Home » Archived » XML Schema Definition (XSD) » errors using XSD as plugin, UnknownHostException and NPE
errors using XSD as plugin, UnknownHostException and NPE [message #63953] Tue, 27 September 2005 13:58 Go to next message
I have previously used the wonderful XSD support standalone, using
xsd.[resource].jar, common.[resource].jar and core.[resource].jar with
version 2.0.1.
I have since migrated to SWT and RCP (on version 3.1) and am now using
it as a plug in. I have removed the above jar files and and replaced
them with these jar files (which of course include quite a bit more than
XSD):
org.eclipse.core.resources_3.1.0.jar org.eclipse.osgi_3.1.0.jar
org.eclipse.core.resources.linux_3.1.0.jar
org.eclipse.swt.gtk.linux.x86_3.1.0.jar
org.eclipse.core.runtime_3.1.0.jar org.eclipse.ui_3.1.0.jar
org.eclipse.emf.common_2.1.0.jar org.eclipse.ui.ide_3.1.0.jar
org.eclipse.emf.ecore_2.1.0.jar org.eclipse.ui.views_3.1.0.jar
org.eclipse.jface_3.1.0.jar
org.eclipse.ui.workbench_3.1.0.jar
org.eclipse.jface.text_3.1.0.jar org.eclipse.xsd_2.1.0.jar
I have also added the the following dependent plugins:
Require-Bundle: org.eclipse.jface,
org.eclipse.jface.text,
org.eclipse.osgi,
org.eclipse.swt,
org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.osgi.util,
org.eclipse.osgi.services,
org.eclipse.ui.views,
org.eclipse.ui.ide,
org.eclipse.ui.editors,
org.eclipse.ui.workbench.texteditor,
org.junit,
org.eclipse.emf.common,
org.eclipse.emf.ecore,
org.eclipse.xsd,
org.eclipse.emf.importer,
org.eclipse.emf.importer.ecore,
org.eclipse.xsd.ecore.importer
With all this, running the same tests that used to work fine, I'm
getting the following errors when I try to import an .xsd file.
Any ideas?
Francis
!SESSION 2005-09-27 10:50:03.485
eclipse.buildId=unknown
java.version=1.4.2_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -version 3 -application
org.eclipse.pde.junit.runtime.uitestapplication -product
com.oaklandsw.transform.product -pdelaunch -port 34067 -testpluginname
com.oaklandsw.transform -test
com.oaklandsw.transform.XsdSimpleImportTest:testBasic
Command-line arguments: -version 3 -application
com.oaklandsw.transform.product -data
/home/francis/junit-workbench-workspace -dev
file:/home/francis/d/.metadata/.plugins/org.eclipse.pde.core /XsdSimpleImportTest.testBasic/dev.properties
-pdelaunch -os linux -ws gtk -arch x86 -port 34067 -testpluginname
!ENTRY org.eclipse.ui 4 4 2005-09-27 10:50:11.33
!MESSAGE Invalid Menu Extension (Path is invalid):
org.eclipse.ui.edit.text.gotoLastEditPosition
!ENTRY org.eclipse.xsd 2 0 2005-09-27 10:50:14.290
!MESSAGE bundleentry
!STACK 0
java.net.UnknownHostException: bundleentry
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:153)
at java.net.Socket.connect(Socket.java:452)
at java.net.Socket.connect(Socket.java:402)
at sun.net.NetworkClient.doConnect(NetworkClient.java:139)
at sun.net.NetworkClient.openServer(NetworkClient.java:118)
at sun.net.ftp.FtpClient.openServer(FtpClient.java:423)
at sun.net.ftp.FtpClient.<init>(FtpClient.java:692)
sun.net.www.protocol.ftp.FtpURLConnection.connect(FtpURLConn ection.java:175)
sun.net.www.protocol.ftp.FtpURLConnection.getInputStream(Ftp URLConnection.java:257)
at java.net.URL.openStream(URL.java:913)
org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(U nknown Source)
at org.apache.xerces.impl.XMLEntityManager.startEntity(Unknown
Source)
Source)
at org.apache.xerces.impl.XMLDTDScannerImpl.startPE(Unknown Source)
org.apache.xerces.impl.XMLDTDScannerImpl.skipSeparator(Unkno wn Source)
at org.apache.xerces.impl.XMLDTDScannerImpl.scanDecls(Unknown
Source)
org.apache.xerces.impl.XMLDTDScannerImpl.scanDTDExternalSubs et(Unknown
Source)
org.apache.xerces.impl.XMLDocumentScannerImpl$DTDDispatcher. dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown
Source)
at org.apache.xerces.parsers.DTDConfiguration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
org.eclipse.xsd.util.XSDResourceImpl.getDocument(XSDResource Impl.java:238)
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:412)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:977)
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:398)
org.eclipse.xsd.impl.XSDImportImpl.importSchema(XSDImportImp l.java:476)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2120)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveNamedComponent(XSD SchemaImpl.java:2143)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveAttributeDeclarati on(XSDSchemaImpl.java:2168)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.resolveAttribu teDeclaration(XSDConcreteComponentImpl.java:2469)
org.eclipse.xsd.impl.XSDAttributeDeclarationImpl.patch(XSDAt tributeDeclarationImpl.java:203)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcr eteComponentImpl.java:526)
org.eclipse.xsd.impl.XSDAttributeUseImpl.patch(XSDAttributeU seImpl.java:738)
org.eclipse.xsd.impl.XSDNamedComponentImpl.patch(XSDNamedCom ponentImpl.java:727)
org.eclipse.xsd.impl.XSDTypeDefinitionImpl.patch(XSDTypeDefi nitionImpl.java:249)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.patch(XSDC omplexTypeDefinitionImpl.java:994)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.patch(XSDElem entDeclarationImpl.java:546)
org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1493)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2314)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1219)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:825)
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:489)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:832)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:609)
org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:420)
org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSD ResourceImpl.java:536)
org.eclipse.xsd.util.XSDResourceImpl.findSchemas(XSDResource Impl.java:502)
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:431)
com.oaklandsw.transform.rep.xml.XsdImportProcessor.importFro mFile(XsdImportProcessor.java:178)
com.oaklandsw.transform.rep.xml.XsdImporter.doImportSubclass (XsdImporter.java:42)
com.oaklandsw.transform.editor.Importer.doImport(Importer.ja va:338)
com.oaklandsw.transform.editor.Importer.doImport(Importer.ja va:322)
com.oaklandsw.transform.TransformTestBase.importXsdDefinitio n(TransformTestBase.java:1711)
com.oaklandsw.transform.TransformTestBase.testXsdImport(Tran sformTestBase.java:1926)
com.oaklandsw.transform.TransformTestBase.testXsdImport(Tran sformTestBase.java:1905)
com.oaklandsw.transform.TransformTestBase.testXsdImport(Tran sformTestBase.java:1891)
com.oaklandsw.transform.XsdSimpleImportTest.testBasic(XsdSim pleImportTest.java:43)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:478)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:344)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:57)
org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:99)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2844)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2575)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
com.oaklandsw.transform.editor.Editor.runEditor(Editor.java: 2111)
com.oaklandsw.transform.editor.Standalone.run(Standalone.jav a:72)
org.eclipse.pde.internal.junit.runtime.UITestApplication.run (UITestApplication.java:39)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.xsd 2 0 2005-09-27 10:50:14.505
!MESSAGE
!STACK 0
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.handleNewB aseTypeDefinition(XSDComplexTypeDefinitionImpl.java:2046)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.handleReco nciliation(XSDComplexTypeDefinitionImpl.java:2329)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.reconcileConte nts(XSDConcreteComponentImpl.java:1032)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.reconcile(XSDC oncreteComponentImpl.java:966)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.elementChanged (XSDConcreteComponentImpl.java:411)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.adoptContent(X SDConcreteComponentImpl.java:1360)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.adoptContent( XSDElementDeclarationImpl.java:1456)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1182)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.eNotify(XSDEl ementDeclarationImpl.java:1380)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:113)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:101)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.setAnonymousT ypeDefinition(XSDElementDeclarationImpl.java:1765)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.handleReconci liation(XSDElementDeclarationImpl.java:1229)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.reconcileCont ents(XSDElementDeclarationImpl.java:1175)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.elementContent sChanged(XSDConcreteComponentImpl.java:473)
org.eclipse.xsd.impl.XSDParticleImpl.reconcileContents(XSDPa rticleImpl.java:664)
org.eclipse.xsd.impl.XSDModelGroupImpl.adoptContent(XSDModel GroupImpl.java:693)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1139)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:288)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 99)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setListContent AndOrder(XSDConcreteComponentImpl.java:2094)
org.eclipse.xsd.impl.XSDModelGroupImpl.handleReconciliation( XSDModelGroupImpl.java:657)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.adoptConte nt(XSDComplexTypeDefinitionImpl.java:2600)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.setContent (XSDComplexTypeDefinitionImpl.java:758)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.handleReco nciliation(XSDComplexTypeDefinitionImpl.java:2240)
org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1763)
org.eclipse.xsd.impl.XSDSchemaImpl.handleReconciliation(XSDS chemaImpl.java:1985)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.changeAttribut e(XSDConcreteComponentImpl.java:1246)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2318)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElementGen( XSDConcreteComponentImpl.java:2817)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElement(XSD ConcreteComponentImpl.java:2849)
org.eclipse.xsd.impl.XSDSchemaImpl.setElement(XSDSchemaImpl. java:2441)
org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:422)
main ~/junit-workbench-workspace/.metadata>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #63982 is a reply to message #63953] Tue, 27 September 2005 14:08 Go to previous messageGo to next message
Francis,
You aren't putting these jars on the classpath explicitly are you?
I would also expect bundleentry to have a registered protocol handler so
that creating a URL for it would not fail in the way you showed...
> version 2.0.1.
> than XSD):
> org.eclipse.jface_3.1.0.jar org.eclipse.ui.workbench_3.1.0.jar
> org.eclipse.osgi,
> org.eclipse.swt,
> org.eclipse.ui,
> org.eclipse.ui.ide,
> org.junit,
> org.eclipse.xsd,
> Any ideas?
> Francis
> !STACK 0
> at
> at
> at
> Source)
> Source)
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64007 is a reply to message #63982] Tue, 27 September 2005 17:32 Go to previous messageGo to next message
Ed Merks wrote:
> Francis,
I have added the jars to the java build path/libraries tab, as I have
always done. Is this not the way to do it?
Regarding the bundleentry thing, here are some of the variable values
from the XSDSchemaImpl.resolveSchema() stack frame:
this:
org.eclipse.xsd.impl.XSDSchemaImpl@1533b2c (element: [xs:schema: null])
(document: [#document: null], schemaLocation:
bundleentry://141/cache/www.w3.org/2001/XMLSchema.xsd, targetNamespace:
http://www.w3.org/2001/XMLSchema, attributeFormDefault: <unset>,
elementFormDefault: qualified, finalDefault: [], blockDefault: [all],
version: 1.0)
xsdImport:
org.eclipse.xsd.impl.XSDImportImpl@4e76b4 (element: [xs:import: null])
(schemaLocation: http://www.w3.org/2001/xml.xsd) (namespace:
http://www.w3.org/XML/1998/namespace)
namespace:
So it looks like it's trying to resolve something from one of the built
in schemas.
It seems that I have some of my plumbing messed up here, but I'm not
sure how I should fix it.
>> version 2.0.1.
>> than XSD):
>> org.eclipse.osgi,
>> org.eclipse.swt,
>> org.eclipse.ui,
>> org.eclipse.ui.ide,
>> org.junit,
>> org.eclipse.xsd,
>> Any ideas?
>> Thanks,
>> Francis
>> !STACK 0
>> at
>> at
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64033 is a reply to message #64007] Tue, 27 September 2005 19:24 Go to previous messageGo to next message
Francis,
No! When running an Eclipse headless invocation you don't put anything
on the classpath except the startup.jar. If you put plugin jars on the
classpath, you'll by pass the normal plugin initialization that is
supposed to happen. In this case you are loading the cached "meta"
schemas from the org.eclipse.xsd plugin, which should normally work
fine, but I'm quite sure the classpath thing is going to mess it up...
> Ed Merks wrote:
>> Francis,
>> so that creating a URL for it would not fail in the way you showed...
> this:
> null]) (document: [#document: null], schemaLocation:
> targetNamespace: http://www.w3.org/2001/XMLSchema,
> attributeFormDefault: <unset>, elementFormDefault: qualified,
> finalDefault: [], blockDefault: [all], version: 1.0)
> xsdImport:
> namespace:
> built in schemas.
>>> with version 2.0.1.
>>> using it as a plug in. I have removed the above jar files and and
>>> replaced them with these jar files (which of course include quite a
>>> bit more than XSD):
>>> org.eclipse.osgi,
>>> org.eclipse.swt,
>>> org.eclipse.ui,
>>> org.eclipse.ui.ide,
>>> org.junit,
>>> org.eclipse.xsd,
>>> Any ideas?
>>> Thanks,
>>> Francis
>>> -testpluginname com.oaklandsw.transform -test
>>> !STACK 0
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> org.apache.xerces.impl.XMLEntityManager.startEntity(Unknown Source)
>>> at
>>> Source)
>>> at
>>> at
>>> org.apache.xerces.impl.XMLDTDScannerImpl.scanDecls(Unknown Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
>>> Source)
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !MESSAGE
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64057 is a reply to message #64033] Wed, 28 September 2005 02:21 Go to previous messageGo to next message
Ed,
I'm still confused. First, I'm not executing headless; this is an RCP
application which is created from a plugin as a product. There is
nothing the class of the plugin - here is the manifest.mf:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Oakland Software Data Mapper
Bundle-SymbolicName: com.oaklandsw.transform; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: com.oaklandsw.transform.editor.TransformPlugin
Bundle-Localization: plugin
org.eclipse.osgi,
org.eclipse.swt,
org.eclipse.ui,
org.eclipse.ui.ide,
org.junit,
org.eclipse.xsd,
Eclipse-AutoStart: true
I have the jars for all of the eclipse stuff (including SWT, jface,
runtime, emf, xsd) in my java build path (Project -> Properties -> Java
BuildPath -> Library) so that my code can compile, but I don't think
this puts things in the classpath when the plugin is being executed.
I still don't know what to do to fix the problem. Thanks for your
patience with me if I'm missing something obvious.
Francis
Ed Merks wrote:
> Francis,
>> Ed Merks wrote:
>>> Francis,
>> this:
>> xsdImport:
>> namespace:
>> built in schemas.
>>>> with version 2.0.1.
>>>> bit more than XSD):
>>>> org.eclipse.osgi,
>>>> org.eclipse.swt,
>>>> org.eclipse.ui,
>>>> org.eclipse.ui.ide,
>>>> org.junit,
>>>> org.eclipse.xsd,
>>>> Any ideas?
>>>> Thanks,
>>>> Francis
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !MESSAGE
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64081 is a reply to message #64057] Wed, 28 September 2005 05:28 Go to previous messageGo to next message
Ed,
I hope you disregarded my previous post. I'm no longer confused about
the classpath issue and have removed all of the org.eclipse.* from the
build path libraries, as I can see now that they come in with the
plugins if the dependencies are correctly declared.
I built everything clean, deleted my run configurations, and yet I still
get exactly the same problem.
It looks like getDocument() is being called to parse:
http://www.w3.org/2001/xml.xsd. It has been called a couple of other
times previously (and successfully) to parse documents where the URI
scheme is "bundled".
However, in the failing call, the parser tries to open the URL:
" file://bundleentry://141/cache/www.w3.org/2001/datatypes.dtd"
which goes to the FTP client and then fails because of the invalid host
on bundleentry. Seems like this URL is bad.
This same error and stacktrace has appeared before, in the tools.emf
newsgroup, with the title "XSD metamodel: Error trying to load xsd
resources into the resourceset." on 3 Jun 05. The resolution of the
problem was not posted.
Can you give me some hints to debug this?
Francis
> Ed,
> org.eclipse.osgi,
> org.eclipse.swt,
> org.eclipse.ui,
> org.eclipse.ui.ide,
> org.junit,
> org.eclipse.xsd,
> Francis
> Ed Merks wrote:
>> Francis,
>> anything on the classpath except the startup.jar. If you put plugin
>> jars on the classpath, you'll by pass the normal plugin initialization
>> that is supposed to happen. In this case you are loading the cached
>> "meta" schemas from the org.eclipse.xsd plugin, which should normally
>> work fine, but I'm quite sure the classpath thing is going to mess it
>> up...
>>> Ed Merks wrote:
>>>> Francis,
>>>> handler so that creating a URL for it would not fail in the way you
>>>> showed...
>>> this:
>>> xsdImport:
>>> null]) (schemaLocation: http://www.w3.org/2001/xml.xsd) (namespace:
>>> namespace:
>>> built in schemas.
>>>>> with version 2.0.1.
>>>>> bit more than XSD):
>>>>> org.eclipse.osgi,
>>>>> org.eclipse.swt,
>>>>> org.eclipse.ui,
>>>>> org.eclipse.ui.ide,
>>>>> org.junit,
>>>>> org.eclipse.xsd,
>>>>> Any ideas?
>>>>> Thanks,
>>>>> Francis
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !MESSAGE
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64105 is a reply to message #64081] Wed, 28 September 2005 06:19 Go to previous messageGo to next message
Good morning Ed,
I have resolved the first of the two exceptions. It was caused by
inconsistent xerces jar files from two different versions. Sorry about
troubling you for that, and my punishment is that my sloppyness will be
enshrined here for public view by future generations.
However, the 2nd NPE still remains (I copied the stack trace below this
message). In this case, it is trying to get the "schema for schema",
but in the schema being parsed, the qNamePrefixToNamespaceMap is empty,
but the schemaForSchemaQnamePrefix contains "xsd" which is what I would
expect.
Here is the XSD file (which has worked fine in the past):
<?xml version="1.0" encoding="UTF-8" ?>
simple xsd document
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://www.publishing.org"
xmlns="http://www.publishing.org"
elementFormDefault="qualified">
<xsd:element name="BookCatalogue">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="Book" minOccurs="1"
maxOccurs="unbounded">
<xsd:complexType>
<xsd:sequence>
<xsd:element
name="Title" type="xsd:string" minOccurs="1" maxOccurs="1"/>
<xsd:element
name="Author" type="xsd:string" minOccurs="1" maxOccurs="2"/>
<xsd:element
name="Date" type="xsd:string" minOccurs="1" maxOccurs="1"/>
<!-- ISBN
element is optional for the sake of testing -->
<xsd:element
name="ISBN" type="xsd:string" minOccurs="0" maxOccurs="1"/>
<xsd:element
name="Publisher" type="xsd:string" minOccurs="1" maxOccurs="1"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64134 is a reply to message #64105] Wed, 28 September 2005 07:41 Go to previous messageGo to next message
--------------010901020603010302050600
Francis,
I can't duplicate this problem. The prefix map should have been
populated by this code in XSDSchemaImpl.reconcileAttributes:
Map theQNamePrefixToNamespaceMap = getQNamePrefixToNamespaceMap();
theQNamePrefixToNamespaceMap.clear();
for (Element currentElement = changedElement; currentElement
!= null; )
NamedNodeMap attributes = currentElement.getAttributes();
for (int i = 0, size = attributes.getLength(); i < size; ++i)
Attr attr = (Attr)attributes.item(i);
String name = attr.getNodeName();
if (name.startsWith("xmlns"))
String value = attr.getNodeValue();
int index = name.indexOf(":");
String key = index == -1 ? null : name.substring(index
+ 1);
if (!theQNamePrefixToNamespaceMap.containsKey(key))
theQNamePrefixToNamespaceMap.put(key, value);
Node parent = currentElement.getParentNode();
if (parent instanceof Element)
currentElement = (Element)parent;
else
break;
Maybe you could step through that and see why no prefix mappings are
being populated.
> Good morning Ed,
> about troubling you for that, and my punishment is that my sloppyness
> will be enshrined here for public view by future generations.
> this message). In this case, it is trying to get the "schema for
> schema", but in the schema being parsed, the qNamePrefixToNamespaceMap
> is empty, but the schemaForSchemaQnamePrefix contains "xsd" which is
> what I would expect.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> simple xsd document
> <xsd:complexType>
> <xsd:sequence>
> minOccurs="1" maxOccurs="unbounded">
> <xsd:complexType>
> <xsd:sequence>
> <xsd:element
> <xsd:element
> <xsd:element
> <!-- ISBN
> <xsd:element
> <xsd:element
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
<html>
<head>
</head>
Francis,<br>
<br>
I can't duplicate this problem.&nbsp; The prefix map should have been
populated by this code in XSDSchemaImpl.reconcileAttributes:<br>
<blockquote><small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Map theQNamePrefixToNamespaceMap =
getQNamePrefixToNamespaceMap();</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; theQNamePrefixToNamespaceMap.clear();</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for (Element currentElement = changedElement;
currentElement != null; ) </small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; NamedNodeMap attributes =
currentElement.getAttributes(); </small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; for (int i = 0, size = attributes.getLength(); i &lt;
size; ++i)</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Attr attr = (Attr)attributes.item(i);</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; String name = attr.getNodeName();</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (name.startsWith("xmlns"))</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; String value = attr.getNodeValue();</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; int index = name.indexOf(":");</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; String key&nbsp; = index == -1 ? null :
name.substring(index + 1);</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if
(!theQNamePrefixToNamespaceMap.containsKey(key)) </small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; theQNamePrefixToNamespaceMap.put(key, value);</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; Node parent = currentElement.getParentNode(); </small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (parent instanceof Element)</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; currentElement = (Element)parent;</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; break;</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; } </small><br>
</blockquote>
being populated.<br>
<br>
<br>
<blockquote cite="middhdqo7$jbk$1@news.eclipse.org" type="cite">Good
morning Ed,
<br>
<br>
I have resolved the first of the two exceptions.&nbsp; It was caused by
inconsistent xerces jar files from two different versions.&nbsp; Sorry about
<br>
<br>
message).&nbsp; In this case, it is trying to get the "schema for schema",
expect.
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at java.lang.reflect.Method.invoke(Method.java:324)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at junit.framework.TestCase.runTest(TestCase.java:154)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at junit.framework.TestCase.runBare(TestCase.java:127)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at junit.framework.TestResult$1.protect(TestResult.java:106)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at junit.framework.TestResult.runProtected(TestResult.java:124)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at junit.framework.TestResult.run(TestResult.java:109)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at junit.framework.TestCase.run(TestCase.java:118)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.launcher.Main.run(Main.java:973)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.launcher.Main.main(Main.java:948)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&lt;?xml version="1.0" encoding="UTF-8" ?&gt;
<br>
&lt;!--
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; simple xsd document
<br>
--&gt;
<br>
&lt;xsd:schema xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://www.publishing.org">"http://www.publishing.org"</a>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; xmlns=<a class="moz-txt-link-rfc2396E" href="http://www.publishing.org">"http://www.publishing.org"</a>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; elementFormDefault="qualified"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;xsd:element name="BookCatalogue"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;xsd:complexType&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:sequence&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;xsd:element name="Book"&nbsp;
minOccurs="1" maxOccurs="unbounded"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;xsd:complexType&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:sequence&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;xsd:element
name="Title" type="xsd:string" minOccurs="1" maxOccurs="1"/&gt;
<br>
name="Author" type="xsd:string" minOccurs="1" maxOccurs="2"/&gt;
<br>
name="Date" type="xsd:string" minOccurs="1" maxOccurs="1"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;!-- ISBN
element is optional for the sake of testing --&gt;
<br>
name="ISBN" type="xsd:string" minOccurs="0" maxOccurs="1"/&gt;
<br>
name="Publisher" type="xsd:string" minOccurs="1" maxOccurs="1"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:sequence&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;/xsd:complexType&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;/xsd:element&gt;
<br>
<br>
<br>
<br>
&lt;/xsd:schema&gt;
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------010901020603010302050600--
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64158 is a reply to message #64134] Wed, 28 September 2005 13:16 Go to previous messageGo to next message
Ed,
I have stepped through the code and the xmlns attribute is not present
in the Element. The element is of type
org.apache.xerces.dom.ElementNsImpl, and the namespace information is
provided in fields of that element.
I'm guessing this alteration of the element is caused by the:
http://xml.org/sax/features/namespaces feature of the Xerces parser,
which is by default set to true.
See: http://xml.apache.org/xerces2-j/features.html
How are the features controls for Xerces as used by the XSd stuff?
Francis
Ed Merks wrote:
> Francis,
> != null; )
> + 1);
> else
> break;
> being populated.
>> Good morning Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> simple xsd document
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:element
>> <xsd:element
>> <xsd:element
>> <!-- ISBN
>> <xsd:element
>> <xsd:element
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64184 is a reply to message #64158] Wed, 28 September 2005 13:41 Go to previous messageGo to next message
Ed,
Ok, I found the problem. The SAX parser that is was using was the
ancient alfraed parser, not the Xerces one. I already had this code for
the DOM parser.
System.setProperty("javax.xml.parsers.DocumentBuilderFactory ",
"org.apache.xerces.jaxp.DocumentBuilderFactoryImpl");
I added this line for the SAX parser:
System.setProperty("javax.xml.parsers.SAXParserFactory",
"org.apache.xerces.jaxp.SAXParserFactoryImpl");
Thanks for your help.
Francis
> Ed,
> Francis
> Ed Merks wrote:
>> Francis,
>> != null; )
>> + 1);
>> else
>> break;
>> being populated.
>>> Good morning Ed,
>>> qNamePrefixToNamespaceMap is empty, but the
>>> schemaForSchemaQnamePrefix contains "xsd" which is what I would expect.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> simple xsd document
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:element
>>> <xsd:element
>>> <xsd:element
>>> <!-- ISBN
>>> <xsd:element
>>> <xsd:element
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64219 is a reply to message #64158] Wed, 28 September 2005 14:28 Go to previous messageGo to next message
--------------010502000104010207030106
Francis,
Yes, it sounds like a namespace awareness problem.
XSDParser.createDocument is used to create new Documents.
public static Document createDocument()
try
DocumentBuilderFactory documentBuilderFactory =
DocumentBuilderFactory.newInstance();
documentBuilderFactory.setNamespaceAware(true);
documentBuilderFactory.setValidating(false);
DocumentBuilder documentBuilder =
documentBuilderFactory.newDocumentBuilder();
return documentBuilder.newDocument();
catch (ParserConfigurationException exception)
XSDPlugin.INSTANCE.log(exception);
return null;
Or the XSDResourceImpl does it directly:
protected static Document getDocument(InputSource inputSource,
ErrorHandler errorHandler) throws IOException
try
// Create a catalog with an entity mapping URL for the cached
DTD for XML Schemas and set to into the build.
EntityResolver entityResolver = createEntityResolver();
documentBuilder.setEntityResolver(entityResolver);
documentBuilder.setErrorHandler(errorHandler);
Document document = documentBuilder.parse(inputSource);
return document;
throw new IOWrappedException(exception);
catch (SAXException exception)
> Ed,
> Francis
> Ed Merks wrote:
>> Francis,
>> != null; )
>> ++i)
>> + 1);
>> else
>> break;
>> being populated.
>>> Good morning Ed,
>>> sloppyness will be enshrined here for public view by future
>>> generations.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> simple xsd document
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:element
>>> <xsd:element
>>> <xsd:element
>>> <!-- ISBN
>>> <xsd:element
>>> <xsd:element
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:schema>
<html>
<head>
</head>
Francis,<br>
<br>
Yes, it sounds like a namespace awareness problem.&nbsp;&nbsp;
XSDParser.createDocument is used to create new Documents.<br>
<blockquote><small>&nbsp; public static Document createDocument()<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; try<br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; DocumentBuilderFactory documentBuilderFactory =
DocumentBuilderFactory.newInstance();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; documentBuilderFactory.setNamespaceAware(true);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; documentBuilderFactory.setValidating(false);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; DocumentBuilder documentBuilder =
documentBuilderFactory.newDocumentBuilder();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return documentBuilder.newDocument();<br>
&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp; catch (ParserConfigurationException exception)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDPlugin.INSTANCE.log(exception);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return null;<br>
</blockquote>
Or the XSDResourceImpl does it directly:<br>
<blockquote><small>&nbsp; protected static Document getDocument(InputSource
inputSource, ErrorHandler errorHandler)&nbsp; throws IOException</small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; try</small><br>
<small>&nbsp;&nbsp;&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; DocumentBuilderFactory documentBuilderFactory =
DocumentBuilderFactory.newInstance();</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; documentBuilderFactory.setNamespaceAware(true);</small><br >
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; documentBuilderFactory.setValidating(false);</small><br>
<br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; DocumentBuilder documentBuilder =
documentBuilderFactory.newDocumentBuilder();</small><br>
<small>&nbsp; </small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Create a catalog with an entity mapping URL for the
cached DTD for XML Schemas and set to into the build.</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; //</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; EntityResolver entityResolver = createEntityResolver();</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; documentBuilder.setEntityResolver(entityResolver);</small><br >
<br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; documentBuilder.setErrorHandler(errorHandler);</small><br>
<br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Document document = documentBuilder.parse(inputSource);</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return document;</small><br>
<small>&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp; catch (ParserConfigurationException exception)</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; throw new IOWrappedException(exception);</small><br>
<small>&nbsp;&nbsp;&nbsp; catch (SAXException exception)</small><br>
<small>&nbsp; }</small><br>
</blockquote>
<br>
<blockquote cite="middhej65$pmd$1@news.eclipse.org" type="cite">Ed,
<br>
<br>
in the Element.&nbsp; The element is of type
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://xml.org/sax/features/namespaces">http://xml.org/sax/features/namespaces</a> feature of the Xerces parser,
<br>
<br>
See: <a class="moz-txt-link-freetext" href="http://xml.apache.org/xerces2-j/features.html">http://xml.apache.org/xerces2-j/features.html</a>
<br>
<br>
<br>
<br>
Francis
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Francis,
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Map theQNamePrefixToNamespaceMap =
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; theQNamePrefixToNamespaceMap.clear();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; for (Element currentElement = changedElement; currentElement
<br>
&nbsp;&nbsp;&nbsp; != null; )
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; NamedNodeMap attributes = currentElement.getAttributes();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for (int i = 0, size = attributes.getLength(); i &lt; size;
++i)
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; Attr attr = (Attr)attributes.item(i);
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; String name = attr.getNodeName();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (name.startsWith("xmlns"))
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; String value = attr.getNodeValue();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; int index = name.indexOf(":");
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; String key&nbsp; = index == -1 ? null : name.substring(index
<br>
&nbsp;&nbsp;&nbsp; + 1);
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (!theQNamePrefixToNamespaceMap.containsKey(key))
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; theQNamePrefixToNamespaceMap.put(key, value);
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Node parent = currentElement.getParentNode();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (parent instanceof Element)
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; currentElement = (Element)parent;
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; else
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; break;
<br>
<br>
<br>
<br>
being populated.
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Good morning Ed,
<br>
<br>
<br>
<br>
expect.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&
Re: errors using XSD as plugin, UnknownHostException and NPE [message #64237 is a reply to message #64184] Wed, 28 September 2005 14:44 Go to previous message
Francis,
I'm glad to hear it's working. I should have hit send on my other note
before I went to a meeting. ;-)
> Ed,
> for the DOM parser.
> Francis
>> Ed,
>> present in the Element. The element is of type
>> Francis
>> Ed Merks wrote:
>>> Francis,
>>> != null; )
>>> ++i)
>>> + 1);
>>> else
>>> break;
>>> being populated.
>>>> Good morning Ed,
>>>> generations.
>>>> expect.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> simple xsd document
>>>> <xsd:complexType>
>>>> <xsd:sequence>
>>>> <xsd:complexType>
>>>> <xsd:sequence>
>>>> <xsd:element name="Title" type="xsd:string" minOccurs="1"
>>>> maxOccurs="1"/>
>>>> <xsd:element name="Author" type="xsd:string" minOccurs="1"
>>>> maxOccurs="2"/>
>>>> <xsd:element name="Date" type="xsd:string" minOccurs="1"
>>>> maxOccurs="1"/>
>>>> <!-- ISBN
>>>> <xsd:element name="ISBN" type="xsd:string" minOccurs="0"
>>>> maxOccurs="1"/>
>>>> <xsd:element name="Publisher" type="xsd:string" minOccurs="1"
>>>> maxOccurs="1"/>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> </xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596657 is a reply to message #63953] Tue, 27 September 2005 14:08 Go to previous message
Francis,
> version 2.0.1.
> than XSD):
> org.eclipse.osgi,
> org.eclipse.swt,
> org.eclipse.ui,
> org.eclipse.ui.ide,
> org.junit,
> org.eclipse.xsd,
> Any ideas?
> Francis
> !STACK 0
> at
> at
> at
> Source)
> Source)
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596671 is a reply to message #63982] Tue, 27 September 2005 17:32 Go to previous message
Ed Merks wrote:
> Francis,
this:
version: 1.0)
xsdImport:
namespace:
in schemas.
>> version 2.0.1.
>> than XSD):
>> org.eclipse.osgi,
>> org.eclipse.swt,
>> org.eclipse.ui,
>> org.eclipse.ui.ide,
>> org.junit,
>> org.eclipse.xsd,
>> Any ideas?
>> Thanks,
>> Francis
>> !STACK 0
>> at
>> at
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596690 is a reply to message #64007] Tue, 27 September 2005 19:24 Go to previous message
Francis,
> Ed Merks wrote:
>> Francis,
> this:
> xsdImport:
> namespace:
> built in schemas.
>>> with version 2.0.1.
>>> bit more than XSD):
>>> org.eclipse.osgi,
>>> org.eclipse.swt,
>>> org.eclipse.ui,
>>> org.eclipse.ui.ide,
>>> org.junit,
>>> org.eclipse.xsd,
>>> Any ideas?
>>> Thanks,
>>> Francis
>>> !STACK 0
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !MESSAGE
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596701 is a reply to message #64033] Wed, 28 September 2005 02:21 Go to previous message
Ed,
org.eclipse.osgi,
org.eclipse.swt,
org.eclipse.ui,
org.eclipse.ui.ide,
org.junit,
org.eclipse.xsd,
Francis
Ed Merks wrote:
> Francis,
>> Ed Merks wrote:
>>> Francis,
>> this:
>> xsdImport:
>> namespace:
>> built in schemas.
>>>> with version 2.0.1.
>>>> bit more than XSD):
>>>> org.eclipse.osgi,
>>>> org.eclipse.swt,
>>>> org.eclipse.ui,
>>>> org.eclipse.ui.ide,
>>>> org.junit,
>>>> org.eclipse.xsd,
>>>> Any ideas?
>>>> Thanks,
>>>> Francis
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !MESSAGE
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596710 is a reply to message #64057] Wed, 28 September 2005 05:28 Go to previous message
Ed,
http://www.w3.org/2001/xml.xsd It has been called a couple of other
Francis
> Ed,
> org.eclipse.osgi,
> org.eclipse.swt,
> org.eclipse.ui,
> org.eclipse.ui.ide,
> org.junit,
> org.eclipse.xsd,
> Francis
> Ed Merks wrote:
>> Francis,
>> up...
>>> Ed Merks wrote:
>>>> Francis,
>>>> showed...
>>> this:
>>> xsdImport:
>>> namespace:
>>> built in schemas.
>>>>> with version 2.0.1.
>>>>> bit more than XSD):
>>>>> org.eclipse.osgi,
>>>>> org.eclipse.swt,
>>>>> org.eclipse.ui,
>>>>> org.eclipse.ui.ide,
>>>>> org.junit,
>>>>> org.eclipse.xsd,
>>>>> Any ideas?
>>>>> Thanks,
>>>>> Francis
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !MESSAGE
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596714 is a reply to message #64081] Wed, 28 September 2005 06:19 Go to previous message
Good morning Ed,
expect.
simple xsd document
<xsd:complexType>
<xsd:sequence>
<xsd:complexType>
<xsd:sequence>
<xsd:element
<xsd:element
<xsd:element
<!-- ISBN
<xsd:element
<xsd:element
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596726 is a reply to message #64105] Wed, 28 September 2005 07:41 Go to previous message
Francis,
!= null; )
+ 1);
else
break;
being populated.
> Good morning Ed,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> simple xsd document
> <xsd:complexType>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:element
> <xsd:element
> <xsd:element
> <!-- ISBN
> <xsd:element
> <xsd:element
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
<html>
<head>
</head>
Francis,<br>
<br>
</blockquote>
<br>
<br>
morning Ed,
<br>
<br>
<br>
<br>
expect.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&lt;!--
<br>
<br>
--&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&lt;/xsd:schema&gt;
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596742 is a reply to message #64134] Wed, 28 September 2005 13:16 Go to previous message
Ed,
Francis
Ed Merks wrote:
> Francis,
> != null; )
> + 1);
> else
> break;
> being populated.
>> Good morning Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> simple xsd document
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:element
>> <xsd:element
>> <xsd:element
>> <!-- ISBN
>> <xsd:element
>> <xsd:element
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596751 is a reply to message #64158] Wed, 28 September 2005 13:41 Go to previous message
Ed,
the DOM parser.
Francis
> Ed,
> Francis
> Ed Merks wrote:
>> Francis,
>> != null; )
>> + 1);
>> else
>> break;
>> being populated.
>>> Good morning Ed,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> simple xsd document
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:element
>>> <xsd:element
>>> <xsd:element
>>> <!-- ISBN
>>> <xsd:element
>>> <xsd:element
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:schema>
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596759 is a reply to message #64158] Wed, 28 September 2005 14:28 Go to previous message
Francis,
try
return null;
try
return document;
> Ed,
> Francis
> Ed Merks wrote:
>> Francis,
>> != null; )
>> ++i)
>> + 1);
>> else
>> break;
>> being populated.
>>> Good morning Ed,
>>> generations.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> simple xsd document
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:element
>>> <xsd:element
>>> <xsd:element
>>> <!-- ISBN
>>> <xsd:element
>>> <xsd:element
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:schema>
<html>
<head>
</head>
Francis,<br>
<br>
&nbsp; {<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Francis
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
++i)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
being populated.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
expect.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
o
Re: errors using XSD as plugin, UnknownHostException and NPE [message #596769 is a reply to message #64184] Wed, 28 September 2005 14:44 Go to previous message
Francis,
> Ed,
> for the DOM parser.
> Francis
>> Ed,
>> Francis
>> Ed Merks wrote:
>>> Francis,
>>> != null; )
>>> ++i)
>>> + 1);
>>> else
>>> break;
>>> being populated.
>>>> Good morning Ed,
>>>> generations.
>>>> expect.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> simple xsd document
>>>> <xsd:complexType>
>>>> <xsd:sequence>
>>>> <xsd:complexType>
>>>> <xsd:sequence>
>>>> maxOccurs="1"/>
>>>> maxOccurs="2"/>
>>>> maxOccurs="1"/>
>>>> <!-- ISBN
>>>> maxOccurs="1"/>
>>>> maxOccurs="1"/>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> </xsd:schema>
Previous Topic:errors using XSD as plugin, UnknownHostException and NPE
Next Topic:plug in for XSD
Current Time: Sat Nov 08 19:57:48 EST 2025
Powered by FUDForum. Page generated in 0.09319 seconds
