Home » Eclipse Projects » Mylyn » Temporary TaskDeactivation while launching External Tools
Temporary TaskDeactivation while launching External Tools [message #63975] |
Wed, 07 January 2009 11:21  |
Dear Sirs.
We have some Launches defined, with the "External Tools Configuration"
feature in Eclipse. (Mostly these are build.xml files for ant).
These launches generate java-classes, based on a XML-file containing
message-definitions.
(After a Launch is finnished, Eclipse allowes to specify that the
workspace should be refreshed.Which compiles the generated java-classes)
The problem is, that the generated java-classes show up in the active
Mylyn task. Even though they never have been in any Editor.
It would be great, if the Active task, was temporarily deactivated,
while this auto-generation & compilation takes place.
Possibly this temporaty deactivation would best be placed in
in the "Refresh-folder" of the "External Tools Configuration" window.
Perhaps there are even better solutions.
Best regards
Ivan P.
Re: Temporary TaskDeactivation while launching External Tools [message #63998 is a reply to message #63975] |
Thu, 08 January 2009 03:05   |
Hello Ivan,
please see this bug:
254423: Provide easy way to temporarily disable interest tracking
https://bugs.eclipse.org/bugs/show_bug.cgi?id=254423
and the check whether the suggestions from Steffen would improve your situation.
Comment and vote on this bug if you also need further improvements.
Cheers, Jörg
On 01/07/09 17:21, Ivan Pea wrote:
> Dear Sirs.
> Possibly this temporaty deactivation would best be placed in in the
> Best regards Ivan P.
Re: Temporary TaskDeactivation while launching External Tools [message #64019 is a reply to message #63975] |
Thu, 08 January 2009 03:18  |
Hello Ivan,
This bug is already resolved with regard to version control checkouts:
120499: [context] make explicitly created resources interesting, and ignore others, e.g. from CVS
checkout
https://bugs.eclipse.org/bugs/show_bug.cgi?id=120499
but I feel it does not take care about other implicit updates, e.g. by workspace refreshs.
Cheers, Jörg
> Dear Sirs.
Re: Temporary TaskDeactivation while launching External Tools [message #595660 is a reply to message #63975] |
Hello Ivan,
Cheers, Jörg
> Dear Sirs.
Re: Temporary TaskDeactivation while launching External Tools [message #595665 is a reply to message #63975] |
Hello Ivan,
checkout
Cheers, Jörg
> Dear Sirs.
Current Time: Sat Jul 26 19:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.03548 seconds
