Home » Eclipse Projects » Plugin Development Environment (PDE) » Extension point schema org.eclipse.ui.navigator.viewer cannot be found
Extension point schema org.eclipse.ui.navigator.viewer cannot be found [message #5723] Tue, 03 June 2008 12:48
(This is just a reposting of the post above called "re: Common Navigator
Framework) with a more descriptive title, hoping that one of the great
PDE experts will help out here.
Joe Hutson wrote:
> I�m working through Michael Elder�s CNF tutorials as a second pass at
gaining some experience with the CNF. I am having trouble getting the
manifest editor to find extension point schema and definition for
org.eclipse.ui.navigator.viewer and
org.eclipse.ui.navigator.navigatorContent. The error message is
'Extension point schema org.eclipse.ui.navigator.viewer cannot be
found.' Eclipse version 3.3.2
> org.eclipse.ui.navigator is configured as dependency for my plug-in
> Any suggestions?
Previous Topic:simple cheatsheet editor doesn't support command returns property?
Next Topic:Extension point schema org.eclipse.ui.navigator.viewer cannot be found
Current Time: Sun Nov 09 04:21:24 EST 2025
Powered by FUDForum. Page generated in 0.02879 seconds
