Home » Eclipse Projects » Remote Application Platform (RAP) » Custom widget tutorial problems
Custom widget tutorial problems [message #64060] Mon, 03 December 2007 12:16 Go to next message
Originally posted by: newsclient.server32212.xantronnet.de
Dear all,
I need help with the custom widget tutorial. I followed http://help.eclipse.org
/help33/topic/org.eclipse.rap.help/help/html/advanced/custom -widget.html as far
as possible, but probably I am missing some important steps.
Can I find the complete custom widget tutorial sources somewhere?
Here are my problems:
The internal browser shows the normal shaded blue background and nothing else.
The console displays:
osgi> Dec 3, 2007 5:47:41 PM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
Dec 3, 2007 5:47:41 PM org.mortbay.util.Container start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@13d28e3
INFO: Started HttpContext[/,/]
Dec 3, 2007 5:47:41 PM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:9090
INFO: Started org.mortbay.http.HttpServer@12a3722
I am most uncertain about the plugin.xml and MANIFEST.MF files. Could you
check these (below)?
If no obvious mistake is found in the following files, how can I check what
is going wrong, given that no error is displayed, but only the background is
displayed?
If I just remove the calls
>GMap map = new GMap( shell, SWT.NONE );
>map.setAddress( "Stephanienstraße 20, Karlsruhe" );
in gmapdemo and remove gmaps from the build path, there is still no widget
displayed. In addition I have to remove gmaps from the Bundles in the Launch
Configuration, so that an empty widget is then displayed.
Thank you
Eike
gmaps plugin.xml
<?eclipse version="3.2"?>
<plugin>
<extension
id="org.eclipse.rap.gmaps.gmap"
point="org.eclipse.rap.ui.resources">
<resource class="org.eclipse.rap.gmaps.GMapResource"/>
<resource class="org.eclipse.rap.gmaps.GMapAPIResource"/>
</extension>
</plugin>
gmaps MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: GMap Custom Widget
Bundle-SymbolicName: org.eclipse.rap.gmaps;singleton:=true
Bundle-Version: 1.0.0
Bundle-Vendor: RAP Team
Require-Bundle: org.eclipse.rap.ui
Export-Package: org.eclipse.rap.gmaps,
org.eclipse.rap.internal.gmaps.gmapkit
gmapdemo plugin.xml
<plugin>
<extension
point="org.eclipse.rap.ui.entrypoint">
<entrypoint
class="org.eclipse.rap.gmapdemo.GMapDemo"
id="org.eclipse.rap.gmapdemo.gmapentry"
parameter="hello2">
</entrypoint>
</extension>
<extension
point="org.eclipse.ui.perspectives">
<perspective
class="org.eclipse.rap.gmapdemo.Perspective"
id="org.eclipse.rap.gmapdemo.perspective2"
name="name">
</perspective>
</extension>
<extension
</extension>
</plugin>
gmapdemo MANIFEST.MF
Bundle-Name: Testgmap Plug-in
Bundle-SymbolicName: org.eclipse.rap.gmapdemo;singleton:=true
Import-Package: javax.servlet;version="2.4.0",
javax.servlet.http;version="2.4.0"
Export-Package: org.eclipse.rap.gmapdemo
Re: Custom widget tutorial problems [message #64197 is a reply to message #64060] Tue, 04 December 2007 03:49 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Eike,
regarding the source of the tutorial: that would be way too easy;) No,
seriously, I am not aware of that there is a complete download of the
source as described by the tutorial. However, the gmaps widget can be
found in the sandbox CVS module.
From what I can see, the plugin.xml and manifest snippets as well las
the console output look good. To further diagnose the problem:
* have you tried to type "ss" in the console. This will give you a list
of bundles along with their state which should be ACTIVE.
* to see exception messages in the console output that occur during
bundle startup, try to launch with program argument "-consolelog"
(ignore those AuthorizationHandler-something exceptions)
* assuming that you use the RAP launcher, you can enable client-side
debug- and error-messages by setting the "Client-side log level" to
"All" and the "Client-side library variant" to "Debug"
* hm, if all that isn't the case ... come back here;)
Rüdiger
newsclient@server32212.xantronnet.de wrote:
> Dear all,
> displayed?
> Thank you
> Eike
> gmaps plugin.xml
> <plugin>
> <extension
> </extension>
> </plugin>
> gmaps MANIFEST.MF
> gmapdemo plugin.xml
> <plugin>
> <extension
> <entrypoint
> parameter="hello2">
> </entrypoint>
> </extension>
> <extension
> <perspective
> name="name">
> </perspective>
> </extension>
> <extension
> </extension>
> </plugin>
Re: Custom widget tutorial problems [message #64220 is a reply to message #64197] Tue, 04 December 2007 04:39 Go to previous messageGo to next message
You are right. Just copying the code doesn't help me much. But if I'm not
successful following the description, a working solution can still allow
me to locate the cause of the problems.
>However, the gmaps widget can be found in the sandbox CVS module.
I'll try that. Although I suspect that rather some project settings are
wrong than the source code.
For example, I don't completely understand the differences, what I have to
put into the Build Path, into the "Dependencies", into "Require-bundle" in
MANIFEST.MF and into "Build". Is there some (general eclipse) good
overview on these questions?
> From what I can see, the plugin.xml and manifest snippets as well las the
>* have you tried to type "ss" in the console. This will give you a list of
all that are listed, are ACTIVE. (see below)
>* to see exception messages in the console output that occur during bundle
>startup, try to launch with program argument "-consolelog" (ignore those
Do you also mean to ignore (see below) this?
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/runtime/auth/AuthorizationHandler
>* assuming that you use the RAP launcher, you can enable client-side debug-
>and error-messages by setting the "Client-side log level" to "All" and the
I appreciate your hints. Any new clues from this consolelog?
Eike
comple console output:
(the GMap*Resource.*() messages stem from print statements which I added
to those functions)
osgi> !SESSION 2007-12-04 10:25:57.897
eclipse.buildId=unknown
java.version=1.6.0
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -dev
file:/home/eike/eclipseworkspace/eclipse33/.metadata/.plugin s/org.eclipse.pde.core/gmapdemo/dev.properties
-os linux -ws gtk -arch x86 -console -consolelog
!ENTRY org.eclipse.core.runtime 2 0 2007-12-04 10:25:59.006
!MESSAGE Authorization infrastructure
(org.eclipse.core.runtime.compatibility.auth) not installed.
!STACK 0
org.eclipse.core.internal.runtime.InternalPlatform.initializ eAuthorizationHandler(InternalPlatform.java:603)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:745)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:31)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.MultiSourcePackage. loadClass(MultiSourcePackage.java:31)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
Dec 4, 2007 10:26:00 AM org.mortbay.http.HttpServer doStart
Dec 4, 2007 10:26:00 AM org.mortbay.util.Container start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@136a43c
Dec 4, 2007 10:26:00 AM org.mortbay.http.SocketListener start
INFO: Started org.mortbay.http.HttpServer@3570b0
GMapResource.isExternal()
GMapResource.getLoader()
GMapResource.getCharset()
GMapResource.getOptions()
GMapResource.getLocation()
GMapResource.isJSLibrary()
GMapApiResource.isExternal()
GMapApiResource.getLocation()
ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
1 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.20071010-2241
2 ACTIVE org.eclipse.osgi.services_3.1.200.v20070605
3 ACTIVE org.eclipse.core.expressions_3.3.0.v20070606-0010
4 ACTIVE org.eclipse.rap.jface_1.0.0.20071010-2241
5 ACTIVE org.eclipse.rap.core.databinding_1.0.0.20071010-2241
6 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
7 ACTIVE org.eclipse.rap.ui_1.0.0.20071010-2241
8 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
9 ACTIVE org.eclipse.rap.ui.forms_1.0.0.20071010-2241
10 ACTIVE org.eclipse.rap.ui.views_1.0.0.20071010-2241
12 ACTIVE org.eclipse.rap.source_1.0.0.20071010-2241
13 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
14 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.20071010-2241
15 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
16 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
17 ACTIVE javax.servlet_2.4.0.20071010-2241
18 ACTIVE org.eclipse.core.commands_3.3.0.I20070605-0010
19 ACTIVE org.eclipse.rap.jface.databinding_1.0.0.20071010-2241
20 ACTIVE org.eclipse.equinox.http.jetty_1.0.0.20071010-2241
21 ACTIVE org.eclipse.rap.core.databinding.beans_1.0.0.20071010-2241
22 ACTIVE org.apache.commons.logging_1.0.4.20071010-2241
23 ACTIVE org.eclipse.rap.demo.databinding_1.0.0.20071010-2241
24 ACTIVE org.mortbay.jetty_5.1.11.20071010-2241
25 ACTIVE org.eclipse.rap.rwt_1.0.0.20071010-2241
26 ACTIVE org.eclipse.core.contenttype_3.2.100.v20070319
27 ACTIVE org.eclipse.equinox.http.registry_1.0.0.20071010-2241
28 ACTIVE org.eclipse.rap.demo_1.0.0.20071010-2241
29 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
31 ACTIVE org.eclipse.rap.gmaps_1.0.0
32 ACTIVE org.eclipse.rap.gmapdemo_1.0.0
osgi>
Re: Custom widget tutorial problems [message #64332 is a reply to message #64220] Tue, 04 December 2007 09:35 Go to previous messageGo to next message
Eike,
please see my comments below.
Rüdiger
> not successful following the description, a working solution can still
> allow me to locate the cause of the problems.
My answer regarding the source code was meant in good fun. You are
right, the tutorial source code should be available. We will try to
provide this in the near future.
> to put into the Build Path, into the "Dependencies", into
As a general rule, don't use the Build Path except for the JRE System
Library when PDE is involved. All references to plug-ins as well as
libraries 'embedded' in the plug-in are declared in the MANIFEST.MF.
The dependencies page is a more user-friendly representation of what is
described by Require-Bundle and Import-Package in the MANIFEST.MF
> "Require-bundle" in MANIFEST.MF and into "Build". Is there some (general
> eclipse) good overview on these questions?
- Search the resources page of eclipse.org
http://www.eclipse.org/resources
there is also a "Getting Started" link on the left that
lists some articles
- Eclipse help: The Platform Plug-in developer guide
http://help.eclipse.org/help33/index.jsp
>> list of bundles along with their state which should be ACTIVE.
Yes
Have you tried to enable the client-side debug messages?
Please note that RAP runs only on Safari, IE and FF.
the consolelog and the ss output looks like it should.
> Eike
> to those functions)
> java.version=1.6.0
> !STACK 0
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ss
> id State Bundle
> 21 ACTIVE
> osgi>
Re: Custom widget tutorial problems [message #64354 is a reply to message #64332] Tue, 04 December 2007 10:53 Go to previous messageGo to next message
Thank you, I got a working widget!
I did understand it as fun :-)
I just wanted to point out that I agree, I consider the "way too easy"
tutorial not as the ideal way how to teach things, but nevertheless it is
a valuable "emergency exit".
Got it, combined it with the GMapDemo from the written tutorial, and it
works. Now I can find out where my mistake was hidden. I don't promise it
(knowing me) but I hope to post a final answer once I know the reason and
if it was not too stupid.
(BTW, while struggling with this tutorial I found some comments on two or
three typos (like "if( parent.classname ==
"org.eclipse.rap.rwt.widgets.Shell" ) {" in GMap.js where the "rap.rwt"
needs to be "swt". The answer was "Yep we forgot to update that stuff". If
you belong to the tutorial authors, pleeeeaaase do those updates).
Thank you :-))
Eike
Re: Custom widget tutorial problems [message #64400 is a reply to message #64354] Tue, 04 December 2007 11:05 Go to previous messageGo to next message
Eike,
good to hear that it finally worked out. I forwarded the typos to the
author.
Rüdiger
>>> still allow me to locate the cause of the problems.
> is a valuable "emergency exit".
> it (knowing me) but I hope to post a final answer once I know the reason
> and if it was not too stupid.
> or three typos (like "if( parent.classname ==
> If you belong to the tutorial authors, pleeeeaaase do those updates).
> Thank you :-))
> Eike
Re: Custom widget tutorial problems SOLVED [message #64446 is a reply to message #64332] Tue, 04 December 2007 12:15 Go to previous message
Finally it was the missing line "members:{" in the GMap.js that I copied
and pasted from the eclipse help.
Other replies when someone was fighting with the Javascript suggested to
open the script in a js validating editor. Is this the only possibility?
Yes, I did, without any more output.
Is there no setting so that RAP reports or throws an Exception for broken
Javascript?
Eike
Previous Topic:UICallback Mechanism
Next Topic:Date Chooser in the Rap Workbench Demo
Current Time: Mon Jul 21 20:55:30 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
