EXTLibraryPackage.eINSTANCE,
new EValidatorAdapter());
*Insert
ProductPackage.eINSTANCE,
20. Edit plugin.properties file in
*Remove
dependency org.eclipse.emf.examples.library
21. Edit plugin.xml file in org.eclipse.emf.validation.examples.adapter
*Delete
<extension point="org.eclipse.emf.validation.constraintBindings">
<clientContext id="org.eclipse.emf.validation.examples.adapter">
<enablement>
<and>
<instanceof value="org.eclipse.emf.ecore.EObject"/>
<test
property="org.eclipse.emf.validation.examples.adapter.ePackage "
value=" http:///org/eclipse/emf/examples/library/extlibrary.ecore/1. 0.0"/>
</and>
</enablement>
</clientContext>
<binding
context="org.eclipse.emf.validation.examples.adapter"
category="emf-validation-example"/>
</extension>
*Insert
<enablement>
<and>
<test
value="http://www.mycompany/product"/>
</and>
</enablement>
</clientContext>
<binding
</extension>
*Delete
<package
<constraints categories="emf-validation-example/adapter">
<constraint
lang="Java"
severity="INFO"
mode="Batch"
name="%example1.name"
id="example1"
statusCode="201"
class=" org.eclipse.emf.validation.examples.adapter.constraints.Exam pleConstraint ">
<description>%example1.desc</description>
<message>%example1.msg</message>
<!-- This constraint applies to any library element. -->
<target class="Library"/>
<target class="Writer"/>
<target class="Book"/>
</constraint>
</constraints>
*Insert
<package namespaceUri="http://www.mycompany/product"/>
<constraint
lang="Java"
severity="INFO"
mode="Batch"
id="example1"
statusCode="201"
</constraint>
</constraints>
22. Create a new Run Configuration so we can see the GEF editor for our
myModel.ecore
Run->Run->Run as Eclipse Application
This operation will result in a new Eclipse workspace session starting.
This new workspace will have the GEF based editor and OCL example plugins
built into it.
23. In the new workspace do the following.
Project name: myProduct
This will create a project to hold our instance model
24. In the new workspace do the following.
File->New->Example EMF Model Creation Wizards
Select Product Model
File name: my.Product
25. Create a model instance using the GEF editor
26. Validate the using the context menu (right click a model
element->Validation->Validate Elements... or simply right click a model
element->Validate)
27. Be impressed :)
| Re: An org.eclipse.emf.validation.examples.ocl example plug-in howto [message #64161 is a reply to message #64066] |
Tue, 04 November 2008 09:01   |
Originally posted by: cdamus.zeligsoft.com
Hi, Ronan,
(copying the EMF newsgroup which is home to this component)
I second Mark's comment: this is exactly the kind of contribution that
we are thrilled to see in the EMF Wiki. In fact, I think this would be
the first recipe for the validation component. Feel free to add it by
following the "Recipes" link, here:
http://wiki.eclipse.org/EMF/Validation#Documentation
As you probably know, the Wikipedia technology makes formatting a recipe
like yours a snap.
Thanks!
Christian
Ronan wrote:
> plugin to work [see
> howto for new users. If I have time, and if people are interested, I can
> convert this into an Eclipse Corner article. Any errors you find please
> report them.
> OCL constraints to be defined in a text file. These constraints are then
> Framework.
> based model editor
> <constraintProvider
> <package
> change the namespaceUri as noted below
> *Delete
> myProduct
> myProduct.editor
> myProduct.edit
> myProduct.tests
> <editorContribution
> <menu
> </menu>
> <action
> <action
> <action
> style="toggle"
> state="false"
> </extension>
> <menu
> path="additions"
> </menu>
> <action
> <action
> <action
> style="toggle"
> state="false"
> </extension>
> <category
> <package
> <constraints
> severity="ERROR"
> mode="Live"
> statusCode="1">
> <description>
> </description>
> <message>
> </message>
> <event name="Set">
> </event>
> </event>
> </target>
> <event name="Set">
> </event>
> </event>
> </target>
> </constraint>
> </constraints>
> </extension>
> *Delete import
> *Insert import Product.presentation.ProductEditor;
> *Delete protected EXTLibraryEditor editor = null;
> *Insert protected ProductEditor editor = null;
> *Delete
> *Insert
> *Delete import
> *Delete
> *Insert
> *Delete this file
> *Remove
> *Insert
> myProduct
> *Delete import
> *Insert import Product.ProductPackage;
> *Delete
> *Insert
> *Remove dependency org.eclipse.emf.examples.library
> *Delete
> <enablement>
> <and>
> <test
> </and>
> </enablement>
> </clientContext>
> <binding
> </extension>
> *Insert
> <enablement>
> <and>
> <test
> </and>
> </enablement>
> </clientContext>
> <binding
> </extension>
> *Delete
> <package
> <constraint
> lang="Java"
> severity="INFO"
> mode="Batch"
> id="example1"
> statusCode="201"
> </constraint>
> </constraints>
> *Insert
> <constraint
> lang="Java"
> severity="INFO"
> mode="Batch"
> id="example1"
> statusCode="201"
> </constraint>
> </constraints>
> myModel.ecore
> plugins built into it.
> element->Validate)
> 27. Be impressed :)
FUDForum. Page generated in 0.04331 seconds
