Home » Modeling » GMF (Graphical Modeling Framework) » How to replace the view of an existing element
How to replace the view of an existing element [message #63909] Tue, 17 October 2006 07:27 Go to next message
Originally posted by: jan.herriger.gmx.de
Hello all,
I'd like to have an ObjectActionDelegate which replaces the view of the
selected element.
In the delegate, I use the following code to create a new view:
ObjectAdapter objAdapter = new ObjectAdapter();
objAdapter.setObject(PetrinetElementTypes.Transition_2002);
CreateViewRequest.ViewDescriptor viewDescriptor = new
CreateViewRequest.ViewDescriptor(
objAdapter, Node.class,
null,
PetrinetDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT);
CreateViewRequest cvRequest = new CreateViewRequest((viewDescriptor));
Command cmd = selectedElement.getParent().getCommand(cvRequest);
IDiagramEditDomain dEditingDomain =
selectedElement.getDiagramEditDomain();
dEditingDomain.getDiagramCommandStack().execute(cmd);
Is there a way to replace the selectedElement's view with the new one?
best regards
Jan
Re: How to replace the view of an existing element [message #64476 is a reply to message #63909] Tue, 17 October 2006 12:18 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
Look in CreationEditPolicy and ComponentEditPolicy for commands to create
views and delete, respectively.
On Tue, 17 Oct 2006 13:27:30 +0200, Jan Herriger wrote:
> Hello all,
> selected element.
> null,
> best regards
> Jan
Re: How to replace the view of an existing element [message #64543 is a reply to message #64476] Tue, 17 October 2006 14:12 Go to previous messageGo to next message
Thanks Vlad,
but I think, I was on the wrong approach...
Basically I want to switch between two visual styles of one EditPart.
So, I think i will add a property to the semantic model, wich indicates
what style the EditPart should have and add a logic to the EditPart's
class accordingly. I don't know, if this is the right approach. But it
seems to work.
>> Hello all,
>> selected element.
>> null,
>> best regards
>> Jan
Re: How to replace the view of an existing element [message #64588 is a reply to message #64543] Tue, 17 October 2006 14:47 Go to previous messageGo to next message
Ok, in that case look at the code in ShapeEditPart to see how it
registers/listens to the notational model and refreshes when changes
occur. Do the same for your semantic model.
hope this helps
vlad
On Tue, 17 Oct 2006 20:12:49 +0200, Jan Herriger wrote:
> Thanks Vlad,
> seems to work.
>>> Hello all,
>>> selected element.
>>> null,
>>> best regards
>>> Jan
Re: How to replace the view of an existing element [message #64679 is a reply to message #64588] Tue, 17 October 2006 16:16 Go to previous messageGo to next message
Thanks again Vlad,
keep on helping like that. Thats great.
For interested parties:
I'm creating a petrinet editor to become familiar with GMF. Transition
nodes (simple rectange figures) should be able to be switched between
vertical orientation and horizontal oriantation.
I added the following code to 'TransitionEditPart.java':
protected void handleNotificationEvent(Notification notification) {
	Transition t = (Transition) this.resolveSemanticElement();
	Object feature = notification.getFeature();
	if (PetrinetPackage.eINSTANCE.getTransition_Vertical().equals(feature))
		refreshBounds();
	else
		super.handleNotificationEvent(notification);
protected void refreshBounds() {
	Dimension size = getPrimaryShapeDimension();
	int x = ((Integer)
getStructuralFeatureValue(NotationPackage.eINSTANCE.getLocation_X())).intValue();
	int y = ((Integer)
getStructuralFeatureValue(NotationPackage.eINSTANCE.getLocation_Y())).intValue();
	Point loc = new Point(x, y);
	((GraphicalEditPart) getParent()).setLayoutConstraint(
		this,
		getFigure(),
		new Rectangle(loc, size));
protected Dimension getPrimaryShapeDimension() {
	if (t.isVertical())
		return new Dimension(40, 10);
	else
		return new Dimension(10, 40);
Changing the 'vertical' EAttribute now results in switching between
> hope this helps
> vlad
>> Thanks Vlad,
>> seems to work.
>>>> Hello all,
>>>> selected element.
>>>> null,
>>>> best regards
>>>> Jan
Re: How to replace the view of an existing element [message #64702 is a reply to message #64679] Tue, 17 October 2006 16:34 Go to previous messageGo to next message
forget about the first line of handleNotificationEvent method...
Jan Herriger schrieb:
> Thanks again Vlad,
>         refreshBounds();
>     else
>     int x = ((Integer)
>     int y = ((Integer)
>         this,
>         getFigure(),
>     if (t.isVertical())
>     else
Re: How to replace the view of an existing element [message #64796 is a reply to message #64702] Wed, 18 October 2006 04:38 Go to previous messageGo to next message
Hi Jan,
Another possibility could be to register two different mappings and
differentiate between them using MappingEntry.domainSpecialization
constraint. An example of this approach can be found in the MindMap project
used in tutorial (three different link mappings are used for the domain
element Relationship).
The advantages of having two distinct elements are the following:
1. You may associate completely unrelated figures with these two elements
(this may not bee needed in your scenario, although you might use figures
with fixed sizes 10x40 and 40x10, respectively);
2. You might associate different creation tools with these elements (but
still have one creation tool if you don't need two);
3. You might associate element initializers with these elements, so as to
initialize your orientation based on the element you are creating.
4. This approach can be easily adapted to the situation when the visual
aspects of an element depend on multiple features, all you need is to modify
the OCL expression in the *.gmfmap.
Disadvantages are:
1. You have more code generated. This may be a problem as the number of
@generated NOT's increases;
2. If the visual aspects depend solely on a single attribute of the semantic
element, OCL may seem an overkill;
3. There is a known problem in the generated diagram editor that a
XXXCanonicalEditPpolicy might fail to always update the ElementType on a
change in the domain model that affects the element type. (this problem is
not present in the lite runtime, where ANY such change is guaranteed to be
processed correctly).
Boris
"Jan Herriger" <jan.herriger@gmx.de> wrote in message
news:eh3eng$7q1$1@utils.eclipse.org...
>> Thanks again Vlad,
>>     if
>>         refreshBounds();
>>     else
>>     int x = ((Integer)
>> int y = ((Integer)
>>         this,
>>         getFigure(),
>>     if (t.isVertical())
>>     else
Re: How to replace the view of an existing element [message #65210 is a reply to message #64796] Wed, 18 October 2006 09:39 Go to previous messageGo to next message
Hi Boris,
having two different mappings was my very first approach. It seems to be
the most logic way, having two independent visual elements, which can be
associated to an element. But I just can't see how to change the visual
component of an existing element (in a way different to how I mentioned
before). Maybe I'm just a blockhead right now ;-)
Best regards
Jan
Boris Blajer schrieb:
> Hi Jan,
> Disadvantages are:
> Best regards,
> Boris
>>> Thanks again Vlad,
>>>     if
>>>         refreshBounds();
>>>     else
>>>     int x = ((Integer)
>>> int y = ((Integer)
>>>         this,
>>>         getFigure(),
>>>     if (t.isVertical())
>>>     else
Re: How to replace the view of an existing element [message #65356 is a reply to message #65210] Wed, 18 October 2006 10:28 Go to previous message
Hi Jan,
In fact, this should be automatic (provided that the node is canonical). The
fact that it does not update is due to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150257.
Boris
news:eh5aqo$3er$1@utils.eclipse.org...
> Hi Boris,
> Best regards
> Jan
>> Hi Jan,
>> project used in tutorial (three different link mappings are used for the
>> domain element Relationship).
>> modify the OCL expression in the *.gmfmap.
>> Disadvantages are:
>> semantic element, OCL may seem an overkill;
>> is not present in the lite runtime, where ANY such change is guaranteed
>> to be processed correctly).
>> Best regards,
>> Boris
>>>> Thanks again Vlad,
>>>>     if
>>>>         refreshBounds();
>>>>     else
>>>>     int x = ((Integer)
>>>> int y = ((Integer)
>>>>         this,
>>>>         getFigure(),
>>>>     if (t.isVertical())
>>>>     else
Previous Topic:How does one create pre-defined fixed elements/figures?
Next Topic:How to set ConnectionRouter?
Current Time: Mon Jul 21 21:11:23 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
